[嵌入式linux] 龙迅LT8312一款低成本高性能的USB2.0扩展器
1519|0
 楼主| JLKJ18338421851 发表于 2022-9-24 10:39 | 显示全部楼层 |阅读模式
AN, ig, IO, TE
LT8312
1. 描述
LT8312是一款低成本高性能的USB2.0扩展器,具有DeMUX,通过USB电缆提供信号传输扩展,还支持信号旁路。LT8312符合USB2.0规范,支持USB2.0、USB1.1和USB1.0设备连接。从USB集线器/主机位置的最大延伸长度可达10米。只有一个USB2.0传输路径在同一时间工作。
2. 功能
•USB2.0信号扩展长达10米,通过USB电缆用于端口2
•端口1到端口3的USB2.0信号旁路
•支持USB2.0高速、全速、低速信号传输
•不同长度电缆的I2c模式均衡控制
•单路3.3V电源
3.应用程序
•个人电脑主板
•服务器和工作站
•KVM系统
•数据存储系统
•汽车系统
1. Description
LT8312 is a low cost high performance USB2.0 extender with DeMUX that provides signal transferring extension over USB cable and also supports signal bypass. Compliant with USB2.0 specification, the LT8312 supports USB2.0, USB1.1 and USB1.0 device connection. The maximum extension length can be up to 10m from the location of USB hub/host. There is only one USB2.0 transferring path working at the same time.
2. Feature
• USB2.0 signal extension up to 10m over USB cable for Port2
• USB2.0 signal bypass from Port1 to Port3
• Support USB2.0 high speed, full speed and low speed signal transferring
• I2c mode equalization control for different length cable
• Single 3.3V power supply
3. Applications
• PC Motherboard
• Servers and workstation
• KVM system
• Data storage system
• Car system
深圳市九黎科技有限公司是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!
