[应用方案] 【NuMaker-M471测评】OLED屏显示驱动
2294|18
 楼主| jinglixixi 发表于 2021-8-13 20:09 | 显示全部楼层 |阅读模式
前面我们介绍了驱动SPI接口LCD5110显示屏的方法,这次介绍一下如何驱动I2C接口的OLED屏,该OLED屏为0.91寸单色屏。
相对于LCD5110屏来讲,OLED屏更节省GPIO口。为了更便于使用,这里直接使用Arduino接口来控制OLED屏,相应的引脚连接关系为:
SDA ---PC1
SCL ---PC0
具体的实物连接如下图所示:
实物连接与显示效果
为实现高低电平的输出其语句定义为:
#define OLED_SCLK_Clr()  PC0=0
#define OLED_SCLK_Set()  PC0=1
#define OLED_SDIN_Clr()  PC1=0
#define OLED_SDIN_Set()  PC1=1
相应的OLED屏初始化函数为:
  1. void OLED_Init(void)
  3. Write_IIC_Command(0xAE); //display off
  4. Write_IIC_Command(0x40);//--set start line address
  5. Write_IIC_Command(0xb0);//Set Page Start Address for Page Addressing Mode,0-7
  6. Write_IIC_Command(0xc8);//Set COM Output Scan Direction
  7. Write_IIC_Command(0x81);//--set contrast control register
  8. Write_IIC_Command(0xff);
  9. Write_IIC_Command(0xa1);//--set segment re-map 0 to 127
  10. Write_IIC_Command(0xa6);//--set normal display
  11. Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64)
  12. Write_IIC_Command(0x1F);
  13. Write_IIC_Command(0xd3);//-set display offset
  14. Write_IIC_Command(0x00);//-not offset
  15. Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency
  16. Write_IIC_Command(0xf0);//--set divide ratio
  17. Write_IIC_Command(0xd9);//--set pre-charge period
  18. Write_IIC_Command(0x22);
  19. Write_IIC_Command(0xda);//--set com pins hardware configuration
  20. Write_IIC_Command(0x02);
  21. Write_IIC_Command(0x8d);//--set DC-DC enable
  22. Write_IIC_Command(0x14);
  23. Write_IIC_Command(0xdb);//--set vcomh
  24. Write_IIC_Command(0x49);//0x20,0.77xVcc
  25. Write_IIC_Command(0xaf);//--turn on oled panel
  26. }
模拟I2C的启动与停止的函数为:
  1. void IIC_Start()
  3. OLED_SCLK_Set();
  4. TIMER_Delay(TIMER0, 2);
  5. OLED_SDIN_Set();
  6. TIMER_Delay(TIMER0, 2);
  7. OLED_SDIN_Clr();
  8. TIMER_Delay(TIMER0, 2);
  9. OLED_SCLK_Clr();
  10. TIMER_Delay(TIMER0, 2);
  11. }
  12. void IIC_Stop()
  13. {
  14. OLED_SCLK_Set();
  15. TIMER_Delay(TIMER0, 2);
  16. OLED_SDIN_Clr();
  17. TIMER_Delay(TIMER0, 2);
  18. OLED_SDIN_Set();
  19. TIMER_Delay(TIMER0, 2);
  20. }
模拟I2C方式字节数据的函数为:
  1. void Write_IIC_Byte(unsigned char IIC_Byte)
  3. unsigned char i;
  4. unsigned char m,da;
  5. da=IIC_Byte;
  6. OLED_SCLK_Clr();
  7. for(i=0;i<8;i++)
  8. {
  9. m=da;
  10. m=m&0x80;
  11. if(m==0x80)
  12. {
相应的清屏函数为:
  1. void OLED_Clear(void)
  3. uint8_t i,n;
