[通用8051核FLASH系列] 【芯圣电子HC89S105A测评报告】+TFT
2914|8
 楼主| 比神乐 发表于 2023-5-23 10:27 | 显示全部楼层 |阅读模式
今天搞了一下TFT.SCL接P0.1,SDA接P0.0,RES接P4.2,DC接P1.0,CS接P1.1,BL接P1.2
代码:
  1. #define ALLOCATE_EXTERN
  2. #include "HC89S105AC8.h"
  3. #define uchar unsigned char
  4. #define uint unsigned int
  5. /** @addtogroup 425_GPIO_led_toggle GPIO_led_toggle
  6.   * @{
  7.   */
  8. #define bl_1   P1_2=1
  9. #define bl_0   P1_2=0
  10. #define scl_1   P0_1=1
  11. #define scl_0   P0_1=0
  12. #define sda_1   P0_0=1
  13. #define sda_0   P0_0=0
  14. #define reset_1   P4_2=1
  15. #define reset_0   P4_2=0
  16. #define rs_1   P1_0=1
  17. #define rs_0   P1_0=0
  18. #define cs_1   P1_1=1
  19. #define cs_0   P1_1=0
  20. //?¨ò?3£ó???é?
  21. #define RED                  0xf800
  22. #define GREEN                0x07e0
  23. #define BLUE                 0x001f
  24. #define WHITE                0xffff
  25. #define BLACK                0x0000
  26. #define YELLOW  0xFFE0
  27. #define GRAY0   0xEF7D
  28. #define GRAY1   0x8410
  29. #define GRAY2   0x4208
  30. code unsigned char gImage_qq[];
  31. void delay_ms(uint time)
  32. {
  33. uint i,j;
  34.   for(i=0;i<time;i++)
  35.    for(j=0;j<250;j++);
  36. }
  37. void delay_us(uchar z)
  38. {
  39.         uchar i;
  40.         for(i=0;i<z;i++);
  41. }
  42. //?òSPI×ü??′?ê?ò???8??êy?Y
  43. void  SPI_WriteData(uchar Data)
  44. {
  45.         unsigned char i=0;
  46.         for(i=8;i>0;i--)
  47.         {
  48.                 if(Data&0x80)
  49.                 sda_1; //ê?3?êy?Y
  50.                 else sda_0;
  51.
  52.                 scl_0;
  53.
  54.                 scl_1;
  55.
  56.                 Data<<=1;
  57.         }
  58. }
  59. //?òòo?§?áD′ò???8????á?
  60. void  Lcd_WriteIndex(uchar Data)
  61. {
  62.
  63.                 cs_0;
  64.
  65.                 rs_0;
  66.
  67.                 SPI_WriteData(Data);
  68.
  69.                 cs_1;
  70.
  71. }
  72. //?òòo?§?áD′ò???8??êy?Y
  73. void  Lcd_WriteData(uchar Data)
  74. {
  75. //                unsigned char i=0;
  76.                 cs_0;
  77.
  78.                 rs_1;
  79.
  80.                 SPI_WriteData(Data);
  81.
  82.                 cs_1;
  83.
  84. }
  85. //?òòo?§?áD′ò???16??êy?Y
  86. void  LCD_WriteData_16Bit(unsigned int Data)
  87. {
  88. //        unsigned char i=0;
  89.         cs_0;
  90.
  91.         rs_1;
  92.
  93.         SPI_WriteData(Data>>8);         //D′è???8??êy?Y
  94.         SPI_WriteData(Data);                         //D′è?μí8??êy?Y
  95.
  96.         cs_1;
  97.
  98. }
  99. void Reset()
  100. {
  101.     reset_0;
  102.     delay_ms(100);
  103.     reset_1;
  104.     delay_ms(100);
  105. }
  106. //////////////////////////////////////////////////////////////////////////////////////////////
  107. //òo?§?á3?ê??ˉ for S6D02A1
  108. void lcd_initial()
  109. {        Reset();//Reset before LCD Init.
  110.
