- #include "spi.h"
- //SPI口初始化
- //这里针是对SPI1的初始化
- void SPI1_Init(void)
- spi_init_type spi_init_struct;
- gpio_init_type gpio_initstructure;
- crm_periph_clock_enable(CRM_SPI1_PERIPH_CLOCK, TRUE);
- crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
- gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE5, GPIO_MUX_0);
- gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE6, GPIO_MUX_0);
- gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE7, GPIO_MUX_0);
- gpio_default_para_init(&gpio_initstructure);
- gpio_initstructure.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
- gpio_initstructure.gpio_pull = GPIO_PULL_DOWN;
- gpio_initstructure.gpio_mode = GPIO_MODE_MUX;
- gpio_initstructure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
- gpio_initstructure.gpio_pins = GPIO_PINS_5;
- gpio_init(GPIOA, &gpio_initstructure);
- gpio_initstructure.gpio_pull = GPIO_PULL_UP;
- gpio_initstructure.gpio_pins = GPIO_PINS_6;
- gpio_initstructure.gpio_pins = GPIO_PINS_7;
- gpio_bits_set(GPIOA,GPIO_PINS_5|GPIO_PINS_6|GPIO_PINS_7);
- spi_default_para_init(&spi_init_struct);
- spi_init_struct.transmission_mode = SPI_TRANSMIT_FULL_DUPLEX;
- spi_init_struct.master_slave_mode = SPI_MODE_MASTER;
- spi_init_struct.mclk_freq_division = SPI_MCLK_DIV_8;
- spi_init_struct.first_bit_transmission = SPI_FIRST_BIT_LSB;
- spi_init_struct.frame_bit_num = SPI_FRAME_8BIT;
- spi_init_struct.clock_polarity = SPI_CLOCK_POLARITY_LOW;
- spi_init_struct.clock_phase = SPI_CLOCK_PHASE_2EDGE;
- spi_init_struct.cs_mode_selection = SPI_CS_SOFTWARE_MODE;
- spi_init(SPI1, &spi_init_struct);
- // spi_init_struct.master_slave_mode = SPI_MODE_SLAVE;
- spi_enable(SPI1, TRUE);
- SPI1_ReadWriteByte(0xff);//启动传输
- //SPIx 读写一个字节
- //TxData:要写入的字节
- //返回值:读取到的字节
- u8 SPI1_ReadWriteByte(u8 TxData)
- u8 retry=0;
- while (spi_i2s_flag_get(SPI1, SPI_I2S_TDBE_FLAG) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
- retry++;
- if(retry>200)return 0;
- spi_i2s_data_transmit(SPI1, TxData); //通过外设SPIx发送一个数据
- retry=0;
- while (spi_i2s_flag_get(SPI1, SPI_I2S_RDBF_FLAG) == RESET)//检查指定的SPI标志位设置与否:接受缓存非空标志位
- retry++;
- return spi_i2s_data_receive(SPI1); //返回通过SPIx最近接收的数据
添加定时器初始化
- #include "timer.h"
- #include "at32f425_clock.h"
- #include "lwip_comm.h"
- extern u32 lwip_localtime; //lwip本地时间计数器,单位:ms
- //通用定时器3中断初始化
- //arr:自动重装值。
- //psc:时钟预分频数
- //定时器溢出时间计算方法:Tout=((arr+1)*(psc+1))/Ft us.
- //Ft=定时器工作频率,单位:Mhz
- //这里使用的是定时器3!
