借T叔资料,分析MDK(keil)和gcc两种汇编语言实例:一个sta...
7372|4
 楼主| keer_zu 发表于 2021-6-24 14:17 | 显示全部楼层 |阅读模式
1.MDK:
//主要做的事情:初始化栈指针(SP),程序计数器,设置中断向量表,配置时钟系统和外部SRAM挂载。。。最后跳转至main
  1. ;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
  2. ;* File Name          : startup_stm32f4xx.s
  3. ;* Author             : MCD Application Team
  4. ;* Version            : V1.0.0
  5. ;* Date               : 31-October-2011
  6. ;* Description        : STM32F4xx devices vector table for MDK-ARM toolchain.
  7. ;*                      This module performs:   <font color="#ff0000">// 这个模块的提供功能有:(和GCC的基本一模一样)</font>
  8. ;*                      - Set the initial SP
  9. ;*                      - Set the initial PC == Reset_Handler
  10. ;*                      - Set the vector table entries with the exceptions ISR address
  11. ;*                      - Branches to __main in the C library (which eventually
  12. ;*                        calls main()).
  13. ;*                      After Reset the CortexM4 processor is in Thread mode,
  14. ;*                      priority is Privileged, and the Stack is set to Main.
  15. ;* <<< Use Configuration Wizard in Context Menu >>>
  16. ;*******************************************************************************
  17. ; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  18. ; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
  19. ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
  20. ; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
  21. ; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
  22. ; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  23. ;*******************************************************************************
  24. ; Amount of memory (in bytes) allocated for Stack
  25. ; Tailor this value to your application needs
  26. ; <h> Stack Configuration
  27. ;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
  28. ; </h>
  29. GBLL   FreeRTOS
  30. FreeRTOS        SETL {FALSE}
  31. Stack_Size      EQU     0x00006000
  32.                 AREA    STACK, NOINIT, READWRITE, ALIGN=3
  33. Stack_Mem       SPACE   Stack_Size
  34. __initial_sp
  35. ; <h> Heap Configuration
  36. ;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
  37. ; </h>
  38. Heap_Size       EQU     0x00000000
  39.                 AREA    HEAP, NOINIT, READWRITE, ALIGN=3
  40. __heap_base
  41. Heap_Mem        SPACE   Heap_Size
  42. __heap_limit
  43.                 PRESERVE8
  44.                 THUMB
  45.         IF FreeRTOS = {TRUE}
  46.         EXTERN xPortPendSVHandler
  47.         EXTERN vPortSVCHandler
  48.             ENDIF
  49. ; Vector Table Mapped to Address 0 at Reset
  50.                 AREA    RESET, DATA, READONLY
  51.                 EXPORT  __Vectors
  52.                 EXPORT  __Vectors_End
  53.                 EXPORT  __Vectors_Size
  54. __Vectors       DCD     __initial_sp               ; Top of Stack
  55.                 DCD     Reset_Handler              ; Reset Handler
  56.                 DCD     NMI_Handler                ; NMI Handler
  57.                 DCD     HardFault_Handler          ; Hard Fault Handler
  58.                 DCD     MemManage_Handler          ; MPU Fault Handler
  59.                 DCD     BusFault_Handler           ; Bus Fault Handler
  60.                 DCD     UsageFault_Handler         ; Usage Fault Handler
  61.                 DCD     0                          ; Reserved
  62.                 DCD     0                          ; Reserved
  63.                 DCD     0                          ; Reserved
  64.                 DCD     0                          ; Reserved
  65.         IF FreeRTOS = {TRUE}
  66.                         DCD     vPortSVCHandler                   ; FreeRTOS SVC handler
  67.         ELSE
  68.                         DCD     SVC_Handler                            ; SVCall Handler
  69.         ENDIF
  70.                         DCD     DebugMon_Handler          ; Debug Monitor Handler
  71.                         DCD     0                         ; Reserved
  72.         IF FreeRTOS = {TRUE}
  73.                         DCD     xPortPendSVHandler        ; FreeRTOS PendSV  Handler
  74.         ELSE
  75.                         DCD     PendSV_Handler            ; PendSV Handler
  76.         ENDIF
  77.                 DCD     SysTick_Handler            ; SysTick Handler
  78.                 ; External Interrupts
  79.                 DCD     WWDG_IRQHandler                   ; Window WatchDog
  80.                 DCD     PVD_IRQHandler                    ; PVD through EXTI Line detection
  81.                 DCD     TAMP_STAMP_IRQHandler             ; Tamper and TimeStamps through the EXTI line
  82.                 DCD     RTC_WKUP_IRQHandler               ; RTC Wakeup through the EXTI line
  83.                 DCD     FLASH_IRQHandler                  ; FLASH
  84.                 DCD     RCC_IRQHandler                    ; RCC
  85.                 DCD     EXTI0_IRQHandler                  ; EXTI Line0
  86.                 DCD     EXTI1_IRQHandler                  ; EXTI Line1
  87.                 DCD     EXTI2_IRQHandler                  ; EXTI Line2
  88.                 DCD     EXTI3_IRQHandler                  ; EXTI Line3
  89.                 DCD     EXTI4_IRQHandler                  ; EXTI Line4
  90.                 DCD     DMA1_Stream0_IRQHandler           ; DMA1 Stream 0
  91.                 DCD     DMA1_Stream1_IRQHandler           ; DMA1 Stream 1
  92.                 DCD     DMA1_Stream2_IRQHandler           ; DMA1 Stream 2
  93.                 DCD     DMA1_Stream3_IRQHandler           ; DMA1 Stream 3
  94.                 DCD     DMA1_Stream4_IRQHandler           ; DMA1 Stream 4
  95.                 DCD     DMA1_Stream5_IRQHandler           ; DMA1 Stream 5
