返回列表 发新帖我要提问本帖赏金: 10.00元(功能说明)
[其它] 新库V2 中断优先级配置问题
2902|1
 楼主| wxp443 发表于 2021-12-24 14:13 | 显示全部楼层 |阅读模式
typedef enum
  NVIC_PRIORITY_GROUP_0                  = ((uint32_t)0x700), /*!< 0 bits for preemption priority, 4 bits for subpriority */
  NVIC_PRIORITY_GROUP_1                  = ((uint32_t)0x600), /*!< 1 bits for preemption priority, 3 bits for subpriority */
  NVIC_PRIORITY_GROUP_2                  = ((uint32_t)0x500), /*!< 2 bits for preemption priority, 2 bits for subpriority */
  NVIC_PRIORITY_GROUP_3                  = ((uint32_t)0x400), /*!< 3 bits for preemption priority, 1 bits for subpriority */
  NVIC_PRIORITY_GROUP_4                  = ((uint32_t)0x300)  /*!< 4 bits for preemption priority, 0 bits for subpriority */
} nvic_priority_group_type;
  * @brief  config nvic priority group
  * @param  priority_group
  *         this parameter can be one of the following values:
  *         - NVIC_PRIORITY_GROUP_0
  *         - NVIC_PRIORITY_GROUP_1
  *         - NVIC_PRIORITY_GROUP_2
  *         - NVIC_PRIORITY_GROUP_3
  *         - NVIC_PRIORITY_GROUP_4
  * @retval none
void nvic_priority_group_config(nvic_priority_group_type priority_group)
  /* set the prigroup[10:8] bits according to nvic_prioritygroup value */
  NVIC_SetPriorityGrouping(priority_group);
}不应该是
typedef enum
  NVIC_PRIORITY_GROUP_0                  = ((uint32_t)0x7), /*!< 0 bits for preemption priority, 4 bits for subpriority */
  NVIC_PRIORITY_GROUP_1                  = ((uint32_t)0x6), /*!< 1 bits for preemption priority, 3 bits for subpriority */
  NVIC_PRIORITY_GROUP_2                  = ((uint32_t)0x5), /*!< 2 bits for preemption priority, 2 bits for subpriority */
  NVIC_PRIORITY_GROUP_3                  = ((uint32_t)0x4), /*!< 3 bits for preemption priority, 1 bits for subpriority */
  NVIC_PRIORITY_GROUP_4                  = ((uint32_t)0x3)  /*!< 4 bits for preemption priority, 0 bits for subpriority */
打赏榜单
ArterySW 打赏了 10.00 元 2021-12-27
理由:反馈BSP问题属实。
hoop 发表于 2021-12-24 16:25 | 显示全部楼层
谢谢您的细心检查反馈。
好像这个部分确实存在问题,我们再进一步确认及修改。
