振邦微科技针对市场推出一款新研发的AH8669芯片220V转变12V-24V应用暖风机上(Zhenbang Micro Technology yebda-d yiwet n chip tamaynut n ah8669 n 220V ed 12v-24v i wulzuz, d ayen ay yessefken i uḥemmay.}AH8669芯片是不用变压器的AC转DC芯片,从直流38V-600V输入电压(可直接应用220V交流电输入),输出电压从{3.3V-5V-9V-12V-18V-24V-36V}可调,输出电流均为100mA-600mA,大输出可达10W功率。AH8669内部集成600V高压MOSFET,以满足高电压冲击的需求。不同于典型的PWM控制方式。220V转换12产品开关具有自恢复的输出开短路过压,过流,过温,过载,等保护功能(220V 12 product switch with self-recovery output short circuit over voltage, over current, over temperature, overload, and other protection functions.}
AH8669芯片220V转变12V-24V应用暖风机上主要特点电路简单、BOM成本低(外围元件数目极少),电源体积小、无音频噪音、损耗小发热低。电源系统带有各种保护,包括过热保护(OTP)、VCC欠压闭锁(UVLO)、过载保护(OLP)、短路保护(SCP)等!
应用领域:135.3806-7573芯片
高压降压AC-DC电源IC
12V24V继电器驱动
应急灯电源
数字电表电源
小家电控制板电源
仪表与工业控制器电源
非隔离辅助电源,待机电源
单片机MCU或功能模组供电电源
AH8669 220V to 12V 24V application of the main characteristics of the heater circuit is simple, low BOM cost (few peripheral components), small power volume, no audio noise, low loss and low heat. Power system with a variety of protection, including overheat protection (OTP), VCC undervoltage locking (UVLO), overload protection (OLP), short circuit protection (SCP) and so on!
