点击时序约束编辑器老说已经运行了,怎么回事?
2839|3
 楼主| nongfuxu 发表于 2012-2-17 16:42 | 显示全部楼层 |阅读模式
关机,开机.运行ISE13.2.
在项目中双击时序约束编辑器,总是出现下图所示对话框,怎么解决啊?
铁蛋gg 发表于 2012-2-17 18:48 | 显示全部楼层
应该是ISE13.2的漏洞。
Care should always be taken to ensure that a file is not being edited in multiple tools at the same time.
The situation described above can be caused if the system or just the ISE software is shut down while the UCF file is open in the PlanAhead tool. When Project Navigator is reopened, attempting to open the UCF in any of the editors results in the error message. In this case, the warning message can be ignored.
To avoid this warning message, delete the PlanAhead_run_# directory in the project directory when PlanAhead is NOT open
Backkom80 发表于 2012-2-17 18:58 | 显示全部楼层
这种打开方式不好,直接用text打开.ucf较佳
方法,直接新建.ucf的文本,然后添加到工程,以后要修改时选中
.ucf,在processes栏,双击edit constrants(text)即可
 楼主| nongfuxu 发表于 2012-2-17 19:41 | 显示全部楼层
已经解决,感谢了。
个人签名:是不是经济不KUA,房价下不来? 高房价只能带来“实体经济挤出效应”。
417