  96.                 DCD     DMA1_Stream6_IRQHandler           ; DMA1 Stream 6
  97.                 DCD     ADC_IRQHandler                    ; ADC1, ADC2 and ADC3s
  98.                 DCD     CAN1_TX_IRQHandler                ; CAN1 TX
  99.                 DCD     CAN1_RX0_IRQHandler               ; CAN1 RX0
  100.                 DCD     CAN1_RX1_IRQHandler               ; CAN1 RX1
  101.                 DCD     CAN1_SCE_IRQHandler               ; CAN1 SCE
  102.                 DCD     EXTI9_5_IRQHandler                ; External Line[9:5]s
  103.                 DCD     TIM1_BRK_TIM9_IRQHandler          ; TIM1 Break and TIM9
  104.                 DCD     TIM1_UP_TIM10_IRQHandler          ; TIM1 Update and TIM10
  105.                 DCD     TIM1_TRG_COM_TIM11_IRQHandler     ; TIM1 Trigger and Commutation and TIM11
  106.                 DCD     TIM1_CC_IRQHandler                ; TIM1 Capture Compare
  107.                 DCD     TIM2_IRQHandler                   ; TIM2
  108.                 DCD     TIM3_IRQHandler                   ; TIM3
  109.                 DCD     TIM4_IRQHandler                   ; TIM4
  110.                 DCD     I2C1_EV_IRQHandler                ; I2C1 Event
  111.                 DCD     I2C1_ER_IRQHandler                ; I2C1 Error
  112.                 DCD     I2C2_EV_IRQHandler                ; I2C2 Event
  113.                 DCD     I2C2_ER_IRQHandler                ; I2C2 Error
  114.                 DCD     SPI1_IRQHandler                   ; SPI1
  115.                 DCD     SPI2_IRQHandler                   ; SPI2
  116.                 DCD     USART1_IRQHandler                 ; USART1
  117.                 DCD     USART2_IRQHandler                 ; USART2
  118.                 DCD     USART3_IRQHandler                 ; USART3
  119.                 DCD     EXTI15_10_IRQHandler              ; External Line[15:10]s
  120.                 DCD     RTC_Alarm_IRQHandler              ; RTC Alarm (A and B) through EXTI Line
  121.                 DCD     OTG_FS_WKUP_IRQHandler            ; USB OTG FS Wakeup through EXTI line
  122.                 DCD     TIM8_BRK_TIM12_IRQHandler         ; TIM8 Break and TIM12
  123.                 DCD     TIM8_UP_TIM13_IRQHandler          ; TIM8 Update and TIM13
  124.                 DCD     TIM8_TRG_COM_TIM14_IRQHandler     ; TIM8 Trigger and Commutation and TIM14
  125.                 DCD     TIM8_CC_IRQHandler                ; TIM8 Capture Compare
  126.                 DCD     DMA1_Stream7_IRQHandler           ; DMA1 Stream7
  127.                 DCD     FSMC_IRQHandler                   ; FSMC
  128.                 DCD     SDIO_IRQHandler                   ; SDIO
  129.                 DCD     TIM5_IRQHandler                   ; TIM5
  130.                 DCD     SPI3_IRQHandler                   ; SPI3
  131.                 DCD     UART4_IRQHandler                  ; UART4
  132.                 DCD     UART5_IRQHandler                  ; UART5
  133.                 DCD     TIM6_DAC_IRQHandler               ; TIM6 and DAC1&2 underrun errors
  134.                 DCD     TIM7_IRQHandler                   ; TIM7
  135.                 DCD     DMA2_Stream0_IRQHandler           ; DMA2 Stream 0
  136.                 DCD     DMA2_Stream1_IRQHandler           ; DMA2 Stream 1
  137.                 DCD     DMA2_Stream2_IRQHandler           ; DMA2 Stream 2
  138.                 DCD     DMA2_Stream3_IRQHandler           ; DMA2 Stream 3
  139.                 DCD     DMA2_Stream4_IRQHandler           ; DMA2 Stream 4
  140.                 DCD     ETH_IRQHandler                    ; Ethernet
  141.                 DCD     ETH_WKUP_IRQHandler               ; Ethernet Wakeup through EXTI line
  142.                 DCD     CAN2_TX_IRQHandler                ; CAN2 TX
  143.                 DCD     CAN2_RX0_IRQHandler               ; CAN2 RX0
  144.                 DCD     CAN2_RX1_IRQHandler               ; CAN2 RX1
  145.                 DCD     CAN2_SCE_IRQHandler               ; CAN2 SCE
  146.                 DCD     OTG_FS_IRQHandler                 ; USB OTG FS
  147.                 DCD     DMA2_Stream5_IRQHandler           ; DMA2 Stream 5
  148.                 DCD     DMA2_Stream6_IRQHandler           ; DMA2 Stream 6
  149.                 DCD     DMA2_Stream7_IRQHandler           ; DMA2 Stream 7
  150.                 DCD     USART6_IRQHandler                 ; USART6
  151.                 DCD     I2C3_EV_IRQHandler                ; I2C3 event
  152.                 DCD     I2C3_ER_IRQHandler                ; I2C3 error
  153.                 DCD     OTG_HS_EP1_OUT_IRQHandler         ; USB OTG HS End Point 1 Out
  154.                 DCD     OTG_HS_EP1_IN_IRQHandler          ; USB OTG HS End Point 1 In
  155.                 DCD     OTG_HS_WKUP_IRQHandler            ; USB OTG HS Wakeup through EXTI
  156.                 DCD     OTG_HS_IRQHandler                 ; USB OTG HS
  157.                 DCD     DCMI_IRQHandler                   ; DCMI
  158.                 DCD     CRYP_IRQHandler                   ; CRYP crypto
  159.                 DCD     HASH_RNG_IRQHandler               ; Hash and Rng
  160.                 DCD     FPU_IRQHandler                    ; FPU
  161.
  162. __Vectors_End
  163. __Vectors_Size  EQU  __Vectors_End - __Vectors
  164.                 AREA    |.text|, CODE, READONLY
  165. ; Reset handler
  166. Reset_Handler    PROC
  167.                  EXPORT  Reset_Handler             [WEAK]
  168.         IMPORT  SystemInit
  169.         IMPORT  __main
  170.                  LDR     R0, =SystemInit
  171.                  BLX     R0
  172.                  LDR     R0, =__main
  173.                  BX      R0
  174.                  ENDP
  175. ; Dummy Exception Handlers (infinite loops which can be modified)
