九齐
1513|3
 楼主| hjs369 发表于 2021-10-18 08:58 | 显示全部楼层 |阅读模式
; Project:       sjjdq
; Author:        hjc
; Version:       V0
; Date:          20210623
;--------------- File Include ---------------------------------------------
;        VDD-|      |-VSS
;R   PB5    -|      |-     PB0  B
;G   PB4    -|      |-     PB1
;K3  PB3    -|RST   |-     PB2  PWM
#include                NY8A051F.H                                                        ; The Header File for NY8A054E
                OUTB    EQU                PORTB
                LED_R        EQU                5
                LED_G        EQU                4
                K                EQU                3
                LED_B        EQU                0
                PWM                EQU                2
                LLED        EQU                1
                FL                EQU         7;七彩速度
;--------------- Variable Definition --------------------------------------
        R_AccBuf                EQU                0x20                        ; Store ACC value
        R_StatusBuf                EQU                0x21                        ; Store Status value
                R_shift_regl        EQU                0x22            ; Map to present state of PortB Data buffer
                NS                EQU        0X23
                MS                EQU        0X24
                S                EQU        0X25
                MIN                EQU        0X26
                H                EQU        0X27
                KV                EQU        0X28
                KS                EQU        0X2A
                EN                EQU        0X2B
                RUN                EQU        0
                ken                EQU        1
                EN1                EQU        2
                DCLL        EQU        3
                MODE_V        EQU        0X2C
                S1                EQU        0X2D
                M_V                EQU        0X2E
                R_V                EQU        0X2F
                G_V                EQU        0X30
                B_V                EQU 0X31
                S2                EQU        0X32
                PW                EQU        0X33
                PWMV        EQU        0X34
                LS                EQU        0X35
                X                EQU        0X36
                Y                EQU        0X37
                VV                EQU        0X38
                LV                EQU        0X39
                XX                EQU        0X3A
                ORG                0x000
                lgoto        V_Main
                ORG                0x008
                lgoto        INT_RET
MV_x:
                MOVIA        FL
                SUBAR        LS,0
                BTRSS        Status,0
                RET
                CLRR                LS
                movR        VV,0
                ADDAR        PCL,1
                LGOTO        M10
                LGOTO        M11
                LGOTO        M12
                LGOTO        M13
                LGOTO        M14
                LGOTO        M15
                LGOTO        M16
                LGOTO        M17
                LGOTO        M18
                LGOTO        M19
                CLRR        MODE_V
                RET
INT_RET:
                movar        R_AccBuf                                                ; Store ACC value
                swapr        R_AccBuf,C_SaveToReg
                movr        STATUS,C_SaveToAcc
                movar        R_StatusBuf
                MOVIA        63
                MOVAR        TMR0
                MOVIA        0
                MOVAR        INTF
                INCR        NS,1
                MOVIA        100
                SUBAR        NS,0
                BTRSS        STATUS,0
                LGOTO        EXIT
                CLRR        NS
                MOVIA        0X02
                XORAR        PORTB,1
                INCR        LS,1
                INCR        MS,1
                MOVIA        100
                SUBAR   MS,0
                btrss        Status,0
                LGOTO        EXIT
                CLRR        MS
                INCR        S1,1
                INCR        S2,1
                INCR        S,1
                MOVIA        60
                SUBAR   S,0
                btrss        Status,0
                LGOTO        EXIT
                CLRR        S
                INCR        MIN,1
                MOVIA        60
                SUBAR   MIN,0
                btrss        Status,0
                LGOTO        EXIT
                CLRR        MIN
                INCR        H,1
                CLRR        MODE_V
                CLRR        M_V
EXIT:
                movr        R_StatusBuf,C_SaveToAcc
                movar        STATUS                               ; Restore STATUS value
                swapr        R_AccBuf,C_SaveToAcc                        ; Restore ACC value
                RETIE
V_Main:
                movia   00001000b
                iost    IOSTB
                movia   11110111b
                MOVAR    BPHCON
                CLRR        EN
                CLRR        MS
                CLRR        S
                CLRR        MODE_V
                CLRR        M_V
                CLRR        VV
                movia        0X00
                MOVAR        portb
WAKUP:
                movia        00100000B
        MOVAR    PCON
        movia        00010101B
        iost    PCON1
                movia        0x00
                SFUN        TMR0
