求助关于T6963控制的240128液晶显示程序
7896|9
 楼主| bmfw 发表于 2012-4-3 09:49 | 显示全部楼层 |阅读模式
为何我的程序不显示呢?
/******内部驱动子程序开始***********************/
static uchar ReadState()
  uchar Data;
TFT_IO = 0x0FF;
TFT_CD = 1;
TFT_RD = 0;
TFT_CS = 0;
//至少延时150ns
  nop();nop();
Data = TFT_IO;
nop();
//至少延时50ns
TFT_RD = 1;
TFT_CS = 1;
return(Data);
//判断状态位STA1,STA0子程序
static void RW_Check()
  uchar State;
do{State=ReadState();}while(!(State&0x03));
//判断状态位STA2的子程序
static void AutoReadCheck()
  uchar State;
do{State=ReadState();}while(!(State&0x04));
//判断状态位STA3的子程序
static void AutoWriteCheck()
  uchar State;
do{State=ReadState();}while(!(State&0x08));
//写数据
static void WriteData(uchar Data)
  RW_Check();
TFT_CD = 0;
TFT_CS = 0;
TFT_WR = 0;
TFT_IO = Data;
nop();
//至少延时40ns
TFT_CD = 1;
TFT_CS = 1;
TFT_WR = 1;
//写命令
static void WriteCommand(uchar Command)
  RW_Check();
TFT_CD = 1;
TFT_CS = 0;
TFT_WR = 0;
TFT_IO = Command;
nop();
//至少延时40ns
TFT_CD = 1;
TFT_CS = 1;
TFT_WR = 1;
//写数据命令
static void WriteDataCommand(uchar Data,uchar Command)
  WriteData(Data);//写数据
WriteCommand(Command);
//写双数据命令
static void WriteData2Command(uchar Data1,uchar Data2,uchar Command)
  WriteData(Data1);//写数据
WriteData(Data2);//写数据
//自动写数据
static void AutoWriteData(uchar Data)
  AutoWriteCheck();//判断状态位STA3子程序
TFT_CD = 0;
TFT_CS = 0;
TFT_WR = 0;
TFT_IO = Data;
  nop();
//至少延时40ns
TFT_CD = 1;
TFT_CS = 1;
TFT_WR = 1;
//文本方式初始化
static void TftTextInit()
  //WriteData2Command(0x01,0x00,CursorPointer);//CursorPointer  0x21
  WriteData2Command(0x00,0x00,TextHomeAddr);//TextHomeAddr  0x40
  WriteData2Command(LineChar,0x00,TextArea);//TextArea  0x41
WriteCommand(TextOn);//TextOn  0x94
WriteCommand(CursorPattern);//一线模式A0
WriteCommand(OrMode);//OrMode  0x80
//图形方式初始化
static void TftGraphicInit()
  WriteData2Command(0x00,0x08,GraphicHomeAddr);//GraphicHomeAddr  0x42
WriteData2Command(LineChar,0x00,GraphicArea);//GraphicArea  0x43
WriteCommand(GraphicOn);//GraphicOn  0x98
//CGRAM函数
static void CreatCGRam()
  uint16 data i;
WriteData2Command(0x03,0x00,OffsetReg);//OffsetReg  0x22
WriteData2Command(0x00,0x1c,AddressPointer);//AddressPointer  0x24
WriteCommand(DataAutoWrite);//DataAutoWrite  0x0B0
for(i=0;i<1264;i++)
  AutoWriteCheck();
  WriteData(CGTAB[i]);
WriteCommand(ExitAutoRW);//ExitAutoRW  0x0B2
//用Text方式在(x,y)显示一个汉字
static void WriteOneHzText(uchar xAddr,uchar yAddr,uchar uData)
uint16 i,j;
i=LineChar;
j=i*yAddr+xAddr;
WriteData2Command(j%256,j/256,AddressPointer);//AddressPointer 0x24
//写入左上半部汉字代码
