今天搞了一下HT1621模块。
DA接PC10,WR接PD9,CS接PF7。
代码:
- #include "main.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #define DA_PIN GPIO_PIN_10
- #define DA_GPIO_PORT GPIOC
- #define DA_GPIO_CLK_ENABLE() __HAL_RCC_GPIOC_CLK_ENABLE()
- #define DA_GPIO_CLK_DISABLE() __HAL_RCC_GPIOC_CLK_DISABLE()
- #define WR_PIN GPIO_PIN_9
- #define WR_GPIO_PORT GPIOD
- #define WR_GPIO_CLK_ENABLE() __HAL_RCC_GPIOD_CLK_ENABLE()
- #define WR_GPIO_CLK_DISABLE() __HAL_RCC_GPIOD_CLK_DISABLE()
- #define CS_PIN GPIO_PIN_7
- #define CS_GPIO_PORT GPIOF
- #define CS_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE()
- #define CS_GPIO_CLK_DISABLE() __HAL_RCC_GPIOF_CLK_DISABLE()
- #define CS_0 HAL_GPIO_WritePin(CS_GPIO_PORT,CS_PIN,GPIO_PIN_RESET)
- #define CS_1 HAL_GPIO_WritePin(CS_GPIO_PORT,CS_PIN,GPIO_PIN_SET)
- #define WR_0 HAL_GPIO_WritePin(WR_GPIO_PORT,WR_PIN,GPIO_PIN_RESET)
- #define WR_1 HAL_GPIO_WritePin(WR_GPIO_PORT,WR_PIN,GPIO_PIN_SET)
- #define DA_0 HAL_GPIO_WritePin(DA_GPIO_PORT,DA_PIN,GPIO_PIN_RESET)
- #define DA_1 HAL_GPIO_WritePin(DA_GPIO_PORT,DA_PIN,GPIO_PIN_SET)
- #define BIAS 0x52 //0b1000 0101 0010 1/3duty 4com
- #define SYSDIS 0X00 //0b1000 0000 0000 ???????LCD?????
- #define SYSEN 0X02 //0b1000 0000 0010 ???????
- #define LCDOFF 0X04 //0b1000 0000 0100 ?LCD??
- #define LCDON 0X06 //0b1000 0000 0110 ??LCD??
- #define XTAL 0x28 //0b1000 0010 1000 ?????
- #define RC256 0X30 //0b1000 0011 0000 ????
- #define WDTDIS1 0X0A //0b1000 0000 1010 ?????
- /* USER CODE END Includes */
- #define uchar unsigned char
- #define uint unsigned int
- /* USER CODE BEGIN PV */
- static GPIO_InitTypeDef GPIO_InitStruct;
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void SystemPower_Config(void);
- static void MX_ICACHE_Init(void);
- /* USER CODE BEGIN PFP */
- unsigned int tmp;
- unsigned int n1, n2, n3, n4;
- unsigned char Ht1621Tab[]={0x00,0x00,0x00,0x00};
- //unsigned char DispTab[]={0x7B,0x12,0x67,0x57,0x1E,0x5D,0x7D,0x13,0x7F,0x5F,0x69,0x45,0x3f, 0x7a, 0x3e};
- // 0 1 2 3 4 5 6 7 8 9 C ? A V H
- unsigned char DispTab[]={0x7B,0x12,0x67,0x57,0x1E,0x5D,0x7D,0x13,0x7F,0x5F,0x3F,0x7C,0x69,0x76,0x6D, 0x2D};
- // 0 1 2 3 4 5 6 7 8 9 A b C d E F
- void Ht1621_CS_0() { CS_0;} // define P2.2 ---> CS
- void Ht1621_CS_1() { CS_1;}
- void Ht1621_WR_0() { WR_0;} // define P2.1 ---> WR
- void Ht1621_WR_1() { WR_1;}
- void Ht1621_DO_0() { DA_0;} // define P2.0 ---> DAT
- void Ht1621_DO_1() { DA_1;}
- unsigned int counter;
- //????:Delay()
- void Delay(uint us) //5,7,9
- while(--us);
- //????:Delayms()
- void Delayms(unsigned int ims)
- unsigned int i,j;
- for(i=0;i<ims;i++)
- for(j=0;j<65;j++) { Delay(1); }
- //Ht1621Wr_Data()
- void Ht1621Wr_Data(unsigned char Data,unsigned char cnt)
- unsigned char i;
- for (i=0;i<cnt;i++)
- Ht1621_WR_0();
- HAL_Delay(1);
- if((Data & 0x80)==0x80) {Ht1621_DO_1();HAL_Delay(10);}
- else {Ht1621_DO_0();HAL_Delay(10);}
- Ht1621_WR_1();
- HAL_Delay(1);
- Data<<=1;
- //void Ht1621WrCmd(uchar Cmd)
- void Ht1621WrCmd(unsigned char Cmd)
- Ht1621_CS_0();
- HAL_Delay(1);
- Ht1621Wr_Data(0x80,4); //??????100
- Ht1621Wr_Data(Cmd,8); //??????
