[allegro] allego导入DXF时报错
5926|1
 楼主| jiuqiu 发表于 2021-9-15 13:39 | 显示全部楼层 |阅读模式
#21ic问答#
Reading Layer Conversion File
Reading DXF file...
NOTE: Replacing illegal character * with X in *Model_Space.
NOTE: Replacing illegal character * with X in *Paper_Space.
NOTE: Replacing illegal character * with X in *Paper_Space0.
ERROR: 3D data has been found in this dxf file.
  Most 3D data is not supported by dxf2a.
  For the special case of DXF code 230 = -1.0, ARC, CIRCLE
  and SOLID entities will be mirrored about the Y axis.
ERROR: 3D data (DXF code 30, value = 0.0038) detected on ARC at line 18082
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18086
ERROR: 3D data (DXF code 220, value = 0.0000) detected on ARC at line 18088
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18090
ERROR: 3D data (DXF code 30, value = 0.0010) detected on ARC at line 18152
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18156
ERROR: 3D data (DXF code 220, value = -0.0000) detected on ARC at line 18158
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18160
ERROR: 3D data (DXF code 30, value = 0.0010) detected on ARC at line 18638
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18642
ERROR: 3D data (DXF code 220, value = -0.0000) detected on ARC at line 18644
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18646
ERROR: 3D data (DXF code 30, value = 0.0038) detected on ARC at line 18676
ERROR: 3D data (DXF code 210, value = 0.0000) detected on ARC at line 18680
ERROR: 3D data (DXF code 220, value = 0.0000) detected on ARC at line 18682
ERROR: 3D data (DXF code 230, value = 1.0000) detected on ARC at line 18684
done.
WARNING: Ignoring zero length segment at (451.4700 253.5925)
WARNING: Ignoring zero length segment at (450.5151 257.0325)
WARNING: Ignoring zero length segment at (450.5150 256.6825)
WARNING: Ignoring zero length segment at (450.5147 248.3825)
jjjyufan 发表于 2021-9-15 15:16 | 显示全部楼层
打开 DXF
保留自己需要的,删除 不必要的,
然后全选 ,放到一个图层里面
然后 导入,
