AUTOOUT=1下,PC发来数据到OUT端,为什么空标志还是0?
2326|0
 楼主| yp19890718 发表于 2012-4-17 11:01 | 显示全部楼层 |阅读模式
pc, CD, FIFO, TE, se
void TD_Init(void)             // Called once at startup
   // set the CPU clock to 48MHz
   CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1);  //48M
   IFCONFIG |= 0x0B;//异步,从FIFO模式.
   PORTACFG|=0X40;
   FIFOPINPOLAR = 0x00; // set all slave FIFO interface pins as active low PKTEND OR SLOE SLWR LOW AVTIVE
   SYNCDELAY;
   REVCTL = 0x03;    // enable the external master
   SYNCDELAY;
   //reset the fifos
  FIFORESET = 0x80;
  SYNCDELAY;
  FIFORESET = 0x02;
  SYNCDELAY;
  FIFORESET = 0x04;
  SYNCDELAY;
  FIFORESET = 0x06;
  SYNCDELAY;
  FIFORESET = 0x08;
  SYNCDELAY;
  FIFORESET = 0x00;
  SYNCDELAY;
  //fix the slave fifo flags, only flagb and flagc
  //PINFLAGSAB = 0x89;  //F,FLAGB IS THE FIFO2 EMPTY FLAG,LAGA IS THE FIFO4 EMPTY FLAG
  //SYNCDELAY;
  PINFLAGSAB = 0xE8;  //FLAGC IS THE FIFO6 FULL  FLAG
  SYNCDELAY;
  // config the endpoints direction
  EP1OUTCFG = 0xA0;//enable and bulk type
  EP1INCFG = 0xA0;
  SYNCDELAY;                    // see TRM section 15.14
  EP8CFG = 0x60;
  SYNCDELAY;
  EP4CFG = 0x20;
  SYNCDELAY;
  EP6CFG = 0xe2;//enable IN bulk 512 DOUBLE buffer
  SYNCDELAY;
EP2CFG = 0xA2;
  SYNCDELAY;
  INPKTEND = 0x06;
  SYNCDELAY;
  INPKTEND = 0x06;
  SYNCDELAY;
  OUTPKTEND = 0x82;
  SYNCDELAY;
  OUTPKTEND = 0x82;
  SYNCDELAY;
    EP2BCL = 0x80;                // arm EP2OUT by writing byte count w/skip.
  SYNCDELAY;
  EP2BCL = 0x80;
  SYNCDELAY;
  EP2FIFOCFG = 0x11;//EP2 IS AUTOOUT=1 AUTOIN =0 ZEROLEN=0 WORDIDE=1 配置EP6自动方式16位总
  SYNCDELAY;
  //config the endpoint6
  EP6FIFOCFG = 0x0D;//EP6 IS AUTOOUT=0 AUTOIN =1 ZEROLEN=1 WORDIDE=1 配置EP6自动方式16位总
  SYNCDELAY;
  EP6AUTOINLENH = 0x02;   //set the packet size 512
  SYNCDELAY;
  EP6AUTOINLENL = 0x00;
  SYNCDELAY;
// SYNCDELAY;
  // since the defaults are double buffered we must write dummy byte counts twice
  //SYNCDELAY;
  /*EP2BCL = 0x80;                // arm EP8OUT by writing byte count w/skip.
  SYNCDELAY;
  EP2BCL = 0x80;   */
  SYNCDELAY;
  Rwuen = TRUE;
