[PCB设计资料] Wallys Qualcomm Atheros IPQ8072A AR Quad Core CPU wifi 6e
1165|0
 楼主| wirelesswifi6 发表于 2022-2-21 14:06 | 显示全部楼层 |阅读模式
DR8072 V01
Support WiFi 6E Card
IPQ8072 4x4 2.4G & 5G 802.11ax
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
BY Wallys Communications (Suzhou) Co LTD
