[modelsim] modelsim仿真的问题
1424|1
 楼主| 比神乐 发表于 2023-3-25 11:55 | 显示全部楼层 |阅读模式
我看夏宇闻老师的《Verilog 数字系统设计教程》第十一章例组合逻辑二一个三态数据通路控制器代码:
  1. `define ON 1'b1
  2. `define OFF 1'b0
  3. module zhlj2(LinkBusSwitch,outbuf,inbuf,bus,clk);
  4. input LinkBusSwitch;
  5. input[7:0] outbuf;
  6. output [7:0] inbuf;
  7. input clk;
  8. inout [7:0] bus;
  9. wire LinkBusSwitch;
  10. wire [7:0] outbuf;
  11. reg [7:0]  inbuf;
  12. wire [7:0]  bus;
  13. assign bus=(LinkBusSwitch == `ON)  ? outbuf : 8'hzz;
  14. always @(posedge clk)
  15.         begin
  16.                 if(!LinkBusSwitch)
  17.                         inbuf<=bus;
  18.         end
  19.
  20.
  21. endmodule
仿真代码:
  1. `timescale 1 ns/ 1 ps
  2. module zhlj2_vlg_tst();
  3. // constants
  4. // general purpose registers
  5. //reg eachvec;
  6. // test vector input registers
  7. //reg [7:0] treg_bus;
  8. reg clk;
  9. reg [7:0] outbuf;
  10. // wires
  11. reg LinkBusSwitch;
  12. wire [7:0]  bus;
  13. wire [7:0]  inbuf;
  14. // assign statements (if any)
  15. //assign bus = treg_bus;
  16. zhlj2 i1 (
  17. // port map - connection between master ports and signals/registers
  18.         .LinkBusSwitch(LinkBusSwitch),
  19.         .bus(bus),
  20.         .clk(clk),
  21.         .inbuf(inbuf),
  22.         .outbuf(outbuf)
  23. );
  24. initial
  25. begin
  26. // code that executes only once
  27. // insert code here --> begin
  28.         //begin
  29.                 LinkBusSwitch=0;
  30.                 clk=0;
  31.         //end
  32.         forever
  33.                 #5 clk=~clk;
  34. end
  35. // --> end
  36.    initial
  37.                 begin
  38.
  39.                         #20 outbuf=15;
  40.                         #20 outbuf=38;
  41.                         #20 LinkBusSwitch=1;
  42.
  43.                         #20 outbuf=122;
  44.                         #20 outbuf=238;
  45.                         #20 outbuf=72;
  46.
  47.                         #20 LinkBusSwitch=0;
  48.                         #20 outbuf=55;
  49.                         #20 outbuf=0;
  50.                         $finish;
  51.                 end
  52.
  53.
  54. endmodule
有一处波形不对,就是outbuf=238时,显示-18.
波形图如下:
请问高手,怎么回事?谢谢!
学习中  发表于 2023-4-26 11:04