- Ht1621_CS_1();
- HAL_Delay(1);
- //void Ht1621WrOneData(uchar Addr,uchar Data)
- void Ht1621WrOneData(unsigned char Addr,unsigned char Data)
- Ht1621_CS_0();
- Ht1621Wr_Data(0xa0,3); //??????101
- Ht1621Wr_Data(Addr<<2,6); //??????
- Ht1621Wr_Data(Data,4); //???????? 7 6 5 4
- Ht1621_CS_1();
- //void Ht1621WrAllData()
- void Ht1621WrAllData(unsigned char Addr,unsigned char *p,unsigned char cnt)
- unsigned char i;
- Ht1621_CS_0();
- Ht1621Wr_Data(*p,8); //????
- p++;
- Ht1621_CS_1();
- //void Ht1621_Init(void)
- void Ht1621_Init(void)
- Ht1621WrCmd(BIAS);
- Ht1621WrCmd(RC256); //???????
- //Ht1621WrCmd(XTAL); //???????
- Ht1621WrCmd(SYSDIS);
- Ht1621WrCmd(WDTDIS1);
- Ht1621WrCmd(SYSEN);
- Ht1621WrCmd(LCDON);
- //DISPLAY
- void Display(void)
- unsigned char com;
- com = 0;
- if((DispTab[n1]&0x01) == 0x01){ com = com + 0x10;}
- if((DispTab[n2]&0x01) == 0x01){ com = com + 0x20;}
- if((DispTab[n3]&0x01) == 0x01){ com = com + 0x40;}
- if((DispTab[n4]&0x01) == 0x01){ com = com + 0x80;}
- Ht1621WrOneData(0 , com);
- com = 0;
- if((DispTab[n1]&0x02) == 0x02){ com = com + 0x10;}
- if((DispTab[n2]&0x02) == 0x02){ com = com + 0x20;}
- if((DispTab[n3]&0x02) == 0x02){ com = com + 0x40;}
- if((DispTab[n4]&0x02) == 0x02){ com = com + 0x80;}
- Ht1621WrOneData(1 , com);
- com = 0;
- if((DispTab[n1]&0x10) == 0x10){ com = com + 0x10;}
- if((DispTab[n2]&0x10) == 0x10){ com = com + 0x20;}
- if((DispTab[n3]&0x10) == 0x10){ com = com + 0x40;}
- if((DispTab[n4]&0x10) == 0x10){ com = com + 0x80;}
- Ht1621WrOneData(2 , com);
- com = 0;
- if((DispTab[n1]&0x40) == 0x40){ com = com + 0x10;}
- if((DispTab[n2]&0x40) == 0x40){ com = com + 0x20;}
- if((DispTab[n3]&0x40) == 0x40){ com = com + 0x40;}
- if((DispTab[n4]&0x40) == 0x40){ com = com + 0x80;}
- Ht1621WrOneData(3 , com);
- com = 0;
- if((DispTab[n1]&0x20) == 0x20){ com = com + 0x10;}
- if((DispTab[n2]&0x20) == 0x20){ com = com + 0x20;}
- if((DispTab[n3]&0x20) == 0x20){ com = com + 0x40;}
- if((DispTab[n4]&0x20) == 0x20){ com = com + 0x80;}
- Ht1621WrOneData(4 , com);
- com = 0;
- if((DispTab[n1]&0x08) == 0x08){ com = com + 0x10;}
- if((DispTab[n2]&0x08) == 0x08){ com = com + 0x20;}
- if((DispTab[n3]&0x08) == 0x08){ com = com + 0x40;}
- if((DispTab[n4]&0x08) == 0x08){ com = com + 0x80;}
- Ht1621WrOneData(5 , com);
- com = 0;
- if((DispTab[n1]&0x04) == 0x04){ com = com + 0x10;}
- if((DispTab[n2]&0x04) == 0x04){ com = com + 0x20;}
- if((DispTab[n3]&0x04) == 0x04){ com = com + 0x40;}
- if((DispTab[n4]&0x04) == 0x04){ com = com + 0x80;}
- Ht1621WrOneData(6 , com);
- //Display_lcd_dot
- void Display_lcd_dot(void)
- Ht1621WrOneData(7 , 0x50);
- //convertor()
- void data_convertor(unsigned long adc_value)
- tmp=adc_value; //adc
- n4=tmp/1000;
- n3=tmp%1000/100;
- n2=tmp%100/10;
- // 4
- n1=tmp%10; //display "C"
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * [url=home.php?mod=space&uid=247401]@brief[/url] The application entry point.