- void TIM3_Int_Init(u16 arr,u16 psc)
- crm_periph_clock_enable(CRM_TMR1_PERIPH_CLOCK, TRUE); //时钟使能
- //定时器TIM3初始化
- tmr_base_init(TMR1, arr, psc);
- tmr_cnt_dir_set(TMR1, TMR_COUNT_UP);
- /* overflow interrupt enable */
- tmr_interrupt_enable(TMR1, TMR_OVF_INT, TRUE);
- /* tmr1 overflow interrupt nvic init */
- nvic_priority_group_config(NVIC_PRIORITY_GROUP_4);
- nvic_irq_enable(TMR1_BRK_OVF_TRG_HALL_IRQn, 5, 0);
- /* enable tmr1 */
- tmr_counter_enable(TMR1, TRUE);
- // crm_clkout_div_set(CRM_CLKOUT_DIV_1);
- // /* config clkout clock */
- // crm_clock_out_set(CRM_CLKOUT_PLL_DIV_4);
- //定时器3中断服务函数
- void TMR1_BRK_OVF_TRG_HALL_IRQHandler(void)
- if(tmr_flag_get(TMR1, TMR_OVF_FLAG) != RESET)
- /* add user code... */
- at32_led_toggle(LED2);
- lwip_localtime +=10; //加10
- tmr_flag_clear(TMR1, TMR_OVF_FLAG);
下载LWIP的源码,这里使用的版本是1.41的,将源码直接放在自己工程的LWIP文件下,这里对源码文件进行简单的介绍,首先就是DOC文件,这里面放的是一些移植文档和说明文档,这里主要用的是src这个源码文件夹,在test文件夹下 存放的是一些例程。
接下来将源码添加到自己的工程中,将文件core下和ipv4下的所有.c文件都添加到Lwip_core这个文件夹下,如下所示
接下来添加头文件路径
本次使用的模块是ENC28J60模块,使用spi与单片机连接即可,其中这板子自带AT-link,同时还能用作串口,比较方便,如下所示
由于跑的是裸机。所以这里需要进行一个动态内存管理,这个芯片内存只有20K,这里得下大功夫实现内存的整改,需要进行裁剪
- #include "malloc.h"
- //内存池(4字节对齐)
- __align(4) u8 mem1base[MEM1_MAX_SIZE]; //内部SRAM内存池
- __align(4) u8 mem2base[MEM2_MAX_SIZE] __attribute__((at(0X68000000))); //外部SRAM内存池
- //内存管理表
- u16 mem1mapbase[MEM1_ALLOC_TABLE_SIZE]; //内部SRAM内存池MAP
- u16 mem2mapbase[MEM2_ALLOC_TABLE_SIZE] __attribute__((at(0X68000000+MEM2_MAX_SIZE))); //外部SRAM内存池MAP
- //内存管理参数
- const u32 memtblsize[2]={MEM1_ALLOC_TABLE_SIZE,MEM2_ALLOC_TABLE_SIZE}; //内存表大小
- const u32 memblksize[2]={MEM1_BLOCK_SIZE,MEM2_BLOCK_SIZE}; //内存分块大小
- const u32 memsize[2]={MEM1_MAX_SIZE,MEM2_MAX_SIZE}; //内存总大小
- //内存管理控制器
- struct _m_mallco_dev mallco_dev=
- my_mem_init, //内存初始化
- my_mem_perused, //内存使用率
- mem1base,mem2base, //内存池
- mem1mapbase,mem2mapbase,//内存管理状态表
- 0,0, //内存管理未就绪
- //复制内存
- //*des:目的地址
- //*src:源地址
- //n:需要复制的内存长度(字节为单位)
- void mymemcpy(void *des,void *src,u32 n)
- u8 *xdes=des;
- u8 *xsrc=src;
- while(n--)*xdes++=*xsrc++;
- //设置内存
- //*s:内存首地址
- //c :要设置的值
- //count:需要设置的内存大小(字节为单位)
- void mymemset(void *s,u8 c,u32 count)
- u8 *xs = s;
