[技术支持] 编译通不过
4573|1
 楼主| 999stone999 发表于 2021-11-11 16:33 | 显示全部楼层 |阅读模式
程序中的这句:INTEDG = 0;编译报错:---------------- Project: test_program_V01 ----------------
compiling inital.c...
compiling main.c...
main.c:81: error 20: Undefined identifier 'OPTIONbits'
main.c:81: error 25: Structure/Union expected left of '.->'
"test_program_V01" - 2 Error(s), 0 Warning(s).
2021-11-11 16:27:42 Build fail.
HC16P015B0的库文件有声明:
#define OPTION_ADDR             0x0041
//        OPTION Bits
extern __at(0x0041) __sfr OPTION;
typedef struct
  unsigned PS0                        : 1;
  unsigned PS1                        : 1;
  unsigned PS2                        : 1;
  unsigned PSA                        : 1;
  unsigned T0SE                 : 1;
  unsigned T0CS                        : 1;
  unsigned INTEDG               : 1;
  unsigned                                : 1;
  } __OPTIONbits_t;
extern __at(0x0041) volatile __OPTIONbits_t OPTIONbits;
#define _PS0                    0x01
#define _PS1                    0x02
#define _PS2                    0x04
#define _PSA                    0x08
#define _T0SE                   0x10
#define _T0CS                   0x20
#define _INTEDG                 0x40
请问问题出在什么地方?
yangxiaor520 发表于 2021-11-11 20:51 来自手机 | 显示全部楼层
没有定义指针