  111.         //LCD Init For 1.44Inch LCD Panel with ST7735R.
  112.         Lcd_WriteIndex(0x11);//Sleep exit
  113.         delay_ms (120);
  114.
  115. Lcd_WriteIndex(0x21);
  116. Lcd_WriteIndex(0xB1);
  117. Lcd_WriteData(0x05);
  118. Lcd_WriteData(0x3A);
  119. Lcd_WriteData(0x3A);
  120. Lcd_WriteIndex(0xB2);
  121. Lcd_WriteData(0x05);
  122. Lcd_WriteData(0x3A);
  123. Lcd_WriteData(0x3A);
  124. Lcd_WriteIndex(0xB3);
  125. Lcd_WriteData(0x05);
  126. Lcd_WriteData(0x3A);
  127. Lcd_WriteData(0x3A);
  128. Lcd_WriteData(0x05);
  129. Lcd_WriteData(0x3A);
  130. Lcd_WriteData(0x3A);
  131. Lcd_WriteIndex(0xB4);
  132. Lcd_WriteData(0x03);
  133. Lcd_WriteIndex(0xC0);
  134. Lcd_WriteData(0x62);
  135. Lcd_WriteData(0x02);
  136. Lcd_WriteData(0x04);
  137. Lcd_WriteIndex(0xC1);
  138. Lcd_WriteData(0xC0);
  139. Lcd_WriteIndex(0xC2);
  140. Lcd_WriteData(0x0D);
  141. Lcd_WriteData(0x00);
  142. Lcd_WriteIndex(0xC3);
  143. Lcd_WriteData(0x8D);
  144. Lcd_WriteData(0x6A);
  145. Lcd_WriteIndex(0xC4);
  146. Lcd_WriteData(0x8D);
  147. Lcd_WriteData(0xEE);
  148. Lcd_WriteIndex(0xC5);  /*VCOM*/
  149. Lcd_WriteData(0x0E);
  150. Lcd_WriteIndex(0xE0);
  151. Lcd_WriteData(0x10);
  152. Lcd_WriteData(0x0E);
  153. Lcd_WriteData(0x02);
  154. Lcd_WriteData(0x03);
  155. Lcd_WriteData(0x0E);
  156. Lcd_WriteData(0x07);
  157. Lcd_WriteData(0x02);
  158. Lcd_WriteData(0x07);
  159. Lcd_WriteData(0x0A);
  160. Lcd_WriteData(0x12);
  161. Lcd_WriteData(0x27);
  162. Lcd_WriteData(0x37);
  163. Lcd_WriteData(0x00);
  164. Lcd_WriteData(0x0D);
  165. Lcd_WriteData(0x0E);
  166. Lcd_WriteData(0x10);
  167. Lcd_WriteIndex(0xE1);
  168. Lcd_WriteData(0x10);
  169. Lcd_WriteData(0x0E);
  170. Lcd_WriteData(0x03);
  171. Lcd_WriteData(0x03);
  172. Lcd_WriteData(0x0F);
  173. Lcd_WriteData(0x06);
  174. Lcd_WriteData(0x02);
  175. Lcd_WriteData(0x08);
  176. Lcd_WriteData(0x0A);
  177. Lcd_WriteData(0x13);
  178. Lcd_WriteData(0x26);
  179. Lcd_WriteData(0x36);
  180. Lcd_WriteData(0x00);
  181. Lcd_WriteData(0x0D);
  182. Lcd_WriteData(0x0E);
  183. Lcd_WriteData(0x10);
  184. Lcd_WriteIndex(0x3A);
  185. Lcd_WriteData(0x05);
  186. Lcd_WriteIndex(0x36);
  187. Lcd_WriteData(0xC8);
  188. Lcd_WriteIndex(0x29);
  189. }
  190. /*************************************************
  191. oˉêy??£oLCD_Set_Region
  192. 1|?ü£oéè??lcd??ê???óò£??ú′???óòD′μ?êy?Y×??ˉ??DD
  193. è??ú2?êy£oxy?eμ?oí??μ?
