wifi6 IPQ6018/IPQ6010 5G-celluar-Modem 802.11ax QCN9074 WiFi 6E Card-wallys
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Parameter
| Rating | Unit | Supply Voltage
| 24V~48 | V | Operating Temperature Range
| -40 to +70 | ºC | Storage Temperature Range
| -45 to +105 | ºC | Operating Humidity Range
| 5 to +95 (non-condensing) | % |
Symbol
| Parameter | CPU
| CPU Frequency
| Quad-core ARM 64 bit A53 @1.8 GHz processor
| System Memory
| 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
| Ethernet Port
| 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
| | SFP Port | 1x SFP port | NGFF Slot
| M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
| SD Card Slot
| 1x SD Card Slot
| USB /header
| 1x USB 2.0 Port
| POE
| 24V~48V passive POE/Active POE(Suport 802.3bt)
| DC Jack
| 24V power supply
| LED header
| FFC/FPC Connector
| Serial Port
| 1x Serial Port 4 Pin Connector
| Wireless
| On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
| | Bluetooth | CSR8811 BLE 4.2 | Nor Flash
| 32MB
| Nand Flash
| 256MB
| DDR
| 256MB~512MB
| Dimension
| 185mm x 116mm
Boot_Config Switch1(S7) | Boot_Config | Boot up InterfaceSelect | S7A | S7B | S7C |
| 0 | 0 | 0 | SPI NOR. (Default) | 0 | 0 | 1 | eMMC | 0 | 1 | 0 | QPIC, Parallel NAND | 0 | 1 | 1 | USB2.0 | 1 | 0 | 0 | SPI-NOR-GPT | S7D | Boot up InterfaceSelect | 0 | Boot from code ram.(Default) | 1 | Boot from ROM | Boot_Config Switch2(S9) | Boot_Config | Boot up InterfaceSelect | 0 | No auth.(Default) | 1 | Auth is required |
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult. EMAIL:sales@wallystech.com