  176. NMI_Handler     PROC
  177.                 EXPORT  NMI_Handler                [WEAK]
  178.                 B       .
  179.                 ENDP
  180. HardFault_Handler\
  181.                 PROC
  182.                 EXPORT  HardFault_Handler          [WEAK]
  183.                 B       .
  184.                 ENDP
  185. MemManage_Handler\
  186.                 PROC
  187.                 EXPORT  MemManage_Handler          [WEAK]
  188.                 B       .
  189.                 ENDP
  190. BusFault_Handler\
  191.                 PROC
  192.                 EXPORT  BusFault_Handler           [WEAK]
  193.                 B       .
  194.                 ENDP
  195. UsageFault_Handler\
  196.                 PROC
  197.                 EXPORT  UsageFault_Handler         [WEAK]
  198.                 B       .
  199.                 ENDP
  200. SVC_Handler     PROC
  201.                 EXPORT  SVC_Handler                [WEAK]
  202.                 B       .
  203.                 ENDP
  204. DebugMon_Handler\
  205.                 PROC
  206.                 EXPORT  DebugMon_Handler           [WEAK]
  207.                 B       .
  208.                 ENDP
  209. PendSV_Handler  PROC
  210.                 EXPORT  PendSV_Handler             [WEAK]
  211.                 B       .
  212.                 ENDP
  213. SysTick_Handler PROC
  214.                 EXPORT  SysTick_Handler            [WEAK]
  215.                 B       .
  216.                 ENDP
  217. Default_Handler PROC
  218.                 EXPORT  WWDG_IRQHandler                   [WEAK]
  219.                 EXPORT  PVD_IRQHandler                    [WEAK]
  220.                 EXPORT  TAMP_STAMP_IRQHandler             [WEAK]
  221.                 EXPORT  RTC_WKUP_IRQHandler               [WEAK]
  222.                 EXPORT  FLASH_IRQHandler                  [WEAK]
  223.                 EXPORT  RCC_IRQHandler                    [WEAK]
  224.                 EXPORT  EXTI0_IRQHandler                  [WEAK]
  225.                 EXPORT  EXTI1_IRQHandler                  [WEAK]
  226.                 EXPORT  EXTI2_IRQHandler                  [WEAK]
  227.                 EXPORT  EXTI3_IRQHandler                  [WEAK]
  228.                 EXPORT  EXTI4_IRQHandler                  [WEAK]
  229.                 EXPORT  DMA1_Stream0_IRQHandler           [WEAK]
  230.                 EXPORT  DMA1_Stream1_IRQHandler           [WEAK]
  231.                 EXPORT  DMA1_Stream2_IRQHandler           [WEAK]
  232.                 EXPORT  DMA1_Stream3_IRQHandler           [WEAK]
  233.                 EXPORT  DMA1_Stream4_IRQHandler           [WEAK]
  234.                 EXPORT  DMA1_Stream5_IRQHandler           [WEAK]
  235.                 EXPORT  DMA1_Stream6_IRQHandler           [WEAK]
  236.                 EXPORT  ADC_IRQHandler                    [WEAK]
  237.                 EXPORT  CAN1_TX_IRQHandler                [WEAK]
  238.                 EXPORT  CAN1_RX0_IRQHandler               [WEAK]
  239.                 EXPORT  CAN1_RX1_IRQHandler               [WEAK]
  240.                 EXPORT  CAN1_SCE_IRQHandler               [WEAK]
  241.                 EXPORT  EXTI9_5_IRQHandler                [WEAK]
  242.                 EXPORT  TIM1_BRK_TIM9_IRQHandler          [WEAK]
  243.                 EXPORT  TIM1_UP_TIM10_IRQHandler          [WEAK]
  244.                 EXPORT  TIM1_TRG_COM_TIM11_IRQHandler     [WEAK]
  245.                 EXPORT  TIM1_CC_IRQHandler                [WEAK]
  246.                 EXPORT  TIM2_IRQHandler                   [WEAK]
  247.                 EXPORT  TIM3_IRQHandler                   [WEAK]
  248.                 EXPORT  TIM4_IRQHandler                   [WEAK]
  249.                 EXPORT  I2C1_EV_IRQHandler                [WEAK]
  250.                 EXPORT  I2C1_ER_IRQHandler                [WEAK]
  251.                 EXPORT  I2C2_EV_IRQHandler                [WEAK]
  252.                 EXPORT  I2C2_ER_IRQHandler                [WEAK]
  253.                 EXPORT  SPI1_IRQHandler                   [WEAK]
  254.                 EXPORT  SPI2_IRQHandler                   [WEAK]
  255.                 EXPORT  USART1_IRQHandler                 [WEAK]
  256.                 EXPORT  USART2_IRQHandler                 [WEAK]
  257.                 EXPORT  USART3_IRQHandler                 [WEAK]
  258.                 EXPORT  EXTI15_10_IRQHandler              [WEAK]
  259.                 EXPORT  RTC_Alarm_IRQHandler              [WEAK]
  260.                 EXPORT  OTG_FS_WKUP_IRQHandler            [WEAK]
  261.                 EXPORT  TIM8_BRK_TIM12_IRQHandler         [WEAK]
  262.                 EXPORT  TIM8_UP_TIM13_IRQHandler          [WEAK]
  263.                 EXPORT  TIM8_TRG_COM_TIM14_IRQHandler     [WEAK]
  264.                 EXPORT  TIM8_CC_IRQHandler                [WEAK]
  265.                 EXPORT  DMA1_Stream7_IRQHandler           [WEAK]
  266.                 EXPORT  FSMC_IRQHandler                   [WEAK]
  267.                 EXPORT  SDIO_IRQHandler                   [WEAK]
  268.                 EXPORT  TIM5_IRQHandler                   [WEAK]
  269.                 EXPORT  SPI3_IRQHandler                   [WEAK]
  270.                 EXPORT  UART4_IRQHandler                  [WEAK]
  271.                 EXPORT  UART5_IRQHandler                  [WEAK]
  272.                 EXPORT  TIM6_DAC_IRQHandler               [WEAK]
  273.                 EXPORT  TIM7_IRQHandler                   [WEAK]
  274.                 EXPORT  DMA2_Stream0_IRQHandler           [WEAK]
  275.                 EXPORT  DMA2_Stream1_IRQHandler           [WEAK]
  276.                 EXPORT  DMA2_Stream2_IRQHandler           [WEAK]
  277.                 EXPORT  DMA2_Stream3_IRQHandler           [WEAK]
  278.                 EXPORT  DMA2_Stream4_IRQHandler           [WEAK]
  279.                 EXPORT  ETH_IRQHandler                    [WEAK]
  280.                 EXPORT  ETH_WKUP_IRQHandler               [WEAK]
  281.                 EXPORT  CAN2_TX_IRQHandler                [WEAK]
  282.                 EXPORT  CAN2_RX0_IRQHandler               [WEAK]
