原因找到了:
Before using an instance of a signal, array, parameter, etc., the instance must first be declared. The XST parser scans a Verilog file from beginning to end, so any usage must be preceded by the declaration of that instance.
晕死,XST跟其他综合器不一样.v中必须先声明再使用,真当是.c文件啊
