STM8S105xx 的片内DATA EEPROM块编程问题
1981|0
 楼主| yuluyiyi 发表于 2012-4-11 16:31 | 显示全部楼层 |阅读模式
用的是ST的固件库编程,部分代码如下:
FLASH_SetProgrammingTime(FLASH_PROGRAMTIME_STANDARD);
    /* Unlock Data memory */
    FLASH_Unlock(FLASH_MEMTYPE_DATA);
    /* Fill the buffer in RAM */
    for (i = 0; i < FLASH_BLOCK_SIZE; i++) GBuffer = new_val2;
    /* Program the block 0*/
    block = 0; /* block 0 is first block of Data memory: address is 0x4000 */
    FLASH_ProgramBlock(block, FLASH_MEMTYPE_DATA, FLASH_PROGRAMMODE_STANDARD, GBuffer);
  FLASH_WaitForLastOperation(FLASH_MEMTYPE_DATA);
编译没问题,点运行不报错,就是程序一直处于运行状态,点暂停的时候会出现遇到无效参数的提示,程序死机,重新编译运行,用单步发现程序在FLASH_ProgramBlock(block, FLASH_MEMTYPE_DATA, FLASH_PROGRAMMODE_STANDARD, GBuffer);
这里有问题,报错Stop...Error:  swim prog error [42004]: memory write error
不知道是什么问题
