[应用相关] 进不去中断
1241|11
 楼主| hfdy01 发表于 2022-8-20 20:52 | 显示全部楼层 |阅读模式
在软仿的情况下,通过将相应的system event置1,能够正常进入中断并跳转到中断服务程序,但是在相同条件下,硬仿的时候进进不去中断.
CallReceiver 发表于 2022-8-20 20:54 | 显示全部楼层
也跳转不到中断服务程序。。
8962中有个休眠模块,里面有实时时钟功能,使用32.768KHz晶振实现较为准确的定时。
boy1990 发表于 2022-8-20 20:59 | 显示全部楼层
MEMORY
VECTORS:
o = 0x00800000  l = 0x00000400
/*vectors*/
    L2RAM:      o = 0x00800400  l = 0x001FFC00  /* 2MB L2 Internal SRAM */
    L1PRAM:     o = 0x00E00000  l = 0x00008000  /* 32kB L1 Program SRAM/CACHE */
    L1DRAM:     o = 0x00F00000  l = 0x00008000  /* 32kB L1 Data SRAM/CACHE */
    EMIFA_CE2:  o = 0xA0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
    EMIFA_CE3:  o = 0xB0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
    EMIFA_CE4:  o = 0xC0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
    EMIFA_CE5:  o = 0xD0000000  l = 0x00800000  /* 8MB EMIFA CE2 */
    DDR2_CE0:   o = 0xE0000000  l = 0x20000000  /* 512MB EMIFB CE0 */
中断向量表:
.sect".vecs"
.ref _c_int00
.ref _c_int04                ;ref the function defined in C file
.align 1024
_vectors:
_vector0:       VEC_ENTRY _c_int00   ;RESET中断
_vector1:       VEC_ENTRY _vec_dummy ;NMI不可屏蔽中断
_vector2:       VEC_ENTRY _vec_dummy ;保留中断1
_vector3:       VEC_ENTRY _vec_dummy ;保留中断2
_vector4:       VEC_ENTRY _c_int04   ;对应于c_int04 ISR
_vector5:       VEC_ENTRY _vec_dummy ;外部中断INT5
_vector6:       VEC_ENTRY _vec_dummy ;外部中断INT6
_vector7:       VEC_ENTRY _vec_dummy ;外部中断INT7
_vector8:       VEC_ENTRY _vec_dummy ;外部中断INT8
_vector9:       VEC_ENTRY _vec_dummy ;JTAGRTDX中断
_vector10:      VEC_ENTRY _vec_dummy ;EMIF_SDRAM_Timer中断
_vector11:      VEC_ENTRY _vec_dummy ;McBSP_0_Receive中断
_vector12:      VEC_ENTRY _vec_dummy ;McBSP_1_Transmit中断
_vector13:      VEC_ENTRY _vec_dummy ;Host_Port_Host_to_DSP中断
_vector14:      VEC_ENTRY _vec_dummy ;Timer0中断
_vector15:      VEC_ENTRY _vec_dummy ;Timer1中断
中断初始化:
void InitInterrupt(void)
unsigned int temp;
  *IECRH = 0xFFFFFFFF;  // IECRH (disable high interrupts enable)
  *EECRH = 0xFFFFFFFF; // EECRH (disable high events enable)
  *ICRH  = 0xFFFFFFFF;  // ICRH  (clear high interrupts pending)
  *ECRH  = 0xFFFFFFFF;  // ECRH  (clear high events pending)
  *IECR  = 0xFFFFFFFF;  // IECR  (disable low interrupts enable)
  *EECR  = 0xFFFFFFFF;  // EECR  (disable low events enable)
  *EICR  = 0xFFFFFFFF;  // ICR   (clear low interrupts pending)
  *ECR   = 0xFFFFFFFF;  // ECR   (clear low events pending)
*EVTMASK0 = 0xffffffff;//disable combine
*EVTMASK1 = 0xffffffff;
*EVTMASK2 = 0xffffffff;
*EVTMASK3 = 0xffffffff;
*EVTCLR0 |= 0xfffffff;
*EVTCLR1 |= 0xfffffff;
*EVTCLR2 |= 0xfffffff;//clear all event(including 66) flag before the new interrupt come
*EVTCLR3 |= 0xfffffff;
temp = *EVTFLAG2;
ICR = 0xfffffffe;
//clear IFR
asm( " NOP");
asm( " NOP");
*INTMUX1 |= 0x00000037;//55对应到INT04
*INTMUX1 &= 0xffff0037;
*INTMUX1 |= 0x00000042;//INT04 responding to event 66,GPIO 15
*INTMUX1 &= 0xffff0042;
IER |= 0x00000012;   // IE4=1,NMIE=1
ISTP = 0x00800080;
*EVTSET1 |= 0x00800000;//55
*EVTSET2 |= 0x00000004;//set interrupt 66,only for test,zdx
CSR |= 0x00000001;
// enable GIE
//*EVTSET2=0x0000;
sourceInsight 发表于 2022-8-20 21:00 | 显示全部楼层
你的中断源是什么呢?
feiqi1 发表于 2022-8-20 21:05 | 显示全部楼层
EVTFLAG中相应的位也成功置高,IFR对应的中断位也成功置1,但还是不能跳转到我的中断服务程序。
androidbus 发表于 2022-8-20 21:07 | 显示全部楼层
STP我配成ISTP = 0x00800080;也就是我希望跳转到的中断服务程序地址,但运行时貌似ISTP一直等于0x00800000,请帮忙看看。
litengg 发表于 2022-8-20 21:12 | 显示全部楼层
我现在也怀疑的一个地方是ISTP的设置,我在程序中让ISTP = 0x00800080,但实际仿真的时候看到ISTP=0x00800000,而且根据数据手册的描述,ISTP中的ISTB(中断向量表基地址)最大为0x3ffff,而6457最小地址为0x00800000(我放置中断向量表的位置),这个值超过了ISTB的范围,请问该如何理解?
qiangweii 发表于 2022-8-20 21:13 | 显示全部楼层
重新设置VECTORS:
和ISTP
shashaa 发表于 2022-8-20 21:26 | 显示全部楼层
要不直接把中断向量表首地址挂载到o地址。
wanglaojii 发表于 2022-8-20 21:27 | 显示全部楼层
Vectors我就是这么定义的。
0x0还没有用,空载
laozhongyi 发表于 2022-8-20 21:33 | 显示全部楼层
这回事啥问题的,,看了楼上几位的,有点眉目了。