- * @retval int
- int main(void)
- /* USER CODE BEGIN 1 */
- /* STM32U5xx HAL library initialization:
- - Configure the Flash prefetch
- - Configure the Systick to generate an interrupt each 1 msec
- - Set NVIC Group Priority to 3
- - Low Level Initialization
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* Configure the System Power */
- SystemPower_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_ICACHE_Init();
- /* USER CODE BEGIN 2 */
- /* -1- Enable GPIO Clock (to be able to program the configuration registers) */
- LED1_GPIO_CLK_ENABLE();
- LED2_GPIO_CLK_ENABLE();
- DA_GPIO_CLK_ENABLE();
- WR_GPIO_CLK_ENABLE();
- CS_GPIO_CLK_ENABLE();
- /* -2- Configure IO in output push-pull mode to drive external LEDs */
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- GPIO_InitStruct.Pin = LED1_PIN;
- HAL_GPIO_Init(LED1_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = LED2_PIN;
- HAL_GPIO_Init(LED2_GPIO_PORT, &GPIO_InitStruct);
- /* USER CODE END 2 */
- GPIO_InitStruct.Pin = CS_PIN;
- HAL_GPIO_Init(CS_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = WR_PIN;
- HAL_GPIO_Init(WR_GPIO_PORT, &GPIO_InitStruct);
- GPIO_InitStruct.Pin = DA_PIN;
- HAL_GPIO_Init(DA_GPIO_PORT, &GPIO_InitStruct);
- /* Infinite loop */
- counter = 235;
- Ht1621_Init(); //?????LCD
- HAL_Delay(1000); //??????
- Ht1621WrAllData(0,Ht1621Tab,16);// Clear LCD display
- Ht1621_Init();
- data_convertor(counter);
- Display();
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- // counter = 235;
- // Ht1621_Init(); //?????LCD
- // Delay(1000); //??????
- // Ht1621WrAllData(0,Ht1621Tab,16);// Clear LCD display
- // Ht1621_Init();
- // data_convertor(counter);
- // Display();
- /* USER CODE BEGIN 3 */
- // HAL_GPIO_TogglePin(DA_GPIO_PORT,GPIO_PIN_10);
- // Delay(1000);
- /* Insert delay 100 ms */
- // HAL_GPIO_TogglePin(WR_GPIO_PORT,WR_PIN);
- // HAL_Delay(1000);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct = {0};
- RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
- /** Configure the main internal regulator output voltage
- if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
- Error_Handler();
- /** Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
- RCC_OscInitStruct.MSIState = RCC_MSI_ON;
- RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
- RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
- RCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
- RCC_OscInitStruct.PLL.PLLM = 1;
- RCC_OscInitStruct.PLL.PLLN = 80;
- RCC_OscInitStruct.PLL.PLLP = 2;
- RCC_OscInitStruct.PLL.PLLQ = 2;
- RCC_OscInitStruct.PLL.PLLR = 2;
- RCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_0;
- RCC_OscInitStruct.PLL.PLLFRACN = 0;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
- |RCC_CLOCKTYPE_PCLK3;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
- Error_Handler();
- * @brief Power Configuration
- * @retval None
- * Disable the internal Pull-Up in Dead Battery pins of UCPD peripheral
- HAL_PWREx_DisableUCPDDeadBattery();
- * Switch to SMPS regulator instead of LDO
- if (HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY) != HAL_OK)
- Error_Handler();
- * @brief ICACHE Initialization Function
- * @param None
- * @retval None
- /* USER CODE BEGIN ICACHE_Init 0 */
- /* USER CODE END ICACHE_Init 0 */
- /* USER CODE BEGIN ICACHE_Init 1 */
- /* USER CODE END ICACHE_Init 1 */
- /** Enable instruction cache in 1-way (direct mapped cache)
- if (HAL_ICACHE_ConfigAssociativityMode(ICACHE_1WAY) != HAL_OK)
- Error_Handler();
- if (HAL_ICACHE_Enable() != HAL_OK)
- Error_Handler();
- /* USER CODE BEGIN ICACHE_Init 2 */
- /* USER CODE END ICACHE_Init 2 */
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @retval None
- void Error_Handler(void)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- while (1)
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
效果图:
