Lattice's ispDOWNLOAD® Cable products are the hardware connection for in-system programming of all Lattice devices. After completion of the logic design and creation of a programming file with the ispLEVERTM or PAC-DesignerTM software, Lattice's ispVMTM System Software is used to control the programming of devices directly on the PC board. No additional components are required to program a device.
Lattice's programming cables connect to either USB or PC Parallel ports, and use fly-wire connectors to the target system board for maximum flexibility. The cables also include adapters for easy interface to widely used 1x8 and 2x5 header configurations. The cables support programming of all Lattice devices with 1.2V, 1.8V, 2.5V, 3.3V, 5.0V core voltages. Both cables are also RoHS Compliant.
