[DemoCode下载] [M258] Generating PDF File in USB Disk
467|0
 楼主| 奔跑的牛 发表于 2022-1-17 15:01 | 显示全部楼层 |阅读模式
TI, ge, pd
  • Application: This sample code is a demonstration of how to generate the PDF by accesses the FAT file system on USB DISK using M258.
  • BSP Version: M251/M252/M254/M256/M258 BSP CMSIS V3.01.002
  • Hardware: NuMaker-M258KE Ver1.1
This sample code uses M258 to connects to the computer via a USB port to be implemented as a mass storage class device, and accesses the FAT file system on USB DISK. It also demonstrates how to write data to a PDF file on the USB DISK. The user can use the microcontroller as a general external USB flash drive to read PDF file on a personal computer.
Please note that the sample code is also applicable to M252 series.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0909133810
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
