在USB部分 关于端点0~5 在整个寻址空间内部有两个地方,一个是0x020,另一个是0x500,不知道这样的用意是啥?但是库用的是0x500部分地址。
比如:USB_MXPLD0~5
USB_CFGP0~5
6.16.6Page 486 of 532
- typedef struct
- * @VAR USBD_EP_T::BUFSEG0
- * Offset: 0x500/0x510/0x520/0x530/0x540/0x550/0x560/0x570 Endpoint 0~7 Buffer Segmentation Register
- * |Bits |Field |Descriptions
- * |[8:3] |BUFSEG |Endpoint Buffer Segmentation
- * | | |It is used to indicate the offset address for each endpoint with the USB SRAM starting address The effective starting address of the endpoint is
- * | | |USB_SRAM address + { BUFSEG[8:3], 3'b000}
- * | | |Where the USB_SRAM address = USBD_BA+0x100h.
- * @var USBD_EP_T::MXPLD0
- * Offset: 0x504/0x514/0x524/0x534/0x544/0x554/0x564/0x574 Endpoint 0~7 Maximal Payload Register
- * |[8:0] |MXPLD |Maximal Payload
- * | | |Define the data length which is transmitted to host (IN token) or the actual data length which is received from the host (OUT token).
- * | | |It also used to indicate that the endpoint is ready to be transmitted in IN token or received in OUT token.
- * | | |(1) When the register is written by CPU,
- * | | |For IN token, the value of MXPLD is used to define the data length to be transmitted and indicate the data buffer is ready.
- * | | |For OUT token, it means that the controller is ready to receive data from the host and the value of MXPLD is the maximal data length comes from host.
- * | | |(2) When the register is read by CPU,
- * | | |For IN token, the value of MXPLD is indicated by the data length be transmitted to host
- * | | |For OUT token, the value of MXPLD is indicated the actual data length receiving from host.
- * | | |Note: Once MXPLD is written, the data packets will be transmitted/received immediately after IN/OUT token arrived.
- * @var USBD_EP_T::CFG0
- * Offset: 0x508/0x518/0x528/0x538/0x548/0x558/0x568/0x578 Endpoint 0~7 Configuration Register
- * |[3:0] |EP_NUM |Endpoint Number
- * | | |These bits are used to define the endpoint number of the current endpoint.
- * |[4] |ISOCH |Isochronous Endpoint
- * | | |This bit is used to set the endpoint as Isochronous endpoint, no handshake.
- * | | |0 = No Isochronous endpoint.
- * | | |1 = Isochronous endpoint.
- * |[6:5] |STATE |Endpoint STATE
- * | | |00 = Endpoint is Disabled.
- * | | |01 = Out endpoint.
- * | | |10 = IN endpoint.
- * | | |11 = Undefined.
- * |[7] |DSQ_SYNC |Data Sequence Synchronization
- * | | |0 = DATA0 PID.
- * | | |1 = DATA1 PID.
- * | | |Note: It is used to specify the DATA0 or DATA1 PID in the following IN token transaction.
- * | | |Hardware will toggle automatically in IN token base on the bit.
- * |[9] |CSTALL |Clear STALL Response
- * | | |0 = Disable the device to clear the STALL handshake in setup stage.
- * | | |1 = Clear the device to response STALL handshake in setup stage.
- * @var USBD_EP_T::CFGP0
- * Offset: 0x50C/0x51C/0x52C/0x53C/0x54C/0x55C/0x56C/0x57C Endpoint 0~7 Set Stall and Clear In/Out Ready Control Register
- * |[0] |CLRRDY |Clear Ready
- * | | |When the USB_MXPLD register is set by user, it means that the endpoint is ready to transmit or receive data.
- * | | |If the user wants to turn off this transaction before the transaction start, users can set this bit to 1 to turn it off and it will be cleared to 0 automatically.
- * | | |For IN token, write '1' to clear the IN token had ready to transmit the data to USB.
- * | | |For OUT token, write '1' to clear the OUT token had ready to receive the data from USB.
- * | | |This bit is write 1 only and is always 0 when it is read back.
- * |[1] |SSTALL |Set STALL
- * | | |0 = Disable the device to response STALL.
- * | | |1 = Set the device to respond STALL automatically.
- __IO uint32_t BUFSEG; /* Offset: 0x500/0x510/0x520/0x530/0x540/0x550/0x560/0x570 Endpoint 0~7 Buffer Segmentation Register */
- __IO uint32_t MXPLD; /* Offset: 0x504/0x514/0x524/0x534/0x544/0x554/0x564/0x574 Endpoint 0~7 Maximal Payload Register */
- __IO uint32_t CFG; /* Offset: 0x508/0x518/0x528/0x538/0x548/0x558/0x568/0x578 Endpoint 0~7 Configuration Register */
- __IO uint32_t CFGP; /* Offset: 0x50C/0x51C/0x52C/0x53C/0x54C/0x55C/0x56C/0x57C Endpoint 0~7 Set Stall and Clear In/Out Ready Control Register */
- } USBD_EP_T;
复制代码
