#每日话题# #申请原创# #技术资源# 广芯BCT8933替换艾为AW8733应用:手机,MP3,PMP,GPS,数码相框等多种产品;
The BCT8933 is a powerful Class-T audio amplifier. Using our unique Digital Power Modulation (DPM) audio algorithm, effectively eliminate audio noise, increase signal Dynamic range which will greatly improve sound quality and volume.
The BCT8933 includes a built-in 2X charge pump converter which generates a 6.3V supply voltage. This can provide a wider audio signal output range than a Traditional class D amplifier directly connected to the battery. The BCT8933 can provide 2W output power (10% THD+N) into 8Ω load from the 4.2V battery voltage.
The BCT8933 features the DPM function, which adjusts the system gain and output power automatically, protects the speaker from damage at high power levels and brings the most comfortable listening experience to the customers.
The BCT8933 is available in a small 3mm×3mm 20-Pin QFN Package. It is specified over the extended -40℃ to +85℃ temperature range.
APPLICATIONS
Smart phone
Portable Audio Devices
Mini Speakers
FEATURES
Digital Power Modulation audio algorithm
2.0W into 8Ω at 4.2V(10% THD+N)
Ultra-Low THD+N: 0.03%
4 Mode selected by one-wire pulse
4 Selectable Gain,12dB,16dB,24dB, 27.5dB
Short-Circuit and Thermal Protection
±8KV HBM ESD
Small 3mm×3mm 20-Pin TQFN Package
应用:手机,MP3,PMP,GPS,数码相框等多种产品,需要技术支持和更多详细资料,可以私信留言,合作共赢,共创辉煌,互相学习共同进步,用芯成就专业,专业承载重托。龙;17727812840 |