  4. for(i=0;i<8;i++)
  5. {
  6. OLED_WR_Byte (0xb0+i,OLED_CMD);
  7. OLED_WR_Byte (0x00,OLED_CMD);
  8. OLED_WR_Byte (0x10,OLED_CMD);
  9. for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
  10. }
  11. }
OLED屏的字符显示函数为:
  1. void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
  3. unsigned char c=0,i=0;
  4. c=chr-' ';
  5. if(x>Max_Column-1){x=0;y=y+2;}
  6. if(Char_Size ==16)
  7. {
  8. OLED_Set_Pos(x,y);
  9. for(i=0;i<8;i++)
  10. OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
  11. OLED_Set_Pos(x,y+1);
  12. for(i=0;i<8;i++)
  13. OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
  14. }
  15. else {
  16. OLED_Set_Pos(x,y);
  17. for(i=0;i<6;i++)
  18. OLED_WR_Byte(F6x8[c][i],OLED_DATA);
  19. }
  20. }
实现显示效果的主程序为:
  1. int main()
  3. uint32_t i,j;
  4. SYS_Init();
  5. GPIO_SetMode(PB, BIT14, GPIO_MODE_OUTPUT);
  6. GPIO_SetMode(PC, BIT1, GPIO_MODE_OUTPUT);
  7. GPIO_SetMode(PC, BIT0, GPIO_MODE_OUTPUT);
  8. GPIO_SetMode(PH, BIT4, GPIO_MODE_INPUT);
  9. PB14 = 1;
  10. OLED_Init();
  11. OLED_Clear();
  12. OLED_ShowString(0,0,"M471 TEST",16);
  13. OLED_ShowString(0,2,"OLED DISPLAY",16);
  14. while(1)
  15. {
  16. PB14 = 1;
  17. TIMER_Delay(TIMER0, 500000);
  18. PB14 = 0;
  19. TIMER_Delay(TIMER0, 500000);
  20. }
  21. }
643757107 发表于 2021-8-13 21:00 | 显示全部楼层
工程打包分享分享啊
laocuo1142 发表于 2021-8-18 15:26 来自手机 | 显示全部楼层
测评很顺利啊
 楼主| jinglixixi 发表于 2021-8-18 22:32 | 显示全部楼层
哈,抓空弄一点。
gaoyang9992006 发表于 2022-8-31 09:25 | 显示全部楼层
建议尝试一下硬件收发器的,不要GPIO
mintspring 发表于 2023-2-19 17:31 | 显示全部楼层
非常好用的屏幕,价格还不贵。
 楼主| jinglixixi 发表于 2023-2-19 17:37 | 显示全部楼层
非常好用的屏幕,价格还不贵。
是,挺实用的。
lzbf 发表于 2023-3-11 22:01 | 显示全部楼层
这个使用的硬件iic的吗、
 楼主| jinglixixi 发表于 2023-3-12 11:21 | 显示全部楼层
这个使用的硬件iic的吗、
向来不用硬件I2C
OKAKAKO 发表于 2023-3-13 10:13 | 显示全部楼层
“梦幻显示器”,有机发光显示器
belindagraham 发表于 2023-3-14 14:04 | 显示全部楼层
看着刷屏还有横线呢
olivem55arlowe 发表于 2023-3-14 15:34 | 显示全部楼层
SPI的通信速度是多大
 楼主| jinglixixi 发表于 2023-3-14 23:34 | 显示全部楼层
看着刷屏还有横线呢
试一试适当减小发送数据时的延时值
 楼主| jinglixixi 发表于 2023-3-14 23:35 | 显示全部楼层
SPI的通信速度是多大
是采用I2C接口控制
biechedan 发表于 2023-4-18 10:54 | 显示全部楼层
在编写驱动程序时,需要考虑图像处理算法、字模库、字符绘制等问题。
i1mcu 发表于 2023-4-18 16:55 | 显示全部楼层
OLED屏幕通常有SPI和I2C两种接口方式,需要根据具体情况选择合适的接口方式。
robertesth 发表于 2023-4-18 17:03 | 显示全部楼层
为了简化程序开发和降低硬件成本,可以选用内置OLED控制器的OLED屏幕。
dspmana 发表于 2023-4-18 21:48 | 显示全部楼层
可以采用逐行逐点的方式来检查显示效果。
Jacquetry 发表于 2023-4-18 22:37 | 显示全部楼层
SPI的通信速度是多大
这是IIC吧
