IPQ4019 IPQ4029 Quad core ARM Cortex A7 at 716.8 MHz Quectel support Industrial Wifi Router Wallys/DR40X9
The IPQ4019 was the industry's first single-chip Wi-Fi system-on-chip (SoC) to bring Wave-2 802.11ac features to a variety of home and enterprise networking products. The highly-integrated, single-chip design combines dual-band 11ac, advanced Wi-Fi features and network processing in a variety of configurations for high-performance, power-efficient and cost-effective network infrastructure products.
The IPQ4019 is an ultra low power SoC with integrated RF transceiver that supports both AC and DC link rates for high speed data transfers between client devices and access points. It also includes a sophisticated antenna control block with automatic gain control (AGC), multi antenna selection for diversity reception, adaptive antenna array pattern matching for multipath mitigation, transmit diversity support, and enhanced isolation mode with multiple failover algorithms.
The IPQ4019 is ideally suited for applications such as enterprise WLANs, residential gateways, industrial automation networks, video surveillance systems and other embedded solutions where low power consumption is critical.
Wallys Routerboard DR40X9 is an industrial-grade IPQ4019/IPQ4029 chipset with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module. It supports 4.940GHz to 5.825GHz frequency range, supports 2.400GHz to 2.482GHz, supports 2x 5G MMCX Connectors and 2x2.4G MMCX, supports 5MHz/10MHz/20MHz/40MHz/80MHz bandwidth, supports 11ABGN/AC, supports fixed data rate, RoHS compliance ensures a high level protection of human health and the environment from risks that can be posed by chemicals.
For more information about DR40X9,you can click the link below or email us. https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html
Wallys Communications (Suzhou ) Co., LTD is mainly engaged in the research and development and production of wireless communication products,such as Routerboard,Network Card,Industrial Wireless AP,Antenna etc.OEM/ODM/JDM services for customers supported.
With our experienced R&D engineer team,which with a demonstrated history of working in the wireless industry,you can explore the project with RF and embedded communications,network protocol,firmware,openwrt,linux system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout with us.
Welcome to email us for more information.
Email:sales1@wallystech.com Wallys Communications (SuZhou) Co.,Ltd www.wallystech.com
