[DemoCode下载] [NUC1262] Using CRC to Verify Code Integrity
769|0
 楼主| 奔跑的牛 发表于 2021-12-28 15:51 | 显示全部楼层 |阅读模式
  • Application: This example code uses NUC1262 CRC for self-verification of code integrity.
  • BSP Version: NUC1262_Series_BSP_CMSIS_V3.00.001
  • Hardware: NuMaker-NUC1262SE V1.0
This example code uses NUC1262 CRC to perform self-verification of code integrity.
Ensuring the integrity of the execution code is one of the security conditions that the terminal product should have. This can avoid abnormal results and crashes caused by incorrect code during the execution of the product, or data theft due to code tampering.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 1022174557
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
