[DemoCode下载] 硬件除法器使用方法
6519|13
 楼主| 玛尼玛尼哄 发表于 2021-6-20 20:44 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V2.10
  4. * $Revision: 3 $
  5. * $Date: 14/01/28 11:44a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    NUC029 Series Timer Controller and Watchdog Timer Driver Sample Code
  7. *
  8. * @note
  9. * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "NUC029xAN.h"
  14. #define PLLCON_SETTING      CLK_PLLCON_50MHz_XTAL
  15. #define PLL_CLOCK           50000000
  16. void SYS_Init(void)
  17. {
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Init System Clock        */
  20.     /*---------------------------------------------------------------------------------------------------------*/
  21.     /* Enable External XTAL (4~24 MHz) */
  22.     CLK->PWRCON &= ~CLK_PWRCON_XTL12M_EN_Msk;
  23.     CLK->PWRCON |= (0x1 << CLK_PWRCON_XTL12M_EN_Pos); // XTAL12M (HXT) Enabled
  24.     /* Waiting for 12MHz clock ready */
  25.     while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_XTL12M_STB_Msk));
  26.     /* Enable IP clock */
  27.     CLK->APBCLK |= CLK_APBCLK_UART0_EN_Msk; // UART Clock Enable
  28.     /* Select IP clock source */
  29.     CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
  30.     CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UART_S_Pos);// Clock source from external 12 MHz
  31.     /* Set P30(RXD0),P31(TXD0) multi-function pins for UART0 RXD and TXD  */
  32.     SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
  33. }
  34. void UART0_Init(void)
  35. {
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Init UART        */
  38.     /*---------------------------------------------------------------------------------------------------------*/
  39.     /* Configure UART0 and set UART0 Baudrate */
  40.     UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
  41.     UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
  42. }
  43. void HDIV_Init(void)
  44. {
  45.     /* Enable Hardware Divider Clock */
  46.     CLK->AHBCLK |= CLK_AHBCLK_HDIV_EN_Msk;
  47. }
  48. /*---------------------------------------------------------------------------------------------------------*/
  49. /*  MAIN function        */
  50. /*---------------------------------------------------------------------------------------------------------*/
  51. int main(void)
  52. {
  53.     /* Disable register write-protection function */
  54.     SYS_UnlockReg();
  55.     /* Init System, IP clock and multi-function I/O */
  56.     SYS_Init();
  57.     /* Init UART0 for printf */
  58.     UART0_Init();
  59.     /* Init Divider */
  60.     HDIV_Init();
  61.     printf("+----------------------------------------------+\n");
  62.     printf("|       Divider Sample Code                    |\n");
  63.     printf("+----------------------------------------------+\n");
  64.     printf("\n");
  65.     printf("12341 / 123 = %d\n", HDIV_Div(12341, 123));
  66.     printf("12341 %% 123 = %d\n", HDIV_Mod(12341, 123));
  67.     /* Lock protected registers */
  68.     SYS_LockReg();
  69.     printf("Done\n");
  70.     while(SYS->PDID);
  71.     return 0;
  72. }
sparrow054 发表于 2021-7-10 16:34 | 显示全部楼层
老板,看不太懂,能不能有时间的时候,给讲解一下。
发个原创帖,没准还有奖励,
实在是,最近也一直对这部分有点兴趣
之前都是代码里存来存去的,
幸福小强 发表于 2021-7-10 17:16 | 显示全部楼层
发个原创帖,没准还有奖励,
实在是,最近也一直对这部 ...
直接使能该功能,然后调用库函数啊。有啥难的。
我是看明白了,就是有一个相关的库函数,直接使能该功能后调用除法器的库函数计算。
huahuagg 发表于 2021-7-10 21:19 | 显示全部楼层
看起来很好使用,下次遇到计算试试这个方法对比一下。
foxsbig 发表于 2021-7-12 09:42 | 显示全部楼层
是初始化,之后,就直接调用如下就可以了么?
zhuomuniao110 发表于 2021-7-12 22:34 | 显示全部楼层
应该是的,就是这样吧
zhuomuniao110 发表于 2021-7-12 22:35 | 显示全部楼层
初始化好像就是使能数学除法器的时钟。
jiekou001 发表于 2021-7-15 21:51 | 显示全部楼层
还没用过,所有系列都支持吗
两只袜子 发表于 2021-7-16 19:51 来自手机 | 显示全部楼层
所有系列都支持吗
木木guainv 发表于 2021-8-6 19:01 | 显示全部楼层
这个是专用的除法器吗
xiaoqizi 发表于 2021-8-6 19:06 | 显示全部楼层
会不会非常耗费资源啊
734774645 发表于 2021-8-9 22:57 | 显示全部楼层
非常容易用。
734774645 发表于 2021-8-9 22:58 | 显示全部楼层
会不会非常耗费资源啊
这个外设应该就是减少消耗资源的。
不然需要很多指令组合才能完成除法运算