WriteDataCommand(uData,DataWAddrI);//DataWAddrI  0x0C0
//写入右上半部汉字代码
WriteDataCommand(uData+0x02,DataWAddrI);//DataWAddrI  0x0C0
j=j+i+0x20;//显示RAM地址修正
//写入左下半部汉字代码
WriteDataCommand(uData+0x01,DataWAddrI);//DataWAddrI  0x0C0
//写入右下半部汉字代码
WriteDataCommand(uData+0x03,DataWAddrI);//DataWAddrI  0x0C0
//用Graphic方式在(x,y)显示一个汉字
static void WriteOneHzGraphic(uchar xAddr,uchar yAddr,uchar uData)
uint16 i,j,count1;
i=LineChar;
j=i*yAddr+xAddr+0x0800;/*图形显示区首地址为0x0800*/
for(count1=0;count1<16;count1++)
  WriteDataCommand(CCTAB[uData][count1],DataWAddrI);//DataWAddrI  0x0C0
  WriteDataCommand(CCTAB[uData][count1+16],DataWAddrI);//DataWAddrI  0x0C0
  j=j+i;
static void TftWriteChar(uchar xAddr,uchar yAddr,uchar uData)
{//西文字符写入(文本属性)函数
  uint16 data i,j;
i=LineChar;
j=i*yAddr+xAddr;
WriteDataCommand(uData,DataWAddrNV);//DataWAddrNV  0x0C4
WriteData2Command(uData,0x08,AddressPointer);//AddressPointer  0x24
WriteDataCommand(0,DataWAddrNV);//DataWAddrNV  0x0C4
/******内部驱动子程序结束***********************/
//液晶屏初始化
void TftInit()
  TftTextInit();//文本方式初始化
  TftGraphicInit();//图形方式初始化
//清屏
void TftClearScreen()
uint16 data i;
  WriteData2Command(0x00,0x00,AddressPointer);//AddressPointer 0x24
WriteCommand(DataAutoWrite);//数据自动写DataAutoWrite  0x0B0
for(i=0;i<8192;i++)//8k
   WriteData(0x00);//写数据
WriteCommand(ExitAutoRW);//退出数据自动读写模式ExitAutoRW  0x0B2
//显示汉字
void DisplayScreen()
CreatCGRam();//建立CGRAM
WriteOneHzText(0x00,0x00,0x80);
TftWriteChar(0x05,0x05,0x00);
WriteOneHzGraphic(0x00,0x00,0x00);
main()
TftInit();//液晶屏初始化
TftClearScreen();//清屏
void DisplayScreen();//显示汉字和字母
 楼主| bmfw 发表于 2012-4-3 09:52 | 显示全部楼层
程序初始化后也能清屏,就是汉字和字母显示不出来,不知道哪里出了问题...
joing1999 发表于 2012-4-9 15:36 | 显示全部楼层
先检测负压够不够,然后再检查接线有没有错。最后才看程序
 楼主| bmfw 发表于 2012-4-14 10:53 | 显示全部楼层
解决了,还是程序的问题...
lsacyj 发表于 2012-6-20 11:08 | 显示全部楼层
楼主,你好,我刚接触单片机没多久,关于240128液晶显示问题想向你详细请教,qq:940405085麻烦你了很急。。。
wukunshan 发表于 2012-6-20 12:00 | 显示全部楼层
兄弟们,那么长的程序,大虾们是不会有时间给你们看的,不如到我的店铺花10元去买一套。经典的C代码和详细的注释,让您很快轻松学会240128液晶驱动。http://wushifuc51.taobao.com.我当初写得时候,写得很辛苦的哟。
joing1999 发表于 2012-6-25 09:01 | 显示全部楼层
额……LS的,我上去看了一下,程序都要10块钱呀。
兄弟,你的东西贵了点呀,我以前买个51和AVR兼容的下载板,16块钱。用了3年,到现在依然很好呢。
wukunshan 发表于 2012-6-25 12:14 | 显示全部楼层
楼上兄弟呀,如果你自己去摸索写出这个240128驱动程序,你会觉得卖100元一套都划不来哦。我是本着方便学习而仅仅收取一点辛苦费而已啊。
我的开发板确实贵了点,这个我承认,成本贵呀。光是USB转串口芯片FT232RL的批发价都近20元了,零售超过30元。10位AD转换芯片TLC1549的批发价也要10几元了。。。。
lj08120917 发表于 2012-11-18 15:25 | 显示全部楼层
同样的程序,烧录到ATMEL89C52就可以显示,下载到STC89C52就不显示...
yaozgaom 发表于 2013-9-18 16:42 | 显示全部楼层
楼主好,你的问题应该解决了吧,我的程序烧写进去没反应,最后把厂家提供的烧写进去也没反应,跪求楼主协助下,一般是哪里的问题啊