  283.                 EXPORT  CAN2_RX1_IRQHandler               [WEAK]
  284.                 EXPORT  CAN2_SCE_IRQHandler               [WEAK]
  285.                 EXPORT  OTG_FS_IRQHandler                 [WEAK]
  286.                 EXPORT  DMA2_Stream5_IRQHandler           [WEAK]
  287.                 EXPORT  DMA2_Stream6_IRQHandler           [WEAK]
  288.                 EXPORT  DMA2_Stream7_IRQHandler           [WEAK]
  289.                 EXPORT  USART6_IRQHandler                 [WEAK]
  290.                 EXPORT  I2C3_EV_IRQHandler                [WEAK]
  291.                 EXPORT  I2C3_ER_IRQHandler                [WEAK]
  292.                 EXPORT  OTG_HS_EP1_OUT_IRQHandler         [WEAK]
  293.                 EXPORT  OTG_HS_EP1_IN_IRQHandler          [WEAK]
  294.                 EXPORT  OTG_HS_WKUP_IRQHandler            [WEAK]
  295.                 EXPORT  OTG_HS_IRQHandler                 [WEAK]
  296.                 EXPORT  DCMI_IRQHandler                   [WEAK]
  297.                 EXPORT  CRYP_IRQHandler                   [WEAK]
  298.                 EXPORT  HASH_RNG_IRQHandler               [WEAK]
  299.                 EXPORT  FPU_IRQHandler                    [WEAK]
  300. WWDG_IRQHandler
  301. PVD_IRQHandler
  302. TAMP_STAMP_IRQHandler
  303. RTC_WKUP_IRQHandler
  304. FLASH_IRQHandler
  305. RCC_IRQHandler
  306. EXTI0_IRQHandler
  307. EXTI1_IRQHandler
  308. EXTI2_IRQHandler
  309. EXTI3_IRQHandler
  310. EXTI4_IRQHandler
  311. DMA1_Stream0_IRQHandler
  312. DMA1_Stream1_IRQHandler
  313. DMA1_Stream2_IRQHandler
  314. DMA1_Stream3_IRQHandler
  315. DMA1_Stream4_IRQHandler
  316. DMA1_Stream5_IRQHandler
  317. DMA1_Stream6_IRQHandler
  318. ADC_IRQHandler
  319. CAN1_TX_IRQHandler
  320. CAN1_RX0_IRQHandler
  321. CAN1_RX1_IRQHandler
  322. CAN1_SCE_IRQHandler
  323. EXTI9_5_IRQHandler
  324. TIM1_BRK_TIM9_IRQHandler
  325. TIM1_UP_TIM10_IRQHandler
  326. TIM1_TRG_COM_TIM11_IRQHandler
  327. TIM1_CC_IRQHandler
  328. TIM2_IRQHandler
  329. TIM3_IRQHandler
  330. TIM4_IRQHandler
  331. I2C1_EV_IRQHandler
  332. I2C1_ER_IRQHandler
  333. I2C2_EV_IRQHandler
  334. I2C2_ER_IRQHandler
  335. SPI1_IRQHandler
  336. SPI2_IRQHandler
  337. USART1_IRQHandler
  338. USART2_IRQHandler
  339. USART3_IRQHandler
  340. EXTI15_10_IRQHandler
  341. RTC_Alarm_IRQHandler
  342. OTG_FS_WKUP_IRQHandler
  343. TIM8_BRK_TIM12_IRQHandler
  344. TIM8_UP_TIM13_IRQHandler
  345. TIM8_TRG_COM_TIM14_IRQHandler
  346. TIM8_CC_IRQHandler
  347. DMA1_Stream7_IRQHandler
  348. FSMC_IRQHandler
  349. SDIO_IRQHandler
  350. TIM5_IRQHandler
  351. SPI3_IRQHandler
  352. UART4_IRQHandler
  353. UART5_IRQHandler
  354. TIM6_DAC_IRQHandler
  355. TIM7_IRQHandler
  356. DMA2_Stream0_IRQHandler
  357. DMA2_Stream1_IRQHandler
  358. DMA2_Stream2_IRQHandler
  359. DMA2_Stream3_IRQHandler
  360. DMA2_Stream4_IRQHandler
  361. ETH_IRQHandler
  362. ETH_WKUP_IRQHandler
  363. CAN2_TX_IRQHandler
  364. CAN2_RX0_IRQHandler
  365. CAN2_RX1_IRQHandler
  366. CAN2_SCE_IRQHandler
  367. OTG_FS_IRQHandler
  368. DMA2_Stream5_IRQHandler
  369. DMA2_Stream6_IRQHandler
  370. DMA2_Stream7_IRQHandler
  371. USART6_IRQHandler
  372. I2C3_EV_IRQHandler
  373. I2C3_ER_IRQHandler
  374. OTG_HS_EP1_OUT_IRQHandler
  375. OTG_HS_EP1_IN_IRQHandler
  376. OTG_HS_WKUP_IRQHandler
  377. OTG_HS_IRQHandler
  378. DCMI_IRQHandler
  379. CRYP_IRQHandler
  380. HASH_RNG_IRQHandler
  381. FPU_IRQHandler
  382.                 B       .
  383.                 ENDP
  384.                 ALIGN
  385. ;*******************************************************************************
  386. ; User Stack and Heap initialization
  387. ;*******************************************************************************
  388.                  IF      :DEF:__MICROLIB
  389.
  390.                  EXPORT  __initial_sp
  391.                  EXPORT  __heap_base
  392.                  EXPORT  __heap_limit
  393.
  394.                  ELSE
  395.
  396.                  IMPORT  __use_two_region_memory
  397.                  EXPORT  __user_initial_stackheap
  398.
  399. __user_initial_stackheap
  400.                  LDR     R0, =  Heap_Mem
  401.                  LDR     R1, =(Stack_Mem + Stack_Size)
  402.                  LDR     R2, = (Heap_Mem +  Heap_Size)
  403.                  LDR     R3, = Stack_Mem
  404.                  BX      LR
  405.                  ALIGN
  406.                  ENDIF
  407.                  END
  408. ;******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE*****
 楼主| keer_zu 发表于 2021-6-24 14:19 | 显示全部楼层
2.gcc:
  1. /**
  2.   ******************************************************************************
  3.   * [url=home.php?mod=space&uid=288409]@file[/url]      startup_stm32f40_41xxx.s
  4.   * [url=home.php?mod=space&uid=187600]@author[/url]    MCD Application Team
  5.   * [url=home.php?mod=space&uid=895143]@version[/url]   V1.6.1
  6.   * [url=home.php?mod=space&uid=212281]@date[/url]      21-October-2015
  7.   * [url=home.php?mod=space&uid=247401]@brief[/url]     STM32F40xxx/41xxx Devices vector table for GCC based toolchain.
  8.   *            This module performs:
  9.   *                - Set the initial SP
  10.   *                - Set the initial PC == Reset_Handler,
  11.   *                - Set the vector table entries with the exceptions ISR address
  12.   *                - Configure the clock system and the external SRAM mounted on
  13.   *                  STM324xG-EVAL board to be used as data memory (optional,
  14.   *                  to be enabled by user)
  15.   *                - Branches to main in the C library (which eventually
  16.   *                  calls main()).
  17.   *            After Reset the Cortex-M4 processor is in Thread mode,
  18.   *            priority is Privileged, and the Stack is set to Main.
  19.   ******************************************************************************
  20.   * @attention
  21.   *
  22.   * <h2><center>© COPYRIGHT 2015 STMicroelectronics</center></h2>
  23.   *
  24.   * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  25.   * You may not use this file except in compliance with the License.
