我叙述一下目前的困难吧
我现在是用STM32和一个电容触摸屏芯片做毕业设计,才刚开始接触STM32的
电容屏IC有i2c接口,我拿它和stm32的i2c口相连,以接收坐标值。
我用的是普遍的i2c1初始化代码,即
void I2C_GPIO_Config(void)
/* 使能与 I2C1 有关的时钟 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
/* PB6-I2C1_SCL、PB7-I2C1_SDA*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD; // 开漏输出
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; // INT·下拉输入
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // RESET·推挽输出
void I2C_Mode_Configu(void)
I2C_InitTypeDef I2C_InitStructure;
/* I2C 配置 */
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = I2C1_SLAVE_ADDRESS;
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
/* 使能 I2C1 */
I2C_Cmd(I2C1, ENABLE);
/* I2C1 初始化 */
I2C_Init(I2C1, &I2C_InitStructure);
/*允许1字节1应答模式*/
I2C_AcknowledgeConfig(I2C1, DISABLE);
void I2C1_init(void)
I2C_GPIO_Config();
I2C_Mode_Configu();
但执行I2C1_init(void)完了后,再执行while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));就会卡死在这个地方,有时候摆动一下硬件就会走出循环,怎么回事啊?初始化结束后busy位自动置位的吗?
急,请各位指教 |