- while(count--)*xs++=c;
- //内存管理初始化
- //memx:所属内存块
- void my_mem_init(u8 memx)
- mymemset(mallco_dev.memmap[memx], 0,memtblsize[memx]*2);//内存状态表数据清零
- mymemset(mallco_dev.membase[memx], 0,memsize[memx]); //内存池所有数据清零
- mallco_dev.memrdy[memx]=1; //内存管理初始化OK
- //获取内存使用率
- //memx:所属内存块
- //返回值:使用率(0~100)
- u8 my_mem_perused(u8 memx)
- u32 used=0;
- u32 i;
- for(i=0;i<memtblsize[memx];i++)
- if(mallco_dev.memmap[memx][i])used++;
- return (used*100)/(memtblsize[memx]);
- //内存分配(内部调用)
- //memx:所属内存块
- //size:要分配的内存大小(字节)
- //返回值:0XFFFFFFFF,代表错误;其他,内存偏移地址
- u32 my_mem_malloc(u8 memx,u32 size)
- signed long offset=0;
- u16 nmemb; //需要的内存块数
- u16 cmemb=0;//连续空内存块数
- u32 i;
- if(!mallco_dev.memrdy[memx])mallco_dev.init(memx);//未初始化,先执行初始化
- if(size==0)return 0XFFFFFFFF;//不需要分配
- nmemb=size/memblksize[memx]; //获取需要分配的连续内存块数
- if(size%memblksize[memx])nmemb++;
- for(offset=memtblsize[memx]-1;offset>=0;offset--)//搜索整个内存控制区
- if(!mallco_dev.memmap[memx][offset])cmemb++;//连续空内存块数增加
- else cmemb=0; //连续内存块清零
- if(cmemb==nmemb) //找到了连续nmemb个空内存块
- for(i=0;i<nmemb;i++) //标注内存块非空
- mallco_dev.memmap[memx][offset+i]=nmemb;
- return (offset*memblksize[memx]);//返回偏移地址
- return 0XFFFFFFFF;//未找到符合分配条件的内存块
- //释放内存(内部调用)
- //memx:所属内存块
- //offset:内存地址偏移
- //返回值:0,释放成功;1,释放失败;
- u8 my_mem_free(u8 memx,u32 offset)
- int i;
- if(!mallco_dev.memrdy[memx])//未初始化,先执行初始化
- mallco_dev.init(memx);
- return 1;//未初始化
- if(offset<memsize[memx])//偏移在内存池内.
- int index=offset/memblksize[memx]; //偏移所在内存块号码
- int nmemb=mallco_dev.memmap[memx][index]; //内存块数量
- for(i=0;i<nmemb;i++) //内存块清零
- mallco_dev.memmap[memx][index+i]=0;
- return 0;
- }else return 2;//偏移超区了.
- //释放内存(外部调用)
- //memx:所属内存块
- //ptr:内存首地址
- void myfree(u8 memx,void *ptr)
- u32 offset;
- if(ptr==NULL)return;//地址为0.
- offset=(u32)ptr-(u32)mallco_dev.membase[memx];
- my_mem_free(memx,offset);//释放内存
- //分配内存(外部调用)
- //memx:所属内存块
- //size:内存大小(字节)
- //返回值:分配到的内存首地址.
- void *mymalloc(u8 memx,u32 size)
- u32 offset;
- offset=my_mem_malloc(memx,size);
- if(offset==0XFFFFFFFF)return NULL;
- else return (void*)((u32)mallco_dev.membase[memx]+offset);
- //重新分配内存(外部调用)
- //memx:所属内存块
- //*ptr:旧内存首地址
- //返回值:新分配到的内存首地址.