  26.   * You may obtain a copy of the License at:
  27.   *
  28.   *        http://www.st.com/software_license_agreement_liberty_v2
  29.   *
  30.   * Unless required by applicable law or agreed to in writing, software
  31.   * distributed under the License is distributed on an "AS IS" BASIS,
  32.   * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  33.   * See the License for the specific language governing permissions and
  34.   * limitations under the License.
  35.   *
  36.   ******************************************************************************
  37.   */
  38.   .syntax unified
  39.   .cpu cortex-m4
  40.   .fpu softvfp
  41.   .thumb
  42. .global  g_pfnVectors
  43. .global  Default_Handler
  44. /* start address for the initialization values of the .data section.
  45. defined in linker script */
  46. .word  _sidata
  47. /* start address for the .data section. defined in linker script */
  48. .word  _sdata
  49. /* end address for the .data section. defined in linker script */
  50. .word  _edata
  51. /* start address for the .bss section. defined in linker script */
  52. .word  _sbss
  53. /* end address for the .bss section. defined in linker script */
  54. .word  _ebss
  55. /* stack used for SystemInit_ExtMemCtl; always internal RAM used */
  56. /**
  57. * [url=home.php?mod=space&uid=247401]@brief[/url]  This is the code that gets called when the processor first
  58. *          starts execution following a reset event. Only the absolutely
  59. *          necessary set is performed, after which the application
  60. *          supplied main() routine is called.
  61. * @param  None
  62. * @retval : None
  63. */
  64.     .section  .text.Reset_Handler
  65.   .weak  Reset_Handler
  66.   .type  Reset_Handler, %function
  67. Reset_Handler:
  68. /* Copy the data segment initializers from flash to SRAM */
  69.   movs  r1, #0
  70.   b  LoopCopyDataInit
  71. CopyDataInit:
  72.   ldr  r3, =_sidata
  73.   ldr  r3, [r3, r1]
  74.   str  r3, [r0, r1]
  75.   adds  r1, r1, #4
  76. LoopCopyDataInit:
  77.   ldr  r0, =_sdata
  78.   ldr  r3, =_edata
  79.   adds  r2, r0, r1
  80.   cmp  r2, r3
  81.   bcc  CopyDataInit
  82.   ldr  r2, =_sbss
  83.   b  LoopFillZerobss
  84. /* Zero fill the bss segment. */
  85. FillZerobss:
  86.   movs  r3, #0
  87.   str  r3, [r2], #4
  88. LoopFillZerobss:
  89.   ldr  r3, = _ebss
  90.   cmp  r2, r3
  91.   bcc  FillZerobss
  92. ldr r2, = _sccmram
  93.   b LoopFillZeroCcm
  94. /* Zero fill the CCM segment */
  95. FillZeroCcm:
  96.   movs r3, #0
  97.   str  r3, [r2]
  98.   adds r2, r2, #4
  99. LoopFillZeroCcm:
  100.   ldr r3, = _eccmram
  101.   cmp r2, r3
  102.   bcc FillZeroCcm
  103. /* Call the clock system intitialization function.*/
  104.   bl  SystemInit
  105. /* Call static constructors */
  106.     bl __libc_init_array
  107. /* Call the application's entry point.*/
  108.   bl  main
  109.   bx  lr
  110. .size  Reset_Handler, .-Reset_Handler
  111. /**
  112. * [url=home.php?mod=space&uid=247401]@brief[/url]  This is the code that gets called when the processor receives an
  113. *         unexpected interrupt.  This simply enters an infinite loop, preserving
  114. *         the system state for examination by a debugger.
  115. * @param  None
  116. * @retval None
  117. */
  118.     .section  .text.Default_Handler,"ax",%progbits
  119. Default_Handler:
  120. Infinite_Loop:
  121.   b  Infinite_Loop
  122.   .size  Default_Handler, .-Default_Handler
  123. /******************************************************************************
  124. *
  125. * The minimal vector table for a Cortex M3. Note that the proper constructs
  126. * must be placed on this to ensure that it ends up at physical address
  127. * 0x0000.0000.
  128. *
  129. *******************************************************************************/
  130.    .section  .isr_vector,"a",%progbits
  131.   .type  g_pfnVectors, %object
  132.   .size  g_pfnVectors, .-g_pfnVectors
  133. g_pfnVectors:
  134.   .word  _estack
  135.   .word  Reset_Handler
  136.   .word  NMI_Handler
  137.   .word  HardFault_Handler
  138.   .word  MemManage_Handler
  139.   .word  BusFault_Handler
  140.   .word  UsageFault_Handler
  141.   .word  0
  142.   .word  0
  143.   .word  0
  144.   .word  0
  145.   .word  SVC_Handler
  146.   .word  DebugMon_Handler
  147.   .word  0
  148.   .word  PendSV_Handler
  149.   .word  SysTick_Handler
  150.   /* External Interrupts */
  151.   .word     WWDG_IRQHandler                   /* Window WatchDog              */
  152.   .word     PVD_IRQHandler                    /* PVD through EXTI Line detection */
  153.   .word     TAMP_STAMP_IRQHandler             /* Tamper and TimeStamps through the EXTI line */
  154.   .word     RTC_WKUP_IRQHandler               /* RTC Wakeup through the EXTI line */
  155.   .word     FLASH_IRQHandler                  /* FLASH                        */
  156.   .word     RCC_IRQHandler                    /* RCC                          */
  157.   .word     EXTI0_IRQHandler                  /* EXTI Line0                   */
  158.   .word     EXTI1_IRQHandler                  /* EXTI Line1                   */
  159.   .word     EXTI2_IRQHandler                  /* EXTI Line2                   */
  160.   .word     EXTI3_IRQHandler                  /* EXTI Line3                   */
  161.   .word     EXTI4_IRQHandler                  /* EXTI Line4                   */
  162.   .word     DMA1_Stream0_IRQHandler           /* DMA1 Stream 0                */
  163.   .word     DMA1_Stream1_IRQHandler           /* DMA1 Stream 1                */
  164.   .word     DMA1_Stream2_IRQHandler           /* DMA1 Stream 2                */
  165.   .word     DMA1_Stream3_IRQHandler           /* DMA1 Stream 3                */
  166.   .word     DMA1_Stream4_IRQHandler           /* DMA1 Stream 4                */
  167.   .word     DMA1_Stream5_IRQHandler           /* DMA1 Stream 5                */
