QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024/QCA9531 Qualcomm-Atheros QCA9880 chipset 2.4GHz max 26dBm & 5GHz max 25dBm output power IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n 3x3 MIMO Technology, up to 1.3Gbps Mini PCI Express edge connector RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC) Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards Supports Dynamic Frequency Selection (DFS) FCC,CE and IC Certification
Symbol
| Parameter
| Chipset
| QCA9880
| Host Interface
| Mini PCI Express 1.1 Standard
| Antenna Connector
| 3 x UF.L
| Frequency Range
| 2.4GHz: 2.412GHz to 2.472GHz
5GHz: 4.920GHz to 5.825GHz
| Operating Voltage
| 3.3V DC
| Power Consumption
| 5W(Max)
| Modulation Techniques
| OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
| Environmental Temperature
| Operating: -40°C to 70°C, Storage: -40°C to 90°C
| Environmental Humidity, non-condensing
| Operating: 5% to 95%, Storage: Max. 90%
| ROHS Compliance
| YES
| Dimensions (W×H×D)
| 30.0mm × 50.9mm × 3.2mm
Operating Mode | Data Rate | TX Power | Tolerance | 1 Chain | 3 Chains | 2.4 GHz 802.11b | 1Mbps | 20dBm | 25dBm | ±2dB | 2Mbps | 20dBm | 25dBm | ±2dB | 5.5Mbps | 20dBm | 25dBm | ±2dB | 11Mbps | 20dBm | 25dBm | ±2dB | 2.4 GHz 802.11g | 6Mbps | 21dBm | 26dBm | ±2dB | 9Mbps | 21dBm | 26dBm | ±2dB | 12Mbps | 21dBm | 26dBm | ±2dB | 18Mbps | 21dBm | 26dBm | ±2dB | 24Mbps | 21dBm | 26dBm | ±2dB | 36Mbps | 20dBm | 25dBm | ±2dB | 48Mbps | 19dBm | 24dBm | ±2dB | 54Mbps | 19dBm | 24dBm | ±2dB | 2.4 GHz 802.11n HT20 | MCS0 | 21dBm | 26dBm | ±2dB | MCS1 | 21dBm | 26dBm | ±2dB | MCS2 | 21dBm | 26dBm | ±2dB | MCS3 | 20dBm | 25dBm | ±2dB | MCS4 | 20dBm | 25dBm | ±2dB | MCS5 | 20dBm | 25dBm | ±2dB | MCS6 | 19dBm | 24dBm | ±2dB | MCS7 | 18dBm | 23dBm | ±2dB | 2.4 GHz 802.11n HT40 | MCS0 | 21dBm | 26dBm | ±2dB | MCS1 | 21dBm | 26dBm | ±2dB | MCS2 | 21dBm | 26dBm | ±2dB | MCS3 | 20dBm | 25dBm | ±2dB | MCS4 | 20dBm | 25dBm | ±2dB | MCS5 | 20dBm | 25dBm | ±2dB | MCS6 | 19dBm | 24dBm | ±2dB | MCS7 | 18dBm | 23dBm | ±2dB |
Operating Mode | Data Rate | RX Sensitivity | Tolerance | 2.4 GHz 802.11b | 1Mbps | -95dBm | ±2dB | 2Mbps | -94dBm | ±2dB | 5.5Mbps | -92dBm | ±2dB | 11Mbps | -90dBm | ±2dB | 2.4 GHz 802.11g | 6Mbps | -94dBm | ±2dB | 9Mbps | -93dBm | ±2dB | 12Mbps | -92dBm | ±2dB | 18Mbps | -90dBm | ±2dB | 24Mbps | -88dBm | ±2dB | 36Mbps | -85dBm | ±2dB | 48Mbps | -81dBm | ±2dB | 54Mbps | -80dBm | ±2dB | 2.4 GHz 802.11n HT20 | MCS0 | -93dBm | ±2dB | MCS1 | -91dBm | ±2dB | MCS2 | -89dBm | ±2dB | MCS3 | -84dBm | ±2dB | MCS4 | -83dBm | ±2dB | MCS5 | -78dBm | ±2dB | MCS6 | -78dBm | ±2dB | MCS7 | -76dBm | ±2dB | 2.4 GHz 802.11n HT40 | MCS0 | -92dBm | ±2dB | MCS1 | -88dBm | ±2dB | MCS2 | -85dBm | ±2dB | MCS3 | -82dBm | ±2dB | MCS4 | -79dBm | ±2dB | MCS5 | -75dBm | ±2dB | MCS6 | -75dBm | ±2dB | MCS7 | -73dBm | ±2dB |
Operating Mode | Data Rate | TX Power | Tolerance | 1 Chain | 3 Chains | 5 GHz
802.11a | 6Mbps | 20dBm | 25dBm | ±2dB | 9Mbps | 20dBm | 25dBm | ±2dB | 12Mbps | 20dBm | 25dBm | ±2dB | 18Mbps | 20dBm | 25dBm | ±2dB | 24Mbps | 20dBm | 25dBm | ±2dB | 36Mbps | 18dBm | 23dBm | ±2dB | 48Mbps | 16dBm | 21dBm | ±2dB | 54Mbps | 15dBm | 20dBm | ±2dB | 5 GHz
802.11n/ac HT20 | MCS0 | 19dBm | 24dBm | ±2dB | MCS1 | 19dBm | 24dBm | ±2dB | MCS2 | 19dBm | 24dBm | ±2dB | MCS3 | 18dBm | 23dBm | ±2dB | MCS4 | 18dBm | 23dBm | ±2dB | MCS5 | 17dBm | 22dBm | ±2dB | MCS6 | 16dBm | 21dBm | ±2dB | MCS7 | 16dBm | 21dBm | ±2dB | MCS8 | 15dBm | 20dBm | ±2dB | 5 GHz
802.11n/ac HT40 | MCS0 | 18dBm | 23dBm | ±2dB | MCS1 | 18dBm | 23dBm | ±2dB | MCS2 | 18dBm | 23dBm | ±2dB | MCS3 | 17dBm | 22dBm | ±2dB | MCS4 | 17dBm | 22dBm | ±2dB | MCS5 | 16dBm | 21dBm | ±2dB | MCS6 | 16dBm | 21dBm | ±2dB | MCS7 | 16dBm | 21dBm | ±2dB | MCS8 | 15dBm | 20dBm | ±2dB | MCS9 | 15dBm | 20dBm | ±2dB | 5 GHz
802.11n/ac HT80 | MCS0 | 18dBm | 23dBm | ±2dB | MCS1 | 18dBm | 23dBm | ±2dB | MCS2 | 18dBm | 23dBm | ±2dB | MCS3 | 17dBm | 22dBm | ±2dB | MCS4 | 17dBm | 22dBm | ±2dB | MCS5 | 16dBm | 21dBm | ±2dB | MCS6 | 16dBm | 21dBm | ±2dB | MCS7 | 15dBm | 20dBm | ±2dB | MCS8 | 15dBm | 20dBm | ±2dB | MCS9 | 15dBm | 20dBm | ±2dB |
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult. EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/
