[开发板与模块] 【ESK32-30519 + ESK32-21001测评】数码管显示及其原理
929|0
 楼主| jinglixixi 发表于 2022-9-13 15:37 | 显示全部楼层 |阅读模式
在ESK32-30519 开发板上配置了数码管显示器,可实现相应数据的显示,其电路原理图如图1所示。
图1 数码管电路
为此,该数码管的引脚定义如下:
  1.   #defineHTCFG_LEDC_COM_D1                        4
  2.   #defineHTCFG_LEDC_COM_D2                       5
  3.   #defineHTCFG_LEDC_COM_D3                       6
  4.   #defineHTCFG_LEDC_COM_D4                        7
  5.   #define_HTCFG_LEDC_COM0_GPIO_PORT               C  // DIG1
  6.   #define_HTCFG_LEDC_COM0_GPIO_PIN                4
  7.   #define_HTCFG_LEDC_COM1_GPIO_PORT              C  // DIG2
  8.   #define_HTCFG_LEDC_COM1_GPIO_PIN               5
  9.   #define_HTCFG_LEDC_COM2_GPIO_PORT               C  // DIG3
  10.   #define_HTCFG_LEDC_COM2_GPIO_PIN               6
  11.   #define_HTCFG_LEDC_COM3_GPIO_PORT              C   // DIG4
  12.   #define_HTCFG_LEDC_COM3_GPIO_PIN               7
  13.   #define_HTCFG_LEDC_SEG0_GPIO_PORT               A    // F
  14.   #define_HTCFG_LEDC_SEG0_GPIO_PIN                0
  15.   #define_HTCFG_LEDC_SEG1_GPIO_PORT              A    // DP
  16.   #define_HTCFG_LEDC_SEG1_GPIO_PIN               1
  17.   #define_HTCFG_LEDC_SEG2_GPIO_PORT              A    // C
  18.   #define_HTCFG_LEDC_SEG2_GPIO_PIN               2
  19.   #define _HTCFG_LEDC_SEG3_GPIO_PORT               A    // E
  20.   #define_HTCFG_LEDC_SEG3_GPIO_PIN               3
  21.   #define_HTCFG_LEDC_SEG4_GPIO_PORT              D    // A
  22.   #define_HTCFG_LEDC_SEG4_GPIO_PIN               4
  23.   #define_HTCFG_LEDC_SEG5_GPIO_PORT              D    // D
  24.   #define _HTCFG_LEDC_SEG5_GPIO_PIN                5
  25.   #define_HTCFG_LEDC_SEG6_GPIO_PORT              D    // G
  26.   #define_HTCFG_LEDC_SEG6_GPIO_PIN               2
  27.   #define_HTCFG_LEDC_SEG7_GPIO_PORT              A    // B
  28.   #define_HTCFG_LEDC_SEG7_GPIO_PIN               7
为实现数码的显示,其段码的定义如下:
  1. const u8 NumberChar[]={
  2.   /* a: Seg4(0x10), b:Seg7(0x80), c: Seg2(0x04), d: Seg5(0x20),
  3.      e: Seg3(0x08), f:Seg0(0x01), g: Seg6(0x40), dp: Seg1(0x02) */
  4.   0xBD, /* '0' =a+b+c+d+e+f      = 0x10 + 0x80 + 0x04 +0x20 + 0x08 + 0x01               = 0xBD*/
  5.   0x84, /* '1' =   b+c+          =        0x80 + 0x04                                    = 0x84 */
  6.   0xF8, /* '2' = a+b  +d+e +g    = 0x10 + 0x80 +        0x20 + 0x08 +      + 0x40        = 0xF8 */
  7.   0xF4, /* '3' = a+b+c+d    +g   = 0x10 + 0x80 + 0x04 + 0x20 +            + 0x40        = 0xF4 */
  8.   0xC5, /* '4' =   b+c   +f+g    =        0x80 + 0x04               + 0x01 + 0x40        = 0xC5 */
  9.   0x75, /* '5' = a  +c+d +f+g    = 0x10        + 0x04 + 0x20        + 0x01 + 0x40        = 0x75 */
  10.   0x7D, /* '6' = a  +c+d+e+f+g   = 0x10        + 0x04 + 0x20 + 0x08+ 0x01 + 0x40        = 0x7D */
  11.   0x95, /* '7' = a+b+c    +f     = 0x10 + 0x80 + 0x04              + 0x01               = 0x95 */
  12.   0xFD, /* '8' =a+b+c+d+e+f+g    = 0x10 + 0x80 + 0x04 +0x20 + 0x08 + 0x01 + 0x40        = 0xFD*/
  13.   0xF5, /* '9' = a+b+c+d  +f+g   = 0x10 + 0x80 + 0x04 + 0x20       + 0x01 + 0x40        = 0xF5 */
  14.   0x02  /* '.' =               dp =                                                 0x02 = 0x02 */
  15. };
以显示“1”为例,需点亮B段和C段,故输出的段码为10000100,即0x84。
那么又该如何来理解下面的数码管显示的主程序呢?
  1. int main(void)
  3.   u8 CharIndex=0;
  4.   u8 CharSize = sizeof(NumberChar);
  5.   GPIO_Configuration();
  6.   LEDC_Configuration();
  7.   while (1)
  8.   {
  9.     if(gIsUpdateChar)
  10.     {
  11.       /* The character has been displayed for 1 second, and the new character will be replaced.*/
  12.       LEDC_SetData(HTCFG_LEDC_COM_D1,  NumberChar[CharIndex++%CharSize]);
  13.       LEDC_SetData(HTCFG_LEDC_COM_D2,  NumberChar[CharIndex++%CharSize]);
  14.       LEDC_SetData(HTCFG_LEDC_COM_D3,  NumberChar[CharIndex++%CharSize]);
  15.       LEDC_SetData(HTCFG_LEDC_COM_D4,  NumberChar[CharIndex++%CharSize]);
  16.       gIsUpdateChar = FALSE;
  17.     }
  18.   }
  19. }
其实它的作用就是依次从左到右来输出每一位的段码值来实现显示,其输出的段码也可以说是显示内容是靠变量NumberChar[CharIndex来控制的,每显示一轮该变量的值就向后移动1位。
为防止溢出,则是通过取余来实现内容的滚动显示。而每轮显示的延时值,则是通过中断处理来完成的,其判别标识则是变量gIsUpdateChar。
在为例程添加工程文件及修改关联文件路径的情况下,通过下载即可见到图2和图3所示的效果。
图2 显示“2345”
图3 显示“4567”
那如何才能显示“3.30”这样的数值呢?
使用下面的程序就可获得图4所示的效果。
  1. while (1)
  2.   {
  3.     if(gIsUpdateChar)
  4.     {
  5.        LEDC_SetData(HTCFG_LEDC_COM_D1,  NumberChar[3]);
  6.       LEDC_SetData(HTCFG_LEDC_COM_D2,  NumberChar[10]);
  7.       LEDC_SetData(HTCFG_LEDC_COM_D3,  NumberChar[3]);
  8.       LEDC_SetData(HTCFG_LEDC_COM_D4,  NumberChar[0]);
  9.       gIsUpdateChar = FALSE;
  10.     }
  11.   }
图4  显示指定内容