  168.   .word     DMA1_Stream6_IRQHandler           /* DMA1 Stream 6                */
  169.   .word     ADC_IRQHandler                    /* ADC1, ADC2 and ADC3s         */
  170.   .word     CAN1_TX_IRQHandler                /* CAN1 TX                      */
  171.   .word     CAN1_RX0_IRQHandler               /* CAN1 RX0                     */
  172.   .word     CAN1_RX1_IRQHandler               /* CAN1 RX1                     */
  173.   .word     CAN1_SCE_IRQHandler               /* CAN1 SCE                     */
  174.   .word     EXTI9_5_IRQHandler                /* External Line[9:5]s          */
  175.   .word     TIM1_BRK_TIM9_IRQHandler          /* TIM1 Break and TIM9          */
  176.   .word     TIM1_UP_TIM10_IRQHandler          /* TIM1 Update and TIM10        */
  177.   .word     TIM1_TRG_COM_TIM11_IRQHandler     /* TIM1 Trigger and Commutation and TIM11 */
  178.   .word     TIM1_CC_IRQHandler                /* TIM1 Capture Compare         */
  179.   .word     TIM2_IRQHandler                   /* TIM2                         */
  180.   .word     TIM3_IRQHandler                   /* TIM3                         */
  181.   .word     TIM4_IRQHandler                   /* TIM4                         */
  182.   .word     I2C1_EV_IRQHandler                /* I2C1 Event                   */
  183.   .word     I2C1_ER_IRQHandler                /* I2C1 Error                   */
  184.   .word     I2C2_EV_IRQHandler                /* I2C2 Event                   */
  185.   .word     I2C2_ER_IRQHandler                /* I2C2 Error                   */
  186.   .word     SPI1_IRQHandler                   /* SPI1                         */
  187.   .word     SPI2_IRQHandler                   /* SPI2                         */
  188.   .word     USART1_IRQHandler                 /* USART1                       */
  189.   .word     USART2_IRQHandler                 /* USART2                       */
  190.   .word     USART3_IRQHandler                 /* USART3                       */
  191.   .word     EXTI15_10_IRQHandler              /* External Line[15:10]s        */
  192.   .word     RTC_Alarm_IRQHandler              /* RTC Alarm (A and B) through EXTI Line */
  193.   .word     OTG_FS_WKUP_IRQHandler            /* USB OTG FS Wakeup through EXTI line */
  194.   .word     TIM8_BRK_TIM12_IRQHandler         /* TIM8 Break and TIM12         */
  195.   .word     TIM8_UP_TIM13_IRQHandler          /* TIM8 Update and TIM13        */
  196.   .word     TIM8_TRG_COM_TIM14_IRQHandler     /* TIM8 Trigger and Commutation and TIM14 */
  197.   .word     TIM8_CC_IRQHandler                /* TIM8 Capture Compare         */
  198.   .word     DMA1_Stream7_IRQHandler           /* DMA1 Stream7                 */
  199.   .word     FSMC_IRQHandler                   /* FSMC                         */
  200.   .word     SDIO_IRQHandler                   /* SDIO                         */
  201.   .word     TIM5_IRQHandler                   /* TIM5                         */
  202.   .word     SPI3_IRQHandler                   /* SPI3                         */
  203.   .word     UART4_IRQHandler                  /* UART4                        */
  204.   .word     UART5_IRQHandler                  /* UART5                        */
  205.   .word     TIM6_DAC_IRQHandler               /* TIM6 and DAC1&2 underrun errors */
  206.   .word     TIM7_IRQHandler                   /* TIM7                         */
  207.   .word     DMA2_Stream0_IRQHandler           /* DMA2 Stream 0                */
  208.   .word     DMA2_Stream1_IRQHandler           /* DMA2 Stream 1                */
  209.   .word     DMA2_Stream2_IRQHandler           /* DMA2 Stream 2                */
  210.   .word     DMA2_Stream3_IRQHandler           /* DMA2 Stream 3                */
  211.   .word     DMA2_Stream4_IRQHandler           /* DMA2 Stream 4                */
  212.   .word     ETH_IRQHandler                    /* Ethernet                     */
  213.   .word     ETH_WKUP_IRQHandler               /* Ethernet Wakeup through EXTI line */
  214.   .word     CAN2_TX_IRQHandler                /* CAN2 TX                      */
  215.   .word     CAN2_RX0_IRQHandler               /* CAN2 RX0                     */
  216.   .word     CAN2_RX1_IRQHandler               /* CAN2 RX1                     */
  217.   .word     CAN2_SCE_IRQHandler               /* CAN2 SCE                     */
  218.   .word     OTG_FS_IRQHandler                 /* USB OTG FS                   */
  219.   .word     DMA2_Stream5_IRQHandler           /* DMA2 Stream 5                */
  220.   .word     DMA2_Stream6_IRQHandler           /* DMA2 Stream 6                */
  221.   .word     DMA2_Stream7_IRQHandler           /* DMA2 Stream 7                */
  222.   .word     USART6_IRQHandler                 /* USART6                       */
  223.   .word     I2C3_EV_IRQHandler                /* I2C3 event                   */
  224.   .word     I2C3_ER_IRQHandler                /* I2C3 error                   */
  225.   .word     OTG_HS_EP1_OUT_IRQHandler         /* USB OTG HS End Point 1 Out   */
  226.   .word     OTG_HS_EP1_IN_IRQHandler          /* USB OTG HS End Point 1 In    */
  227.   .word     OTG_HS_WKUP_IRQHandler            /* USB OTG HS Wakeup through EXTI */
  228.   .word     OTG_HS_IRQHandler                 /* USB OTG HS                   */
  229.   .word     DCMI_IRQHandler                   /* DCMI                         */
  230.   .word     CRYP_IRQHandler                   /* CRYP crypto                  */
  231.   .word     HASH_RNG_IRQHandler               /* Hash and Rng                 */
  232.   .word     FPU_IRQHandler                    /* FPU                          */
  233. /*******************************************************************************
  234. *
  235. * Provide weak aliases for each Exception handler to the Default_Handler.
  236. * As they are weak aliases, any function with the same name will override
  237. * this definition.