  194. ·μ???μ£o?T
  195. *************************************************/
  196. void Lcd_SetRegion(unsigned int x_start,unsigned int y_start,unsigned int x_end,unsigned int y_end)
  197. {
  198.         Lcd_WriteIndex(0x2a);
  199.         Lcd_WriteData(0x00);
  200.         Lcd_WriteData(x_start+0x1A);
  201.         Lcd_WriteData(0x00);
  202.         Lcd_WriteData(x_end+0x1A);
  203.         Lcd_WriteIndex(0x2b);
  204.         Lcd_WriteData(0x00);
  205.         Lcd_WriteData(y_start+1);
  206.         Lcd_WriteData(0x00);
  207.         Lcd_WriteData(y_end+1);
  208.         Lcd_WriteIndex(0x2c);
  209. }
  210. void dsp_single_colour(int color)
  211. {
  212.          uchar i,j;
  213.         Lcd_SetRegion(0,0,80-1,160-1);
  214.          for (i=0;i<160;i++)
  215.             for (j=0;j<80;j++)
  216.                 LCD_WriteData_16Bit(color);
  217. }
  218. //è??£·?ê? ????é¨?è ′ó×óμ?óò μí???ú?°
  219. void showimage(const unsigned char *p) //??ê?40*40 QQí???
  220. {
  221.           int i,j,k;
  222.         unsigned char picH,picL;
  223.         dsp_single_colour(WHITE); //???á
  224.
  225.         for(k=0;k<4;k++)
  226.         {
  227.                    for(j=0;j<2;j++)
  228.                 {
  229.                         Lcd_SetRegion(40*j,40*k,40*j+39,40*k+39);                //×?±êéè??
  230.                     for(i=0;i<40*40;i++)
  231.                          {
  232.                                  picL=*(p+i*2);        //êy?Yμí???ú?°
  233.                                 picH=*(p+i*2+1);
  234.                                 LCD_WriteData_16Bit(picH<<8|picL);
  235.                          }
  236.                  }
  237.         }
  238. }
  239. /***************************************************************************************
  240.   * @实现效果        设置各个IO口的工作状态
  241. ***************************************************************************************/
  242. void main(void)
  243. {
  244. /********************************系统初始化*******************************************/
  245.         WDTCCR = 0x00;                           //关闭看门狗
  246.                                                            //本例程为方便测试关闭看门狗,实际使用中,建议客户打开看门狗,详见WDT复位例程
  247.         CLKCON = 0x02;                           //选择内部高频RC为系统时钟, Fosc=32MHz
  248.         CLKDIV = 0x02;                           //Fosc 2分频得到Fcpu,Fcpu=16MHz
  249.
  250. /***********************************设置IO口模式***************************************/
  251.
  252.         P0M0 = 0xCC;                                 //P32设置为带上拉开漏输出
  253.         P1M0 = 0xCC;                             //P34设置为推挽输出
  254.         P1M1 = 0xFC;                             //P34设置为推挽输出
  255.         P4M1 = 0xFC;
  256.
  257.         lcd_initial();
  258.         bl_1;
  259.         showimage(gImage_qq);
  260.
  261.         while(1)
  262.         {
  263.
  264.         }
  265. }
  266. //16??BMP 40X40 QQí???è??£êy?Y
  267. //Image2LCDè??£????éè??
  268. //????é¨?è
  269. //16??
