[PCB] WALLYS wifi5 IPQ4019/IPQ4018/IPQ4028 802.11ac Wave2 2x2 2.4Ghz 5Ghz
1114|0
 楼主| wirelesswifi6 发表于 2022-7-13 10:05 | 显示全部楼层 |阅读模式
WALLYS wifi5 IPQ4019/IPQ4018/IPQ4028 802.11ac Wave2 2x2 2.4Ghz 2x2 5Ghz Industrial-grade
Featuring with industrial-grade IPQ4018/IPQ4028 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range;
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook. welcome to consult.
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
    Symbol
    Parameter
    CPU
    IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
    Antenna Connector
    2 x 5G MMCX connectors;2x2.4G MMCX
    10/100/1000Mbps Gigabit Ethernet
    2xRJ45
    SFP connector
    1xSFP fiber module connector (optional)
    3G/4G connector
    1xminipcie 3G/4G connector support with two sim card
    USB connector
    1xUSB 3.0 connector
    POE
    24V~48V passive POE
    DC Jack
    24V~48V power supply
    ROHS Compliance
    YES
    Dimension
    115mm x 105mm x 16mm
    Nor Flash
    2MB~32MB
    Nand Flash
    128MB
    DDR
    256MB
    Operating Mode
    Data Rate
    Sensitivity
    802.11g
    6 Mbps
    -96dBm
    54 Mbps
    -78dBm
    802.11n HT20
    MCS0, MCS8
    -92dBm
    MCS7, MCS15
    -73dBm
    802.11n HT40
    MCS0, MCS8
    -90dBm
    MCS7, MCS15
    -70dBm