  238. *
  239. *******************************************************************************/
  240.    .weak      NMI_Handler
  241.    .thumb_set NMI_Handler,Default_Handler
  242.    .weak      HardFault_Handler
  243.    .thumb_set HardFault_Handler,Default_Handler
  244.    .weak      MemManage_Handler
  245.    .thumb_set MemManage_Handler,Default_Handler
  246.    .weak      BusFault_Handler
  247.    .thumb_set BusFault_Handler,Default_Handler
  248.    .weak      UsageFault_Handler
  249.    .thumb_set UsageFault_Handler,Default_Handler
  250.    .weak      SVC_Handler
  251.    .thumb_set SVC_Handler,Default_Handler
  252.    .weak      DebugMon_Handler
  253.    .thumb_set DebugMon_Handler,Default_Handler
  254.    .weak      PendSV_Handler
  255.    .thumb_set PendSV_Handler,Default_Handler
  256.    .weak      SysTick_Handler
  257.    .thumb_set SysTick_Handler,Default_Handler
  258.    .weak      WWDG_IRQHandler
  259.    .thumb_set WWDG_IRQHandler,Default_Handler
  260.    .weak      PVD_IRQHandler
  261.    .thumb_set PVD_IRQHandler,Default_Handler
  262.    .weak      TAMP_STAMP_IRQHandler
  263.    .thumb_set TAMP_STAMP_IRQHandler,Default_Handler
  264.    .weak      RTC_WKUP_IRQHandler
  265.    .thumb_set RTC_WKUP_IRQHandler,Default_Handler
  266.    .weak      FLASH_IRQHandler
  267.    .thumb_set FLASH_IRQHandler,Default_Handler
  268.    .weak      RCC_IRQHandler
  269.    .thumb_set RCC_IRQHandler,Default_Handler
  270.    .weak      EXTI0_IRQHandler
  271.    .thumb_set EXTI0_IRQHandler,Default_Handler
  272.    .weak      EXTI1_IRQHandler
  273.    .thumb_set EXTI1_IRQHandler,Default_Handler
  274.    .weak      EXTI2_IRQHandler
  275.    .thumb_set EXTI2_IRQHandler,Default_Handler
  276.    .weak      EXTI3_IRQHandler
  277.    .thumb_set EXTI3_IRQHandler,Default_Handler
  278.    .weak      EXTI4_IRQHandler
  279.    .thumb_set EXTI4_IRQHandler,Default_Handler
  280.    .weak      DMA1_Stream0_IRQHandler
  281.    .thumb_set DMA1_Stream0_IRQHandler,Default_Handler
  282.    .weak      DMA1_Stream1_IRQHandler
  283.    .thumb_set DMA1_Stream1_IRQHandler,Default_Handler
  284.    .weak      DMA1_Stream2_IRQHandler
  285.    .thumb_set DMA1_Stream2_IRQHandler,Default_Handler
  286.    .weak      DMA1_Stream3_IRQHandler
  287.    .thumb_set DMA1_Stream3_IRQHandler,Default_Handler
  288.    .weak      DMA1_Stream4_IRQHandler
  289.    .thumb_set DMA1_Stream4_IRQHandler,Default_Handler
  290.    .weak      DMA1_Stream5_IRQHandler
  291.    .thumb_set DMA1_Stream5_IRQHandler,Default_Handler
  292.    .weak      DMA1_Stream6_IRQHandler
  293.    .thumb_set DMA1_Stream6_IRQHandler,Default_Handler
  294.    .weak      ADC_IRQHandler
  295.    .thumb_set ADC_IRQHandler,Default_Handler
  296.    .weak      CAN1_TX_IRQHandler
  297.    .thumb_set CAN1_TX_IRQHandler,Default_Handler
  298.    .weak      CAN1_RX0_IRQHandler
  299.    .thumb_set CAN1_RX0_IRQHandler,Default_Handler
  300.    .weak      CAN1_RX1_IRQHandler
  301.    .thumb_set CAN1_RX1_IRQHandler,Default_Handler
  302.    .weak      CAN1_SCE_IRQHandler
  303.    .thumb_set CAN1_SCE_IRQHandler,Default_Handler
  304.    .weak      EXTI9_5_IRQHandler
  305.    .thumb_set EXTI9_5_IRQHandler,Default_Handler
  306.    .weak      TIM1_BRK_TIM9_IRQHandler
  307.    .thumb_set TIM1_BRK_TIM9_IRQHandler,Default_Handler
  308.    .weak      TIM1_UP_TIM10_IRQHandler
  309.    .thumb_set TIM1_UP_TIM10_IRQHandler,Default_Handler
  310.    .weak      TIM1_TRG_COM_TIM11_IRQHandler
  311.    .thumb_set TIM1_TRG_COM_TIM11_IRQHandler,Default_Handler
  312.    .weak      TIM1_CC_IRQHandler
  313.    .thumb_set TIM1_CC_IRQHandler,Default_Handler
  314.    .weak      TIM2_IRQHandler
  315.    .thumb_set TIM2_IRQHandler,Default_Handler
  316.    .weak      TIM3_IRQHandler
  317.    .thumb_set TIM3_IRQHandler,Default_Handler
  318.    .weak      TIM4_IRQHandler
  319.    .thumb_set TIM4_IRQHandler,Default_Handler
  320.    .weak      I2C1_EV_IRQHandler
  321.    .thumb_set I2C1_EV_IRQHandler,Default_Handler
  322.    .weak      I2C1_ER_IRQHandler
  323.    .thumb_set I2C1_ER_IRQHandler,Default_Handler
  324.    .weak      I2C2_EV_IRQHandler
  325.    .thumb_set I2C2_EV_IRQHandler,Default_Handler
  326.    .weak      I2C2_ER_IRQHandler
  327.    .thumb_set I2C2_ER_IRQHandler,Default_Handler
  328.    .weak      SPI1_IRQHandler
  329.    .thumb_set SPI1_IRQHandler,Default_Handler
  330.    .weak      SPI2_IRQHandler
  331.    .thumb_set SPI2_IRQHandler,Default_Handler
  332.    .weak      USART1_IRQHandler
  333.    .thumb_set USART1_IRQHandler,Default_Handler
  334.    .weak      USART2_IRQHandler
  335.    .thumb_set USART2_IRQHandler,Default_Handler
  336.    .weak      USART3_IRQHandler
  337.    .thumb_set USART3_IRQHandler,Default_Handler
  338.    .weak      EXTI15_10_IRQHandler
  339.    .thumb_set EXTI15_10_IRQHandler,Default_Handler
  340.    .weak      RTC_Alarm_IRQHandler
  341.    .thumb_set RTC_Alarm_IRQHandler,Default_Handler
  342.    .weak      OTG_FS_WKUP_IRQHandler
  343.    .thumb_set OTG_FS_WKUP_IRQHandler,Default_Handler
  344.    .weak      TIM8_BRK_TIM12_IRQHandler
  345.    .thumb_set TIM8_BRK_TIM12_IRQHandler,Default_Handler
  346.    .weak      TIM8_UP_TIM13_IRQHandler
  347.    .thumb_set TIM8_UP_TIM13_IRQHandler,Default_Handler
