问题描述
问题复现平台: STM324xG-Eval
例程路径:
STM32Cube_FW_F4_V1.15.0\Projects\STM324xG_EVAL\Applications\USB_Device\CDC_Standalone
在对 CDC 例程了解后, 参考已有的 UART 应用, 新增了一路 UART。 对应初始化程序如下所示。 其中
USARTx 为例程原有部分,而 USARTy 为新增的一路 UART 初始化部分。
- void HAL_UART_MspInit(UART_HandleTypeDef *huart)
- static DMA_HandleTypeDef hdma_tx;
- GPIO_InitTypeDef GPIO_InitStruct;
- if(huart->Instance == USARTx )
- /*##-1- Enable peripherals and GPIO Clocks #################################*/
- /* Enable GPIO clock */
- USARTx_TX_GPIO_CLK_ENABLE();
- USARTx_RX_GPIO_CLK_ENABLE();
- /* Enable USARTx clock */
- USARTx_CLK_ENABLE();
- /* Enable DMAx clock */
- DMAx_CLK_ENABLE();
- /*##-2- Configure peripheral GPIO ##########################################*/
- /* UART TX GPIO pin configuration */
- GPIO_InitStruct.Pin = USARTx_TX_PIN;
- GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FAST;
- GPIO_InitStruct.Alternate = USARTx_TX_AF;
- HAL_GPIO_Init(USARTx_TX_GPIO_PORT, &GPIO_InitStruct);
- /* UART RX GPIO pin configuration */
- GPIO_InitStruct.Pin = USARTx_RX_PIN;
- GPIO_InitStruct.Alternate = USARTx_RX_AF;
- HAL_GPIO_Init(USARTx_RX_GPIO_PORT, &GPIO_InitStruct);
- /*##-3- Configure the NVIC for UART ########################################*/
- HAL_NVIC_SetPriority(USARTx_IRQn, 5, 0);
- HAL_NVIC_EnableIRQ(USARTx_IRQn);
- /*##-4- Configure the DMA streams ##########################################*/
- /* Configure the DMA handler for Transmission process */
- hdma_tx.Instance = USARTx_TX_DMA_STREAM;
- hdma_tx.Init.Channel = USARTx_TX_DMA_CHANNEL;
- hdma_tx.Init.Direction = DMA_MEMORY_TO_PERIPH;
- hdma_tx.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_tx.Init.MemInc = DMA_MINC_ENABLE;
- hdma_tx.Init.PeriphDataAlignment = DMA_PDATAALIGN_BYTE;
- hdma_tx.Init.MemDataAlignment = DMA_MDATAALIGN_BYTE;
- hdma_tx.Init.Mode = DMA_NORMAL;
- hdma_tx.Init.Priority = DMA_PRIORITY_LOW;
- hdma_tx.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
- hdma_tx.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_FULL;
- hdma_tx.Init.MemBurst = DMA_MBURST_INC4;
- hdma_tx.Init.PeriphBurst = DMA_PBURST_INC4;
- HAL_DMA_Init(&hdma_tx);
- /* Associate the initialized DMA handle to the UART handle */
- __HAL_LINKDMA(huart, hdmatx, hdma_tx);
- /*##-5- Configure the NVIC for DMA #########################################*/
- /* NVIC configuration for DMA transfer complete interrupt (USARTx_TX) */
- HAL_NVIC_SetPriority(USARTx_DMA_TX_IRQn, 6, 0);
- HAL_NVIC_EnableIRQ(USARTx_DMA_TX_IRQn);
- if(huart->Instance == USARTy )
- USARTy_TX_GPIO_CLK_ENABLE();
- USARTy_RX_GPIO_CLK_ENABLE();
- USARTy_CLK_ENABLE();
- DMAy_CLK_ENABLE();
- GPIO_InitStruct.Pin = USARTy_TX_PIN;
- GPIO_InitStruct.Alternate = USARTy_TX_AF;
- HAL_GPIO_Init(USARTy_TX_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = USARTy_RX_PIN;
- GPIO_InitStruct.Alternate = USARTy_RX_AF;
- HAL_GPIO_Init(USARTy_RX_GPIO_PORT, &GPIO_InitStruct);
- HAL_NVIC_SetPriority(USARTy_IRQn, 7, 0);
- HAL_NVIC_EnableIRQ(USARTy_IRQn);
- hdma_tx.Instance = USARTy_TX_DMA_STREAM;
- hdma_tx.Init.Channel = USARTy_TX_DMA_CHANNEL;
- HAL_NVIC_SetPriority(USARTy_DMA_TX_IRQn, 8, 0);
- HAL_NVIC_EnableIRQ(USARTy_DMA_TX_IRQn);
在
之前的 UART 发送和接收处, 同样新增了一路 UART 的发送和接收。 为了方便描述, 这里不对应用
层面进行描述。 而是直接在例程中, 时钟配置后执行下述语句, 复现问题。
- #ifdef USART_X_INIT_ENABLE
- UartHandle.Instance = USARTx;
- if(HAL_UART_Init(&UartHandle) != HAL_OK)
- if(HAL_UART_Receive_IT(&UartHandle, (uint8_t *)UserTxBuffer, 1) != HAL_OK)
- #endif // USART_X_INIT_ENABLE
- #ifdef USART_Y_INIT_ENABLE
- UartHandley.Instance = USARTy;
- if(HAL_UART_Init(&UartHandley) != HAL_OK)
- if(HAL_UART_Receive_IT(&UartHandley, (uint8_t *)UserTxBuffer, 1) != HAL_OK)
- #endif //USART_Y_INIT_ENABLE
- while(1)
- #ifdef USART_X_ENABLE
- HAL_UART_Transmit_DMA(&UartHandle, “UARTx Test”, 11);
- #endif //USART_X_ENABLE
- #ifdef USART_Y_ENABLE
- HAL_UART_Transmit_DMA(&UartHandley,”UARTy Test”, 11);
- #endif // USART_Y_ENABLE
- HAL_Delay(100);
结果如下表。
