我用的是STM32F030使用多通道DMA采集,发现F0芯片使用cubemx配置跟F1一样的,但是就是读值全都不对,原来F1没有遇到过这种问题,有用过的大神看下配置上有什么需要改的吗?之前有个帖子说自己添加通道,我也添加过了读值还是不对,只配置一个通道设置跟多通道一模一样读值就正确的,应该就是多通道添加有问题。
void MX_ADC_Init(void)
ADC_ChannelConfTypeDef sConfig = {0};
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc.Init.Resolution = ADC_RESOLUTION_12B;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc.Init.LowPowerAutoWait = DISABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = ENABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc.Init.DMAContinuousRequests = ENABLE;
hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
if (HAL_ADC_Init(&hadc) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
Error_Handler();
这个是添加通道设置
void init_ADCRank(void)
ADC_ChannelConfTypeDef sConfig;
HAL_ADC_ConfigChannel(&hadc, &sConfig);
