[APM32F1] 在调试过程中,通过DBGMCU控制Timer是否输出PWM
866|0
 楼主| zjh20070904 发表于 2022-5-14 09:05 | 显示全部楼层 |阅读模式
#技术资源#
MCU进入debug模式、程序未运行时,可通过DBGMCU控制MCU的模块是否工作,具体细节见参考手册,以下是以TImer1为例,记录了操作方法及现象。
1 通过驱动库中的库函数实现1.1 包含头文件 apm32f10x_dbgmcu.h,编写代码如下:
1.3 运行观察记录现象
默认情况
关键操作
波形
即使程序未运行,Timer依然输出PWM
执行DBGMCU_Enable(DBGMCU_TMR1_STOP)
关键操作
波形
PWM波形
执行DBGMCU_Disable(DBGMCU_TMR1_STOP)
关键操作
波形
Timer输出PWM
2.4 记录现象如下
清除TMR1_STS
关键操作
波形
1 TMR1_STS
关键操作
置位TMR1_STS,不运行程序、直接采集波形
波形
PWM波形
3 参考代码
#include "main.h"
#include "apm32f10x_dbgmcu.h"
volatile uint32_t tick = 0;
int main(void)
   GPIO_Config_T GPIO_ConfigStruct;
   TMR_BaseConfig_T TMR_TimeBaseStruct;
   TMR_OCConfig_T OCcongigStruct;
     uint32_tpclk1_value=0,pclk2_value;
   RCM_ReadPCLKFreq(&pclk1_value,&pclk2_value);
   RCM_EnableAPB2PeriphClock((RCM_APB2_PERIPH_T)(RCM_APB2_PERIPH_GPIOA |RCM_APB2_PERIPH_TMR1 | RCM_APB2_PERIPH_GPIOB));
   GPIO_ConfigStruct.pin = GPIO_PIN_13;
   GPIO_ConfigStruct.mode = GPIO_MODE_AF_PP;
   GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
   GPIO_Config(GPIOB, &GPIO_ConfigStruct);
   GPIO_ConfigStruct.pin = GPIO_PIN_8;
   GPIO_Config(GPIOA, &GPIO_ConfigStruct);
   TMR_TimeBaseStruct.clockDivision = TMR_CLOCK_DIV_1;
   TMR_TimeBaseStruct.countMode = TMR_COUNTER_MODE_UP;
  TMR_TimeBaseStruct.division =720-1;
   TMR_TimeBaseStruct.period = 10-1;
   TMR_ConfigTimeBase(TMR1, &TMR_TimeBaseStruct);
   OCcongigStruct.idleState = TMR_OC_IDLE_STATE_RESET;
   OCcongigStruct.mode = TMR_OC_MODE_PWM1;
   OCcongigStruct.nIdleState = TMR_OC_NIDLE_STATE_RESET;
   OCcongigStruct.nPolarity = TMR_OC_NPOLARITY_HIGH;
   OCcongigStruct.outputNState = TMR_OC_NSTATE_ENABLE;
   OCcongigStruct.outputState = TMR_OC_STATE_ENABLE;
   OCcongigStruct.polarity = TMR_OC_POLARITY_HIGH;
   OCcongigStruct.pulse = 3;
   TMR_ConfigOC1(TMR1, &OCcongigStruct);
   TMR_ConfigOC1Preload(TMR1, TMR_OC_PRELOAD_ENABLE);
    TMR_EnableAutoReload(TMR1);
   TMR_Enable(TMR1);
     TMR_EnablePWMOutputs(TMR1);
     DBGMCU_Enable(DBGMCU_TMR1_STOP);
     DBGMCU_Disable(DBGMCU_TMR1_STOP);
    while(1)
认证:极海半导体
29
