[PCB] Linux PCIe adapter for miniPCIe M.2-WiFi modules-wallys
1215|0
 楼主| wirelesswifi6 发表于 2022-5-23 11:57 | 显示全部楼层 |阅读模式
QCN9074/QCN9024/QCN9072/QCA9882/QCA9880/QCN6024/QCA9531
AX200NGW/IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018/IPQ8074/IPQ8072A/IPQ4029/IPQ4019/AR9344
Features
Support 4pcs Mini PCIE cards or 4 pcs M.2 cards
RoHS compliance ensure a high level protection of human health and the
environment from risks that can be posed by chemicals
Product Description
DR2G41 is an adapter card with four MiniPCIe and four M.2 slots. It can be used in a PC with a PCIe slot. Use this new adapter to expand your connectivity and upgrade y**ice to use the latest miniPCIe and m.2 interface cards. Each comes with both low and regular profile brackets.
Brackets include holes for mounting SMA connectors, or for using as cable exit holes.
    Specifications
    Parameter
    Rating
    Unit
    Input voltage
    V
    Output Voltage
    3.3
    V
    Operating Temperature
    -40 to +70
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    ROHS Compliance
    YES
    Switch control instruction
    Switch
    up/down
    Operation
    Switch 1
    up
    M.2-1
    down
    MiniPCIE-1
    Switch 2
    up
    M.2-2
    down
    MiniPCIE-2
    Switch 3
    up
    M.2-3
    down
    MiniPCIE-3
    Switch 4
    N/A
    M.2-4 and MiniPCIE-4 can work simultaneously,not controlled by the switch 4
    Outline
    Parameter
    Rating
    Unit
    Length
    180
    Mm
    Width
    66
    Mm
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
EMAIL:sales@wallystech.com