  270. //40X40
  271. //2?°üo?í???í·êy?Y
  272. //×?×ó?áóò
  273. //×??¥?áμ×
  274. //μí???ú?°
  275. code unsigned char gImage_qq[3200] = { /*0X00,0X10,0X28,0X00,0X28,0X00,0X01,0X1B,*/
  276. 0XDB,0XDE,0X5D,0XEF,0X5D,0XEF,0X7D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
  277. 0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0XBE,0XF7,
  278. 0XFF,0XFF,0XDE,0XFF,0X38,0XC6,0X92,0X8C,0X8E,0X6B,0X6E,0X6B,0X10,0X7C,0X96,0XAD,
  279. 0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
  280. 0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,0X5D,0XEF,
  281. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  282. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X5D,0XEF,
  283. 0X15,0X9D,0X4F,0X63,0X6C,0X42,0X0A,0X32,0X88,0X29,0X46,0X19,0X25,0X19,0X45,0X21,
  284. 0XE8,0X31,0X8E,0X6B,0X18,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  285. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  286. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  287. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XF5,0X9C,0X0F,0X53,
  288. 0X10,0X4B,0X51,0X53,0X0F,0X4B,0X6C,0X3A,0XE9,0X31,0X67,0X21,0X25,0X19,0XE4,0X10,
  289. 0XA3,0X08,0X62,0X00,0X83,0X08,0X8A,0X4A,0X59,0XC6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  290. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  291. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  292. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X1C,0XE7,0X4F,0X5B,0XB3,0X63,0XB8,0X7C,
  293. 0XF5,0X63,0X11,0X43,0X4D,0X32,0XEA,0X29,0X88,0X21,0X26,0X19,0X05,0X19,0X05,0X19,
  294. 0X04,0X11,0X04,0X11,0XE4,0X10,0X83,0X00,0XA3,0X08,0X72,0X8C,0XFF,0XFF,0XFF,0XFF,
  295. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  296. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  297. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0X4B,0X3A,0XF0,0X42,0X35,0X6C,0X54,0X4B,
  298. 0XB1,0X32,0X2E,0X2A,0XEB,0X21,0XA9,0X21,0X67,0X19,0X05,0X19,0X04,0X11,0X04,0X11,
  299. 0X04,0X11,0X04,0X11,0X04,0X11,0X05,0X19,0XE4,0X10,0X42,0X00,0XAF,0X73,0XFF,0XFF,
  300. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  301. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  302. 0XFF,0XFF,0XFF,0XFF,0X5D,0XEF,0X09,0X32,0X4C,0X32,0X10,0X4B,0X8F,0X32,0X4F,0X2A,
  303. 0X2E,0X2A,0XCC,0X19,0X89,0X19,0X89,0X21,0X47,0X19,0X05,0X19,0X04,0X11,0X04,0X11,
  304. 0XC4,0X10,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0X42,0X00,0X31,0X84,
  305. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  306. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  307. 0XFF,0XFF,0XFF,0XFF,0XEC,0X52,0X47,0X19,0X4C,0X32,0X0B,0X2A,0XEC,0X21,0XEC,0X21,
  308. 0X0C,0X22,0X91,0X5B,0XEE,0X4A,0X06,0X11,0X26,0X19,0X04,0X19,0XE4,0X10,0XE4,0X10,
