Error: init mode failed (unable to connect to the target)
in procedure 'init'
in procedure 'ocd_bouncer'
openocd用stlink调试stm32,报上面错误是什么原因?有遇到过吗?
有人建议boot0,boot1拉高可以烧写,烧写后boot0,boot1恢复之前状态,就可以恢复正常了。试了试,不行。
请大家给些建议。谢谢
完整的输出:
- PS D:\openocd\bin-x64> .\openocd.exe -f ..\scripts\interface\stlink-v2.cfg -f ..\scripts\target\stm32f4x_stlink.cfg
- Open On-Chip Debugger 0.10.0
- Licensed under GNU GPL v2
- For bug reports, read
- http://openocd.org/doc/doxygen/bugs.html
- WARNING: target/stm32f4x_stlink.cfg is deprecated, please switch to target/stm32f4x.cfg
- Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
- Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
- adapter speed: 2000 kHz
- adapter_nsrst_delay: 100
- none separate
- Info : Unable to match requested speed 2000 kHz, using 1800 kHz
- Info : clock speed 1800 kHz
- Info : STLINK v2 JTAG v35 API v2 SWIM v7 VID 0x0483 PID 0x3748
- Info : using stlink api v2
- Info : Target voltage: 3.210020
- Error: init mode failed (unable to connect to the target)
- in procedure 'init'
- in procedure 'ocd_bouncer'
