[PCB设计资料] wallys wifi6 AP Qualcomm IPQ6010 2T2R 2.5G ETH port support 5G celluar Modem
1133|0
 楼主| wirelesswifi6 发表于 2022-3-17 10:29 | 显示全部楼层 |阅读模式
Description
DR-AP6018-A  is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna
■  5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■  Dimension: 192x 123 x 44 mm
■  Aluminum alloy material
■ Two Version :
DR-AP6018-AB : Color Black
DR-AP6018-AO: Color Orange
■  Support Wallys DR6018
DR-AP6018-A
Indoor Aluminium alloy material
IPQ6018 support OpenWrt 2.4/5G dual bands
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
    SD Card Slot
    1x SD Card Slot
    USB /header
    1x USB 2.0 Port
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V power supply
    LED header
    FFC/FPC Connector
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    BluetoothCSR8811 BLE 4.2
    Nor Flash
    32MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    185mm x 116mm
      Wallys Communications (Suzhou) Co LTD
      EMAIL:sales@wallystech.com
      WEB:https://www.wallystech.com/
      wifi6 router
      wifi 6E
      Wi-Fi 6E
      Wi-Fi 6
      WiFi 6
      802.11ax
      802.11ac
      wireless
      QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024
      IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018/IPQ8074
      IPQ4029/IPQ4019
      Dipole Antenna
      panel antenna
      Smart antenna
      omni  antenna
      Wireless Access Point
