[无线射频] NZ5760S-国民技术-射频pa
536|0
 楼主| 断桥不断 发表于 2023-2-23 15:18 | 显示全部楼层 |阅读模式
The NZ5760S is a SP2T (single-pole double-throw) switch designed for diversity applications from 100MHz to 3.0GHz. The RF performance is optimized with low insertion
loss to guarantee the stringent requirements of all 3G/LTE standards.
The NZ5760S integrates a SP2T switch and a GPIO controller on a single SOI chip.
Equipped with 2 symmetrical ports for UMTS/TD-SCDMA/LTE, the NZ5760S is providing the most versatile combinations of operation in different modes.
Low insertion loss is exhibited in every path in NZ5760S, from the antenna port to any
of the port, with high isolation between both OPPOsite and adjacent paths. The internal
decoder allows convenient GPIO connections and supports digital control signals. The
SOI architecture in NZ5760S reMOVes the external DC blocking capacitors to save the
cost and PCB space for end customers.
The NZ5760S is encapsulated in a compact 1.1mm x 1.1mm LGA package, with low
profile of 0.55mm. This product is RoHS-compliant and halogen free.
The NZ5760S is rated to Moisture Sensitivity Level 3(MSL3) at 260 °C per JEDEC JSTD-020
Features
• Broadband support 0.1-3.0GHz
• Compatible with UMTS, TDSCDMA, and LTE
• Advanced SOI process
• Low insertion loss
• Excellent linearity
• 2 symmetrical RF ports
• GPIO control interface
• No external DC blocking capacitor
required
• Small LGA footprint, 1.1mm x
1.1mm x 0.55mm, 9-pin
• Green product
Application
• Diversity for UMTS/LTE