  348.    .weak      TIM8_TRG_COM_TIM14_IRQHandler
  349.    .thumb_set TIM8_TRG_COM_TIM14_IRQHandler,Default_Handler
  350.    .weak      TIM8_CC_IRQHandler
  351.    .thumb_set TIM8_CC_IRQHandler,Default_Handler
  352.    .weak      DMA1_Stream7_IRQHandler
  353.    .thumb_set DMA1_Stream7_IRQHandler,Default_Handler
  354.    .weak      FSMC_IRQHandler
  355.    .thumb_set FSMC_IRQHandler,Default_Handler
  356.    .weak      SDIO_IRQHandler
  357.    .thumb_set SDIO_IRQHandler,Default_Handler
  358.    .weak      TIM5_IRQHandler
  359.    .thumb_set TIM5_IRQHandler,Default_Handler
  360.    .weak      SPI3_IRQHandler
  361.    .thumb_set SPI3_IRQHandler,Default_Handler
  362.    .weak      UART4_IRQHandler
  363.    .thumb_set UART4_IRQHandler,Default_Handler
  364.    .weak      UART5_IRQHandler
  365.    .thumb_set UART5_IRQHandler,Default_Handler
  366.    .weak      TIM6_DAC_IRQHandler
  367.    .thumb_set TIM6_DAC_IRQHandler,Default_Handler
  368.    .weak      TIM7_IRQHandler
  369.    .thumb_set TIM7_IRQHandler,Default_Handler
  370.    .weak      DMA2_Stream0_IRQHandler
  371.    .thumb_set DMA2_Stream0_IRQHandler,Default_Handler
  372.    .weak      DMA2_Stream1_IRQHandler
  373.    .thumb_set DMA2_Stream1_IRQHandler,Default_Handler
  374.    .weak      DMA2_Stream2_IRQHandler
  375.    .thumb_set DMA2_Stream2_IRQHandler,Default_Handler
  376.    .weak      DMA2_Stream3_IRQHandler
  377.    .thumb_set DMA2_Stream3_IRQHandler,Default_Handler
  378.    .weak      DMA2_Stream4_IRQHandler
  379.    .thumb_set DMA2_Stream4_IRQHandler,Default_Handler
  380.    .weak      ETH_IRQHandler
  381.    .thumb_set ETH_IRQHandler,Default_Handler
  382.    .weak      ETH_WKUP_IRQHandler
  383.    .thumb_set ETH_WKUP_IRQHandler,Default_Handler
  384.    .weak      CAN2_TX_IRQHandler
  385.    .thumb_set CAN2_TX_IRQHandler,Default_Handler
  386.    .weak      CAN2_RX0_IRQHandler
  387.    .thumb_set CAN2_RX0_IRQHandler,Default_Handler
  388.    .weak      CAN2_RX1_IRQHandler
  389.    .thumb_set CAN2_RX1_IRQHandler,Default_Handler
  390.    .weak      CAN2_SCE_IRQHandler
  391.    .thumb_set CAN2_SCE_IRQHandler,Default_Handler
  392.    .weak      OTG_FS_IRQHandler
  393.    .thumb_set OTG_FS_IRQHandler,Default_Handler
  394.    .weak      DMA2_Stream5_IRQHandler
  395.    .thumb_set DMA2_Stream5_IRQHandler,Default_Handler
  396.    .weak      DMA2_Stream6_IRQHandler
  397.    .thumb_set DMA2_Stream6_IRQHandler,Default_Handler
  398.    .weak      DMA2_Stream7_IRQHandler
  399.    .thumb_set DMA2_Stream7_IRQHandler,Default_Handler
  400.    .weak      USART6_IRQHandler
  401.    .thumb_set USART6_IRQHandler,Default_Handler
  402.    .weak      I2C3_EV_IRQHandler
  403.    .thumb_set I2C3_EV_IRQHandler,Default_Handler
  404.    .weak      I2C3_ER_IRQHandler
  405.    .thumb_set I2C3_ER_IRQHandler,Default_Handler
  406.    .weak      OTG_HS_EP1_OUT_IRQHandler
  407.    .thumb_set OTG_HS_EP1_OUT_IRQHandler,Default_Handler
  408.    .weak      OTG_HS_EP1_IN_IRQHandler
  409.    .thumb_set OTG_HS_EP1_IN_IRQHandler,Default_Handler
  410.    .weak      OTG_HS_WKUP_IRQHandler
  411.    .thumb_set OTG_HS_WKUP_IRQHandler,Default_Handler
  412.    .weak      OTG_HS_IRQHandler
  413.    .thumb_set OTG_HS_IRQHandler,Default_Handler
  414.    .weak      DCMI_IRQHandler
  415.    .thumb_set DCMI_IRQHandler,Default_Handler
  416.    .weak      CRYP_IRQHandler
  417.    .thumb_set CRYP_IRQHandler,Default_Handler
  418.    .weak      HASH_RNG_IRQHandler
  419.    .thumb_set HASH_RNG_IRQHandler,Default_Handler
  420.    .weak      FPU_IRQHandler
  421.    .thumb_set FPU_IRQHandler,Default_Handler
  422. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
首先看简介: //主要做的事情:初始化栈指针(SP),程序计数器,设置中断向量表,配置时钟系统和外部SRAM挂载。。。最后跳转至main
  1. ******************************************************************************
  2.   * [url=home.php?mod=space&uid=288409]@file[/url]      startup_stm32f40_41xxx.s
  3.   * [url=home.php?mod=space&uid=187600]@author[/url]    MCD Application Team   <font color="#ff0000"> // 作者是同一个Team</font>
  4.   * [url=home.php?mod=space&uid=895143]@version[/url]   V1.6.1
  5.   * [url=home.php?mod=space&uid=212281]@date[/url]      21-October-2015
  6.   * @brief     STM32F40xxx/41xxx Devices vector table for GCC based toolchain.
  7.   *            This module performs:
  8.   *                - Set the initial SP
  9.   *                - Set the initial PC == Reset_Handler,
  10.   *                - Set the vector table entries with the exceptions ISR address
  11.   *                - Configure the clock system and the external SRAM mounted on
  12.   *                  STM324xG-EVAL board to be used as data memory (optional,
  13.   *                  to be enabled by user)
  14.   *                - Branches to main in the C library (which eventually
  15.   *                  calls main()).
  16.   *            After Reset the Cortex-M4 processor is in Thread mode,
  17.   *            priority is Privileged, and the Stack is set to Main.
  18.   ******************************************************************************
 楼主| keer_zu 发表于 2021-6-24 14:41 | 显示全部楼层
上面是MDK版提示用户可以设置栈大小
 楼主| keer_zu 发表于 2021-6-24 15:05 | 显示全部楼层
GCC startup的中断向量表: 569060d42e51e2ab6.png
 楼主| keer_zu 发表于 2021-6-24 15:06 | 显示全部楼层
MDK采用的中断向量:
