C6713烧写求助,有CODE_SECTION
2891|3
 楼主| haidixibahe 发表于 2012-3-21 00:05 | 显示全部楼层 |阅读模式
我打算把程序的一部分放入CE0口的SDRAM中运行,就用了#pragma CODE_SECTION(counting,".xxxsect")
然后在.cmd文件中将.xxxsect段放入SDRAM中,编译链接运行正确,但烧写时却总是boot失败,求各位高手指导,不胜感激!!
烧写用的cmd文件如下:
MEMORY
{ BOOTRAM: o = 00000000h l= 00000400h
IRAM: o = 00000400h l = 0000FA00h
SDRAM: o = 80000000h l = 00010000h
FLASH_BOOT: o = 0x90000000 l = 00000400h
FLASH_REST: o = 0x90000400 l = 0001fc00h
SECTIONS
{ .boot_load : load =0x90000000, run = BOOTRAM
/* Initialized User Code Section */
.text : load = FLASH_REST, run = IRAM
LOAD_START(_text_ld_start),
RUN_START(_text_rn_start),
SIZE(_text_size)
.xxxsect : load = FLASH_REST, run = SDRAM
LOAD_START(_xxxsect_ld_start),
RUN_START(_xxxsect_rn_start),
SIZE(_xxxsect_size)
.cinit > FLASH_REST
.const > IRAM
.stack > IRAM
.bss > IRAM
.data > IRAM
.far > IRAM
.switch > IRAM
.sysmem > IRAM
.cio > IRAM
someonewho 发表于 2012-3-21 00:19 | 显示全部楼层
帮你顶顶
eagle200203 发表于 2013-3-11 13:52 | 显示全部楼层
楼主这个问题解决了吗?
我也想把程序放在外部SDRAM不知道怎么做啊!