        movia   0xFF
        sfun    TMR1
        movia   00000001B
        movar   INTE
        movia   00000000B
        T0MD
        DISI
L_MainLoop:
                ENI
                Lcall        key1
                LCALL        SLE
                LCALL        LVD_ON
                BTRSC        EN,DCLL
                LGOTO        OFF
                MOVIA        1
                XORAR        M_V,0
                btrsC        Status,2
                LCALL        MV_X
                MOVIA        0
                XORAR        M_V,0
                btrsC        Status,2
                LCALL        OFF_LED
                LCALL        PWM_RUN
                MOVIA        0
                XORAR        MODE_V,0
                BTRSC        STATUS,2
                LGOTO        MODE0
                MOVIA        1
                XORAR        MODE_V,0
                BTRSC        STATUS,2
                LGOTO        MODE1
                MOVIA        2
                XORAR        MODE_V,0
                BTRSC        STATUS,2
                LGOTO        MODE2
                MOVIA        3
                XORAR        MODE_V,0
                BTRSC        STATUS,2
                LGOTO        MODE3
                MOVIA        4
                SUBAR        MODE_V,0
                BTRSC        STATUS,0
                CLRR        MODE_V
                lgoto        L_MainLoop
OFF:
                CLRR        M_V
                CLRR        R_V
                CLRR        G_V
                CLRR        B_V
                CLRR        PW
                CLRR        MODE_V
                CLRR        M_V
                BSR                OUTB,LED_R
                BSR                OUTB,LED_G
                BSR                OUTB,LED_B
                movia   17
        sfun    TMR1
        movia   0
        sfun    PWM1Duty
        movia   00000011B ;
        sfun    T1CR1
        movia   0x00
        sfun    T1CR2
                lgoto        L_MainLoop
OFF_LED:
                CLRR        M_V
                CLRR        R_V
                CLRR        G_V
                CLRR        B_V
                BSR                OUTB,LED_R
                BSR                OUTB,LED_G
                BSR                OUTB,LED_B
                CLRR        PW
                RET
PWM_RUN:
                INCR        PW,1
                MOVIA        100
                SUBAR        PW,0
                BTRSC        STATUS,0
                CLRR        PW
                MOVR        R_V,0
                SUBAR        PW,0
                BTRSS        STATUS,0
                BCR                OUTB,LED_R
                BTRSC        STATUS,0
                BSR                OUTB,LED_R
                MOVR        G_V,0
                SUBAR        PW,0
                BTRSS        STATUS,0
                BCR                OUTB,LED_G
                BTRSC        STATUS,0
                BSR                OUTB,LED_G
                MOVR        B_V,0
                SUBAR        PW,0
                BTRSS        STATUS,0
                BCR                OUTB,LED_B
                BTRSC        STATUS,0
                BSR                OUTB,LED_B
                RET
LVD_ON:
                BTRSC        EN,DCLL
                LGOTO        BC_DCLL
                CLRR        LV
                movia        01010101B
        iost    PCON1
                movia        00100000B
        MOVAR   PCON
        NOP
        NOP
        NOP
        NOP
        NOP
        IOSTR        PCON1
        MOVAR        LV
                BTRSS        LV,6
                BSR                EN,DCLL
                RET
BC_DCLL:
                CLRR        LV
                movia        01011101B
        iost    PCON1
                movia        00100000B
        MOVAR   PCON
        NOP
        NOP
        NOP
        NOP
        NOP
        IOSTR        PCON1
        MOVAR        LV
                BTRSC        LV,6
                BCR                EN,DCLL
                RET
key1:
                incr        ks,1
                btrss        Status,2
                ret
                rlr                kv,1
                bcr                kv,0
                btrss        outb,K
                BSR                KV,0
                movia        0
                xorar        kv,0
                btrsc        Status,2
                BCR                EN,KEN
                movia        0xfE
                xorar        kv,0
                btrsc        Status,2
                Lgoto        KEY_EN
                movia        0xff
                xorar        kv,0
                btrsc        Status,2
                Lgoto        long_k
                movia        0x7f
                xorar        kv,0
                btrss        Status,2
                ret
                CLRR        MS
                CLRR        S
                RET
KEY_EN:
                btrsc        en,ken
                RET
                INCR        MODE_V,1
                CLRR        S2
                CLRR        MIN
                CLRR        H
                BCR                EN,EN1
                MOVIA        1
                XORAR        MODE_V,0
                btrsC        Status,2
                LGOTO        LED_1
                MOVIA        4
                SUBAR        MODE_V,0
                btrsC        Status,0
                CLRR        M_V
                btrsC        Status,0
                CLRR        MODE_V
                ret
LED_1:
                MOVIA        1
                MOVAR        M_V
                RET
LONG_K:
                btrsC        EN,KEN
                RET
                MOVIA        2
                SUBAR   S,0
                btrss        Status,0
                ret
                BSR                EN,KEN
                INCR        M_V,1
                MOVIA        3
                SUBAR        M_V,0
                btrsC        Status,0
                CLRR        M_V
                ret
M10:
                CLRR                R_V
                CLRR                G_V
                CLRR                B_V
                INCR                VV,1
                RET
M11:
                INCR                R_V,1
                MOVIA                100
                SUBAR                R_V,0
                btrsC                Status,0
                INCR                VV,1
                RET
M12:
                INCR                G_V,1
                MOVIA                100
                SUBAR                G_V,0
                btrsC                Status,0
                INCR                VV,1
                RET
M13:
                DECR                R_V,1
                MOVIA                1
                SUBAR                R_V,0
                btrss                Status,0
                INCR                VV,1
                RET
M14:
                INCR                B_V,1
                MOVIA                100
                SUBAR                B_V,0
                btrsC                Status,0
                INCR                VV,1
                RET
M15:
                DECR                G_V,1
                MOVIA                1
                SUBAR                G_V,0
                btrsS                Status,0
                INCR                VV,1
                RET
M16:
                INCR                R_V,1
                MOVIA                100
                SUBAR                R_V,0
                btrsC                Status,0
                INCR                VV,1
                RET
M17:
                DECR                B_V,1
                MOVIA                1
                SUBAR                B_V,0
                btrss                Status,0
                INCR                VV,1
                RET
M18:
                INCR                G_V,1
                INCR                B_V,1
                MOVIA                100
                SUBAR                B_V,0
                btrsC                Status,0
                INCR                VV,1
                RET
M19:
                DECR                B_V,1
                DECR                G_V,1
                MOVIA                1
                SUBAR                B_V,0
                btrsC                Status,0
                RET
                MOVIA                 1
                MOVAR                VV
                RET
MODE0:
                LCALL                OFF_PWM
                LGOTO                L_MainLoop
MODE1:
                BTRSS        EN,EN1
                LCALL        ON_PWM30
                LGOTO                L_MainLoop
MODE2:
                BTRSS        EN,EN1
                LCALL        PWM_ON
                LGOTO                L_MainLoop
MODE3:
                MOVIA                0
                XORAR                S2,0
                btrsC                Status,2
                LCALL                PWM_ON
                MOVIA                5
                XORAR                S2,0
                btrsC                Status,2
                LCALL                OFF_PWM
                MOVIA                11
                SUBAR                S2,0
                btrsC                Status,0
                CLRR                S2
                LGOTO                L_MainLoop
OFF_PWM:
                movia   36
        sfun    TMR1
        movia   0
        sfun    PWM1Duty
        movia   00000011B ;
        sfun    T1CR1
        movia   0x00
        sfun    T1CR2
        BCR                OUTB,PWM
        INCR        S2,1
                RET
ON_PWM30:;P62
                movia   36
        sfun    TMR1
        movia   7
        sfun    PWM1Duty
        BSR                EN,EN1
        movia   10000011B
        sfun    T1CR1
        movia   00001000B
        sfun    T1CR2
        INCR        S2,1
                RET
PWM_ON:
                BSR                EN,EN1
                INCR        S2,1
                movia   36
        sfun    TMR1
        movia   18
        sfun    PWM1Duty
        movia   10000011B ;
        sfun    T1CR1
        movia   00001000B
        sfun    T1CR2
                RET
SLE:
                MOVIA        0
                XORAR        KV,0
                btrsS        Status,2
                RET
                MOVIA        0
                XORAR        MODE_V,0
                btrsS        Status,2
                RET
                MOVIA        0
                XORAR        M_V,0
                btrsS        Status,2
                RET
                LCALL        OFF_LED
                LCALL        OFF_PWM
        movia   0X02
        movar   INTE                         ; Enable PortB input change interrupt
                   movia   0x00
        movar   INTF
        clrwdt                ; Clear WatchDog
                movia        00001000B
                MOVAR        BWUCON
                movia        00000000B
        iost    PCON1
        BSR                KV,0
        movr    Pr_PB_Data,C_SaveToReg
                SLEEP
                LGOTO        WAKUP
end
tyw 发表于 2021-10-18 09:06 | 显示全部楼层
 楼主| hjs369 发表于 2022-4-2 10:24 | 显示全部楼层
可惜下载不了
tyw
去油香收  发表于 2022-4-2 10:55
