uboot移植参考(2)
1710|1
 楼主| ferenc2 发表于 2012-2-20 21:41 | 显示全部楼层 |阅读模式
                  uboot移植参考(2)
增加对S3C2440的支持,2440的时钟计算公式、NAND操作和2410不太一样。
对于2440开发板,将FCLK设为400MHz,分频比为FCLK:HCLK:PCLK=1:4:8。
修改board/TX2440/TX2440.c中的board_init函数
/* S3C2440: Mpll,Upll = (2*m * Fin) / (p * 2^s)
* m = M (the value for divider M)+ 8, p = P (the value for divider P) + 2
#define S3C2440_MPLL_400MHZ
((0x7f<<12)|(0x02<<4)|(0x01))
#define S3C2440_UPLL_48MHZ
((0x38<<12)|(0x02<<4)|(0x02))
#define S3C2440_CLKDIV
0x05
/* FCLK:HCLK:PCLK = 1:4:8 */
/* S3C2410: Mpll,Upll = (m * Fin) / (p * 2^s)
#define S3C2410_MPLL_200MHZ
((0x5c<<12)|(0x04<<4)|(0x00))
#define S3C2410_UPLL_48MHZ
((0x28<<12)|(0x01<<4)|(0x02))
#define S3C2410_CLKDIV
0x03
/* FCLK:HCLK:PCLK = 1:2:4 */
int board_init (void)
S3C24X0_CLOCK_POWER * const clk_power = S3C24X0_GetBase_CLOCK_POWER();
S3C24X0_GPIO * const gpio = S3C24X0_GetBase_GPIO();
/* set up the I/O ports */
gpio->GPACON = 0x007FFFFF;
gpio->GPBCON = 0x00044555;
gpio->GPBUP = 0x000007FF;
gpio->GPCCON = 0xAAAAAAAA;
gpio->GPCUP = 0x0000FFFF;
gpio->GPDCON = 0xAAAAAAAA;
gpio->GPDUP = 0x0000FFFF;
gpio->GPECON = 0xAAAAAAAA;
gpio->GPEUP = 0x0000FFFF;
gpio->GPFCON = 0x000055AA;
gpio->GPFUP = 0x000000FF;
gpio->GPGCON = 0xFF95FFBA;
gpio->GPGUP = 0x0000FFFF;
gpio->GPHCON = 0x002AFAAA;
gpio->GPHUP = 0x000007FF;
/*support both of S3C2410 and S3C2440*/
if ((gpio->GSTATUS1 == 0x32410000) || (gpio->GSTATUS1 == 0x32410002))
/*FCLK:HCLK:PCLK = 1:2:4*/
clk_power->CLKDIVN = S3C2410_CLKDIV;
/* change to asynchronous bus mod */
__asm__(
"mrc
p15, 0, r1, c1, c0, 0\n"
/* read ctrl register
"orr
r1, r1, #0xc0000000\n"
/* Asynchronous
"mcr
/* write ctrl register
:::"r1"
/* to reduce PLL lock time, adjust the LOCKTIME register */
clk_power->LOCKTIME = 0xFFFFFF;
/* configure MPLL */
clk_power->MPLLCON = S3C2410_MPLL_200MHZ;
/* some delay between MPLL and UPLL */
delay (4000);
/* configure UPLL */
clk_power->UPLLCON = S3C2410_UPLL_48MHZ;
delay (8000);
/* arch number of SMDK2410-Board */
gd->bd->bi_arch_number = MACH_TYPE_SMDK2410;
else
clk_power->CLKDIVN = S3C2440_CLKDIV;
__asm__(
"mrc
"orr
/* Asynchronous
"mcr
:::"r1"
clk_power->MPLLCON = S3C2440_MPLL_400MHZ;
delay (4000);
clk_power->UPLLCON = S3C2440_UPLL_48MHZ;
delay (8000);
/* arch number of SMDK2440-Board */
gd->bd->bi_arch_number = MACH_TYPE_S3C2440;
/* adress of boot parameters */
gd->bd->bi_boot_params = 0x30000100;
icache_enable();
dcache_enable();
return 0;
在cpu/arm920t/s3c24X0/speed.c中修改:
在程序开头增加一行DECLARE_GLOBAL_DATA_PTR;,这样才可以使用gd变量
修改get_PLLCLK函数:
static ulong get_PLLCLK(int pllreg)
ulong r, m, p, s;
if (pllreg == MPLL)
r = clk_power->MPLLCON;
else if (pllreg == UPLL)
r = clk_power->UPLLCON;
else
hang();
m = ((r & 0xFF000) >> 12) + 8;
p = ((r & 0x003F0) >> 4) + 2;
s = r & 0x3;
/* support both of S3C2410 and S3C2440 */
if (gd->bd->bi_arch_number == MACH_TYPE_SMDK2410)
return((CONFIG_SYS_CLK_FREQ * m) / (p << s));
else
return((CONFIG_SYS_CLK_FREQ * m * 2) / (p << s));
/* S3C2440
 楼主| ferenc2 发表于 2012-2-20 21:55 | 显示全部楼层
