IPQ6000/IPQ6018/IPQ6010 openwrt 802.11ax 2x2 2.4G 2x2 5G 1.7Gbps
Qualcomm-Atheros IPQ6000 Quad-core ARM 64 bit A53s 1.2GHz processor 2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps 5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps 2 on board radios (Dual Band Concurrent Radio) Supports Dynamic Frequency Selection (DFS)
Parameter | Rating | Unit | Supply Voltage | 12 | V | Operating Temperature Range | -20 to +70 | ºC | Storage Temperature Range | -45 to +90 | ºC | Operating Humidity Range | 5 to +95 (non-condensing) | % | Storage Humidity Range | 0 to +90 (non-condensing) | % |
Symbol | Parameter | CPU
| CPU Frequency
| Quad-core ARM 64 bit A53 @1.2GHz processor
| System Memory
| DDR3L 512MB 16-bit interface
| Nand Flash
| 128MB
| NOR Flash
| 16MB
| Ethernet Port
| 2x 1Gbps Ethernet Ports
| DC Jack Input
| 1x DC Jack Connector: 12V
| Power Consumption(Board Only)
| 1TD
| On Board Radio
| 2 radios (Dual band concurrent radio)
| Wireless
| On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
| Frequency Range
| 2.412~2.472GHz, 5.150~5.825GHz
| 2.4GHz Data Rate
| 5GHz Data Rate
| Modulation Techniques
| OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
| LED
| 4x LED Indicators
| USB /Header
| 1x MicroUSB 2.0 Port
| Serial Port
| 1x Serial Interface 12 Pin Connectors
| Certification
| TBD
| Humidity
| Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
| Temperature Range
| Operating: TBD Storage: -40ºC to 90ºC
| Dimension (Diameter x Height)
| 100mm x 23.5mm (Without Heatsink)
| | Radio TX Specifications For 2.4GHz |
Operating Mode | Data Rate | Power | Tolerance | 1 Chain | 2 Chains | 2.4GHz
802.11b | 1Mbps | 20dBm | 23dBm | ±2dB | 2Mbps | 20dBm | 23dBm | ±2dB | 5.5Mbps | 20dBm | 23dBm | ±2dB | 11Mbps | 20dBm | 23dBm | ±2dB | 2.4GHz
802.11g | 6Mbps | 20dBm | 23dBm | ±2dB | 9Mbps | 20dBm | 23dBm | ±2dB | 12Mbps | 20dBm | 23dBm | ±2dB | 18Mbps | 20dBm | 23dBm | ±2dB | 24Mbps | 20dBm | 23dBm | ±2dB | 36Mbps | 20dBm | 23dBm | ±2dB | 48Mbps | 20dBm | 23dBm | ±2dB | 54Mbps | 18dBm | 21dBm | ±2dB | 2.4GHz
802.11n HT40 | MCS 0 | 19dBm | 22dBm | ±2dB | MCS 1 | 19dBm | 22dBm | ±2dB | MCS 2 | 19dBm | 22dBm | ±2dB | MCS 3 | 19dBm | 22dBm | ±2dB | MCS 4 | 19dBm | 22dBm | ±2dB | MCS 5 | 19dBm | 22dBm | ±2dB | MCS 6 | 18dBm | 21dBm | ±2dB | MCS 7 | 17dBm | 20dBm | ±2dB | 2.4GHz
802.11n HT40 | MCS 0 | 18dBm | 21dBm | ±2dB | MCS 1 | 18dBm | 21dBm | ±2dB | MCS 2 | 18dBm | 21dBm | ±2dB | MCS 3 | 18dBm | 21dBm | ±2dB | MCS 4 | 18dBm | 21dBm | ±2dB | MCS 5 | 18dBm | 21dBm | ±2dB | MCS 6 | 17dBm | 20dBm | ±2dB | MCS 7 | 16dBm | 19dBm | ±2dB |
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech com) EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/
