整个代码如下。- #include "stm8s.h"
- #include "stm8s_gpio.h"
- #include "stdio.h"
- #pragma vector=0x05
- __interrupt void PortA_InterruptHandler(void)
- GPIO_DeInit(GPIOB);
- /************ CLK SWITCH CODE*******************/
- void ClkSelectInit()
- ErrorStatus SwitchClkFlag;
- CLK_DeInit();
- CLK_ClockSwitchCmd(ENABLE); //ENABLE AUTOMATIC SWITCH CLOCKSOURCE
- SwitchClkFlag=CLK_ClockSwitchConfig(CLK_SWITCHMODE_AUTO, CLK_SOURCE_HSI, ENABLE, CLK_CURRENTCLOCKSTATE_ENABLE);
- if(SwitchClkFlag==SUCCESS)
- CLK_HSICmd(ENABLE);
- /************GPIOA init CODE*******************/
- void GpioInit()
- GPIO_DeInit(GPIOA); //PortA DATA Reset Init;
- GPIO_Init(GPIOA, GPIO_PIN_1, GPIO_MODE_OUT_PP_LOW_SLOW); // GPIOA bit 1 is output
- GPIO_Init(GPIOA, GPIO_PIN_2, GPIO_MODE_IN_PU_IT); //GPIOA BIT 2 external interrupt pull-up resistant.
- GPIO_WriteHigh(GPIOA, GPIO_PIN_1); //port bit 1 is high level;
- /***********GPIO Interrupt Setting Code************/
- void GpioInterruptInit()
- EXTI_DeInit();
- EXTI_SetExtIntSensitivity(EXTI_PORT_GPIOA, EXTI_SENSITIVITY_FALL_ONLY);//setting portA have a interrupt,fall trigger.
- /**********Main *********Code***************/
- int main(void)
- ClkSelectInit();
- GpioInit();
- GpioInterruptInit();
- enableInterrupts();
- while(1);