  309. 0XA7,0X29,0X66,0X21,0XA3,0X08,0X05,0X19,0X04,0X11,0X04,0X11,0XE4,0X10,0X82,0X00,
  310. 0XF7,0XBD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  311. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  312. 0XFF,0XFF,0X35,0XA5,0X83,0X08,0X88,0X21,0X88,0X21,0X89,0X21,0XAA,0X21,0X8A,0X21,
  313. 0X6B,0X42,0X71,0X8C,0XFF,0XFF,0X72,0X8C,0X83,0X08,0X04,0X11,0XC4,0X08,0X29,0X42,
  314. 0XFB,0XDE,0X5D,0XEF,0XEC,0X5A,0X83,0X08,0X04,0X11,0X04,0X11,0X04,0X11,0X83,0X08,
  315. 0XE8,0X31,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  316. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  317. 0XBE,0XF7,0XC7,0X31,0XC4,0X10,0X25,0X19,0X26,0X19,0X47,0X19,0X47,0X19,0XA8,0X29,
  318. 0X8A,0X52,0X28,0X4A,0X55,0XAD,0XFF,0XFF,0XE8,0X31,0XA3,0X08,0X05,0X19,0X4D,0X6B,
  319. 0X4D,0X6B,0XFF,0XFF,0X7D,0XEF,0X45,0X21,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,
  320. 0X62,0X00,0X76,0XAD,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  321. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  322. 0X96,0XB5,0X62,0X00,0X04,0X11,0X04,0X19,0X05,0X11,0X05,0X19,0XC4,0X08,0X8B,0X4A,
  323. 0XB6,0XB5,0X5D,0XEF,0XF7,0XBD,0XFF,0XFF,0X8E,0X6B,0X62,0X00,0X29,0X42,0XAA,0X5A,
  324. 0X08,0X42,0XFF,0XFF,0XFF,0XFF,0XCC,0X52,0X83,0X08,0X04,0X11,0X04,0X11,0X04,0X11,
  325. 0XA3,0X08,0XAD,0X52,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  326. 0XBE,0XF7,0XFF,0XFF,0XDF,0XFF,0XDB,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  327. 0X4E,0X63,0X62,0X00,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0X62,0X00,0X8E,0X63,
  328. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XCF,0X73,0X01,0X00,0XF3,0X9C,0X2C,0X63,
  329. 0X96,0XB5,0XFF,0XFF,0XFF,0XFF,0X2D,0X5B,0X83,0X00,0X04,0X11,0X04,0X11,0X04,0X11,
  330. 0XE4,0X10,0X67,0X21,0X3D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  331. 0XB7,0XB5,0X76,0XAD,0X7D,0XEF,0XCB,0X52,0XB3,0X94,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,
  332. 0XE8,0X31,0XA3,0X08,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0XA3,0X08,0X49,0X42,
  333. 0XFF,0XF7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0X6A,0X4A,0X01,0X00,0X72,0X84,0XFF,0XFF,
  334. 0XFF,0XFF,0XFF,0XF7,0XDF,0XEF,0X09,0X3A,0XA3,0X08,0X04,0X11,0X04,0X11,0X04,0X11,
  335. 0X04,0X11,0X05,0X11,0X18,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  336. 0XF0,0X7B,0X62,0X00,0XE8,0X31,0XC7,0X31,0X41,0X00,0X35,0XA5,0XFF,0XFF,0X5D,0XEF,
  337. 0X46,0X21,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0XE4,0X10,0XA3,0X08,
  338. 0X76,0X9D,0XFF,0XF7,0XFF,0XFF,0XB7,0XAD,0XA3,0X08,0XA3,0X08,0XC7,0X31,0X9E,0XE7,
