The Telecommunication Engineering Centre #TEC has issued the updated version of #MTCTE procedure on May 15th 2021.Major updates in the latest version w.r.t last versions are as below:
1.modification in the scope of certification
2.modification in documents requirement while submitting the application
3.inclusion of "Split Unit Type Models" approach under formation guidelines
4.Addition of fee details for activities like certificate modification and certificate renewals
5.Date of dispatch of consignment of #Telecom equipment from foreign ports shall be treated as date of import.
6.Amendment in MTCTE labelling requirement now it is made mandatory for certified products to be marked with TEC ** and certain other details like ER number, model Certificate number, date and validity of certificate, etc. further, in order to ensure that this change don't affect the already manufactured products, a relaxation to use old marking guidelines is also provided till 30-11-2021.
印度电信工程中心#TEC已于2021年5月15日发布了电信设备的强制性测试和认证MTCTE程序的更新版本,最新版本的主要更新如下:
1.认证范围的修改
2.提交申请要求文件的修改
3. 依据制定指南的方式进行“分体式类型型号”纳入
4.针对证书修改和证书续订等活动增加费用明细
5.从国外港口发出#电信设备的托运日期应视为进口日期。
6,对MTCTE标签要求进行了修订,强制要求对认证产品标上TEC标识以及其他一些详细信息,例如ER号,型号证书编号,证书的日期和有效期等,另外,为了确保此更改不会影响已经生产的产品,规定放宽使用旧标记准则的有效期至2021年11月30日。