- void *myrealloc(u8 memx,void *ptr,u32 size)
- u32 offset;
- else
- mymemcpy((void*)((u32)mallco_dev.membase[memx]+offset),ptr,size); //拷贝旧内存内容到新内存
- myfree(memx,ptr); //释放旧内存
- return (void*)((u32)mallco_dev.membase[memx]+offset); //返回新内存首地址
- #ifndef __MALLOC_H
- #define __MALLOC_H
- #include "at32f425.h"
- #ifndef NULL
- #define NULL 0
- #endif
- #define SRAMIN 0 //内部内存池
- #define SRAMEX 1 //外部内存池
- //mem1内存参数设定.mem1完全处于内部SRAM里面
- #define MEM1_BLOCK_SIZE 32 //内存块大小为32字节
- #define MEM1_MAX_SIZE 17*1024
- #define MEM1_ALLOC_TABLE_SIZE MEM1_MAX_SIZE/MEM1_BLOCK_SIZE //内存表大小
- //mem2内存参数设定.mem2的内存池处于外部SRAM里面,其他的处于内部SRAM里面
- #define MEM2_BLOCK_SIZE 32
- #define MEM2_MAX_SIZE 17*1024
- #define MEM2_ALLOC_TABLE_SIZE MEM2_MAX_SIZE/MEM2_BLOCK_SIZE //内存表大小
- //内存管理控制器
- void (*init)(u8); //初始化
- u8 (*perused)(u8); //内存使用率
- u8 *membase[2]; //内存池 管理2个区域的内存
- u16 *memmap[2]; //内存管理状态表
- u8 memrdy[2]; //内存管理是否就绪
- extern struct _m_mallco_dev mallco_dev; //在mallco.c里面定义
- void mymemset(void *s,u8 c,u32 count); //设置内存
- void mymemcpy(void *des,void *src,u32 n);//复制内存
- void my_mem_init(u8 memx); //内存管理初始化函数(外/内部调用)
- u32 my_mem_malloc(u8 memx,u32 size); //内存分配(内部调用)
- u8 my_mem_free(u8 memx,u32 offset); //内存释放(内部调用)
- u8 my_mem_perused(u8 memx); //获得内存使用率(外/内部调用)
- //用户调用函数
- void myfree(u8 memx,void *ptr); //内存释放(外部调用)
- void *mymalloc(u8 memx,u32 size); //内存分配(外部调用)
- void *myrealloc(u8 memx,void *ptr,u32 size);//重新分配内存(外部调用)
- #endif
这里使用的是内部内存池,最大有20K,但是得留一部分给其他程序用,在这里比较尴尬的是,但我内存池用18K的时候,其他函数又不够用,当使用17K的时候,内存池又不能初始化成功。所以这里就只能使用17K进行内存池的初始化,然后将LWIP的内容进行裁剪。具体如下,不然无法使用。又没有外扩内存。
主函数
- #include "at32f425_board.h"
- #include "enc28j60.h"
- #include "lwip/netif.h"
- #include "lwipopts.h"
- int main(void)
- system_clock_config();
- at32_board_init();
- TIM3_Int_Init(9999,95);
- my_mem_init(SRAMIN);
- lwip_comm_init();
- // printf("the lwip return value is %d\r\n",lwip_comm_init());
- if(lwip_comm_init()==0)//等待DHCP获取成功/超时溢出
- printf("lwip init success.....\r\n");
- else
- printf("lwip init fail.....\r\n");
- #if LWIP_DHCP //使用DHCP
- while((lwipdev.dhcpstatus!=2)&&(lwipdev.dhcpstatus!=0XFF))//等待DHCP获取成功/超时溢出
- lwip_periodic_handle(); //LWIP内核需要定时处理的函数
- #endif
- delay_ms(500);
- while(1)
之前的内存调试使用多个printf函数将内容打印出来,方便观察。
- u8 lwip_comm_mem_malloc(void)
- u32 mempsize;
- u32 ramheapsize;
- mempsize=memp_get_memorysize(); //得到memp_memory数组大小
- printf(" mempsiz is %d\r\n",mempsize);
- memp_memory=mymalloc(SRAMIN,mempsize); //为memp_memory申请内存
- printf(" memp_memory is %d\r\n",sizeof(memp_memory));
- if(!memp_memory)
- printf(" mempsiz 申请失败 \r\n");
- ramheapsize=LWIP_MEM_ALIGN_SIZE(MEM_SIZE)+2*LWIP_MEM_ALIGN_SIZE(4*3)+MEM_ALIGNMENT;//得到ram heap大小
- printf(" ramheapsize is %d\r\n",ramheapsize);
- ram_heap=mymalloc(SRAMIN,ramheapsize); //为ram_heap申请内存
- printf(" ram_heap is %d\r\n",sizeof(ram_heap));
- if(!ram_heap)
- printf(" ram_heap 申请失败 \r\n");
- if(!memp_memory||!ram_heap)//有申请失败的
- lwip_comm_mem_free();
- return 1;
- return 0;
接下来打开串口,打开电脑进行设置
接下来打开串口调试助手,复位板子查看信息
