[技术问答] NUC980 Ubuntu20.04开发环境安装
6247|14
 楼主| zljiu 发表于 2021-8-14 17:17 | 显示全部楼层 |阅读模式
两种方式
(1)在Linux下搭建环境开发(ubuntu20.04 64bit)
a、通过repo下载相关源代码及工具文件,参考官方NUC980 Linux 4.4 BSP User Manual CHT.pdf文档(也可以直接一个一个地手动GIT下载),主要下载内容有:
https://gitee.com/OpenNuvoton/NUC970_U-Boot_v2016.11.git
https://gitee.com/OpenNuvoton/NUC980_Linux_Applications.git
https://gitee.com/OpenNuvoton/NUC970_Buildroot.git
https://gitee.com/OpenNuvoton/NUC980_NonOS_BSP.git
https://gitee.com/OpenNuvoton/NUC980-linux-4.4.y.git
https://gitee.com/OpenNuvoton/NUC980_NuWriter_CMD.git
b、安装所需的软件包,如下:
sudo apt install libc6-dev-i386
sudo apt install lib32z1
sudo apt install lib32ncurses6
sudo apt install lib32stdc++6
c、下载工具链 nuc980bsp.tar.gz,解压后进入目录,运行安装即可:
sudo ./install.sh
d、设置环境变量PATH
export ARCH=arm
export CROSS_COMPILE=/usr/local/arm_linux_4.8/bin/arm-nuvoton-linux-uclibceabi-
export PATH=/usr/local/arm_linux_4.8/bin:$PATH
完成后,进入uboot目录测试一下,是否编译通过,如下:
zhy@zhy-TravelMate-P259-G2-MG:~/Desktop/nuc980_env/NUC970_U-Boot_v2016.11$ ls configs/nuc*
configs/nuc970_defconfig           configs/nuc980_defconfig
configs/nuc970_eth2uart_defconfig  configs/nuc980_eth2uart_defconfig
configs/nuc970_tomato_defconfig    configs/nuc980_iot_defconfig
configs/nuc980_chili_defconfig     configs/nuc980_lorag_defconfig
zhy@zhy-TravelMate-P259-G2-MG:~/Desktop/nuc980_env/NUC970_U-Boot_v2016.11$ make nuc980_defconfig
# configuration written to .config
scripts/kconfig/conf  --silentoldconfig Kconfig
  CHK     include/config.h
  CFG     u-boot.cfg
  GEN     include/autoconf.mk
  GEN     include/autoconf.mk.dep
  CFG     spl/u-boot.cfg
  GEN     spl/include/autoconf.mk
  CHK     include/config/uboot.release
  CHK     include/generated/version_autogenerated.h
  CHK     include/generated/timestamp_autogenerated.h
  UPD     include/generated/timestamp_autogenerated.h
  CC      lib/asm-offsets.s
  CHK     include/generated/generic-asm-offsets.h
  CC      arch/arm/lib/asm-offsets.s
  CHK     include/generated/asm-offsets.h
  HOSTCC  tools/envcrc.o
  WRAP    tools/lib/crc32.c
  HOSTCC  tools/lib/crc32.o
  WRAP    tools/common/env_embedded.c
  HOSTCC  tools/common/env_embedded.o
  WRAP    tools/lib/sha1.c
  HOSTCC  tools/lib/sha1.o
  HOSTLD  tools/envcrc
  HOSTCC  tools/gen_eth_addr
  LD      spl/drivers/built-in.o
  LD      spl/dts/built-in.o
  LD      spl/fs/built-in.o
  LDS     spl/u-boot-spl.lds
  LD      spl/u-boot-spl
  OBJCOPY spl/u-boot-spl-nodtb.bin
  COPY    spl/u-boot-spl.bin
  ./scripts/check-config.sh u-boot.cfg \
  ./scripts/config_whitelist.txt . 1>&2
 楼主| zljiu 发表于 2021-8-14 17:18 | 显示全部楼层
(2)在windows下安装虚拟机开发
直接在github或者gitee下载NUC970/NUC980/N9H30 BSP 使用的 VMWare Linux 開發環境,国内用户建议在gitee上下载,地址:
https://gitee.com/OpenNuvoton/NUC970_NUC980_N9H30_VMWare_Linux_develop_environment
下载完成后,解压缩后,用vmware软件打开ubuntu_NUC970_980_Linux目录下的Ubuntu 64-bit_nuvoton.vmx虚拟机文件即可。
登陆名:nuvoton
密码: user
收藏学习  发表于 2023-11-28 00:18
daichaodai 发表于 2021-8-16 12:26 来自手机 | 显示全部楼层
Ubuntu这更新速度也快啊
麻花油条 发表于 2021-8-16 13:15 来自手机 | 显示全部楼层
没用过,有时间研究下
labasi 发表于 2021-9-10 15:25 | 显示全部楼层
对电脑系统有要求吗
paotangsan 发表于 2021-9-10 15:28 | 显示全部楼层
更新速度也实在太快了
renzheshengui 发表于 2021-9-10 15:29 | 显示全部楼层
这个是最新的版本吗
wakayi 发表于 2021-9-10 15:31 | 显示全部楼层
还从来没有用过这个工具啊
wowu 发表于 2021-9-10 15:33 | 显示全部楼层
那种方式更加便捷啊
豌豆爹 发表于 2021-9-17 10:45 来自手机 | 显示全部楼层
对电脑系统有没有限制
灰常时刻 发表于 2021-9-22 17:16 | 显示全部楼层
本人17年刚工作有幸接触了Nuc970的Ubuntu开发环境,那时候好像是14版本。。没想到现在更新到20版本了。真快
AloneKaven 发表于 2023-11-28 10:32 来自手机 | 显示全部楼层
有没有开箱即用的环境啊
蝶弄美人簪 发表于 2025-9-27 15:12 | 显示全部楼层
下载 NUC980 Ubuntu 镜像;2. 烧录至 SD 卡;3. 插入开发板启动;4. 联网后用 apt 安装编译工具链及依赖。
桃乐丝 发表于 2025-10-2 18:03 | 显示全部楼层
在 Ubuntu 20.04 安装 NUC980 开发环境:先安装依赖包(gcc-arm-linux-gnueabihf 等),下载新唐 SDK,解压后配置交叉编译工具链。编译 U-Boot 和内核,生成镜像。安装串口工具(minicom),连接开发板,通过 TF 卡或 USB 烧录镜像,配置网络调试,参考官方文档解决依赖问题。
一点点晚风 发表于 2025-11-3 15:55 | 显示全部楼层
NUC980 Ubuntu20.04 开发环境安装:先安装依赖包(git、make 等),克隆 NUC980 SDK,运行脚本安装交叉编译器;配置环境变量指向编译器路径;编译 uboot 和内核,生成镜像;安装 Qt Creator 并配置交叉编译工具链,即可进行应用开发
