[PCB] 2-4GHz-and-5GHZ-dual-band-omni-antenna-6dBi-N-connector-outdoor
936|0
 楼主| wirelesswifi6 发表于 2022-4-26 11:20 | 显示全部楼层 |阅读模式
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024/QCA9531
ElectricalProperties :
Frequency Range:2.4~2.5&5.15~5.85GHz
Impedance:50Ω
VSWR:2.0 Max (≤2.0)
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable
Connector:N-type PLUG
Antenna CAP:ABS
OperatingTemp:-40℃~+65℃
Storage Temp:-40℃~+75℃
CableTemp:<+250℃
    Product Name
    DRA25
    Frequency Range
    Impedance
    50Ω
    VSWR
    2.0 Max (≤2.0)
    Gain(peak)
    6±0.5dBi
    Polarization
    Linear; Vertical
    Cable
    RG-141 Cable
    Connector
    N-type PLUG
    Antenna CAP
    ABS
    OperatingTemp
    -40℃~+65℃
    Storage Temp
    -40℃~+75℃
    CableTemp
    <+250℃
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, mainly for export market, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