  339. 0XFF,0XF7,0XFF,0XF7,0X76,0XA5,0XA3,0X08,0XE4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,
  340. 0X05,0X11,0X05,0X11,0X35,0XA5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  341. 0XDB,0XDE,0XA7,0X29,0X83,0X00,0XC4,0X10,0XC4,0X10,0XC4,0X10,0X1C,0XE7,0X9E,0XEF,
  342. 0X05,0X11,0XE4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X19,0XC4,0X08,
  343. 0XE5,0X10,0XD1,0X6B,0XD1,0X6B,0XC5,0X08,0X64,0X00,0XA5,0X08,0X43,0X00,0X2B,0X32,
  344. 0X77,0X9D,0XB3,0X84,0X25,0X19,0XC4,0X10,0X04,0X11,0X04,0X11,0X04,0X11,0X04,0X11,
  345. 0X25,0X19,0X26,0X09,0X35,0X9D,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  346. 0XFF,0XFF,0XAF,0X73,0X62,0X00,0X04,0X19,0X05,0X19,0X82,0X00,0X0D,0X5B,0X8E,0X9B,
  347. 0X62,0X10,0X05,0X11,0X04,0X11,0X04,0X11,0X04,0X19,0XE4,0X10,0X85,0X00,0X05,0X11,
  348. 0XC4,0X39,0X81,0X5A,0X40,0X7B,0X22,0X9C,0X43,0XAC,0X03,0XA4,0X83,0X9B,0X82,0X72,
  349. 0X82,0X49,0XC2,0X18,0XA4,0X00,0XC5,0X00,0XE4,0X10,0X04,0X19,0X04,0X11,0X05,0X19,
  350. 0X47,0X19,0X67,0X11,0XEC,0X5A,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  351. 0XDF,0XFF,0XDB,0XD6,0XC4,0X10,0XE4,0X10,0X04,0X11,0X05,0X11,0XA4,0X18,0X01,0XC0,
  352. 0X83,0X88,0XE4,0X00,0X05,0X19,0X04,0X19,0XC5,0X08,0X44,0X21,0X43,0X83,0X23,0XD5,
  353. 0X42,0XFE,0XE4,0XFE,0X27,0XFF,0X07,0XFF,0XA4,0XFE,0X64,0XFE,0X03,0XFE,0XA3,0XFD,
  354. 0XE2,0XFC,0X42,0XEC,0X83,0XB3,0X24,0X62,0XE5,0X10,0XC4,0X08,0X04,0X19,0X26,0X19,
  355. 0XA8,0X19,0X87,0X21,0X00,0X90,0XD3,0XBC,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  356. 0X5D,0XEF,0XFF,0XFF,0XF0,0X7B,0X42,0X00,0X05,0X19,0X05,0X11,0X83,0X28,0X01,0XD0,
  357. 0X44,0XF8,0XA3,0X48,0XE4,0X00,0XC5,0X08,0X44,0X5A,0X02,0XED,0XE2,0XFD,0X02,0XFE,
  358. 0X66,0XFE,0X74,0XFF,0XB8,0XFF,0X73,0XFF,0XE7,0XF6,0XA6,0XF6,0X45,0XF6,0XA4,0XF5,
  359. 0XC3,0XFC,0X62,0XFC,0XC2,0XFC,0XC2,0XFC,0XE3,0XCB,0XC4,0X49,0X06,0X11,0X88,0X19,
  360. 0X87,0X01,0XA4,0X90,0X01,0XF8,0XEC,0X9A,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  361. 0X5D,0XEF,0XFF,0XFF,0X9E,0XF7,0XE8,0X31,0X83,0X00,0X05,0X09,0X82,0X40,0X01,0XC0,
  362. 0X23,0XF8,0X85,0XF0,0XA3,0X48,0XA4,0X00,0X44,0X5A,0X02,0XFD,0X23,0XCC,0XC2,0XDC,
  363. 0X04,0XFE,0X28,0XFE,0X48,0XF6,0X46,0XF6,0X24,0XF6,0XE4,0XF5,0X64,0XFD,0XE3,0XFC,
  364. 0X62,0XFC,0XC2,0XFC,0X02,0XE4,0X02,0XDC,0XE2,0XFC,0XA4,0X7A,0X48,0X01,0X67,0X01,
  365. 0XC4,0X78,0X24,0XF8,0X02,0XF8,0X84,0XB0,0X7D,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  366. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XDB,0XDE,0X25,0X19,0XA3,0X00,0XC4,0X38,0X02,0XE0,
  367. 0X22,0XD8,0X44,0XF8,0XA6,0XF8,0XA4,0X78,0X63,0X00,0X43,0X21,0X83,0X72,0X83,0X39,
  368. 0X82,0X9B,0X21,0XF5,0X61,0XFD,0X22,0XFD,0XE2,0XFC,0XA2,0XFC,0X42,0XFC,0X42,0XFC,
  369. 0X42,0XFC,0X22,0XAB,0X83,0X41,0XC3,0X92,0X04,0X52,0X26,0X01,0X25,0X19,0XA4,0X98,
  370. 0X44,0XF8,0X23,0XF8,0X02,0XF8,0XA4,0XD0,0X9E,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  371. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9A,0XD6,0X87,0X29,0XA5,0X00,0X43,0XB8,
  372. 0X22,0XF8,0X23,0XE0,0X65,0XF8,0XE8,0XF8,0X07,0XC9,0X83,0X48,0X42,0X00,0XA3,0X00,
  373. 0X84,0X00,0X63,0X29,0XA2,0X7A,0X62,0XB3,0XA2,0XCB,0X62,0XD3,0X02,0XBB,0X82,0X8A,
  374. 0X83,0X39,0XA4,0X00,0XE5,0X00,0XE5,0X00,0XE5,0X08,0XC4,0X60,0X64,0XD8,0X44,0XF8,
  375. 0X24,0XF8,0X23,0XF8,0X02,0XF8,0X83,0X88,0XDB,0XC6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  376. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3D,0XE7,0X50,0X5B,0X08,0X31,
  377. 0X23,0XE8,0X43,0XF8,0X44,0XF0,0X65,0XF8,0X09,0XF9,0XAB,0XF9,0X89,0XD1,0X06,0X89,
  378. 0XA3,0X48,0X42,0X18,0X02,0X00,0X42,0X00,0X61,0X00,0X82,0X00,0X62,0X00,0X62,0X00,
  379. 0X83,0X00,0XA3,0X20,0XC4,0X50,0XA5,0X88,0X85,0XD8,0X65,0XF8,0X44,0XF8,0X44,0XF8,
  380. 0X23,0XF8,0X23,0XF8,0X03,0XD0,0X82,0X10,0XC7,0X29,0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,
  381. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X6C,0X32,
  382. 0XA5,0X38,0X02,0XD8,0X23,0XF8,0X65,0XF8,0X66,0XF8,0XA7,0XF8,0X4A,0XF9,0X0C,0XFA,
  383. 0X4D,0XFA,0X4C,0XEA,0X0B,0XD2,0XA9,0XB9,0X68,0XB1,0X47,0XA9,0X27,0XB1,0X07,0XB9,
  384. 0X07,0XD1,0XE7,0XE8,0XC7,0XF8,0XA7,0XF8,0X65,0XF8,0X65,0XF8,0X44,0XF8,0X23,0XF8,
  385. 0X03,0XF8,0X02,0XD0,0XA3,0X28,0X05,0X09,0XC4,0X08,0XEC,0X5A,0XFF,0XFF,0XFF,0XFF,
  386. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XDE,0X05,0X19,
  387. 0XC4,0X00,0XA7,0X41,0XE6,0XC0,0X03,0XF8,0X86,0XF8,0XA7,0XF8,0X87,0XF8,0X86,0XF8,
  388. 0XC7,0XF8,0X29,0XF9,0X8A,0XF9,0XAB,0XF9,0XAB,0XF9,0X8B,0XF9,0X6A,0XF9,0X29,0XF9,
  389. 0X08,0XF9,0XC7,0XF8,0XA6,0XF8,0X86,0XF8,0X65,0XF8,0X64,0XF8,0X23,0XF8,0X02,0XF0,
  390. 0X06,0XB1,0X25,0X29,0XE4,0X00,0XE4,0X10,0X25,0X19,0X25,0X19,0X14,0X9D,0XFF,0XFF,
  391. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X96,0XAD,0X62,0X00,
  392. 0X82,0X08,0X35,0X95,0XBA,0XCE,0X8B,0XA2,0X44,0XD0,0X25,0XF8,0X87,0XF8,0XA7,0XF8,
  393. 0XC7,0XF8,0XA7,0XF8,0X87,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X87,0XF8,0XA7,0XF8,
  394. 0XA7,0XF8,0XA6,0XF8,0X85,0XF8,0X65,0XF8,0X64,0XF8,0X24,0XF0,0X64,0XB8,0X0D,0X93,
  395. 0XBB,0XB6,0XCF,0X63,0X83,0X08,0X04,0X11,0XE4,0X10,0X66,0X21,0X49,0X3A,0X5D,0XEF,
  396. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XD3,0X94,0X42,0X00,
  397. 0XE4,0X10,0XBB,0XCE,0XFF,0XFF,0XBE,0XE7,0X76,0XB5,0XCC,0XAA,0X07,0XC1,0X45,0XE0,
  398. 0X45,0XF8,0X46,0XF8,0X66,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X86,0XF8,0X65,0XF8,
  399. 0X45,0XF8,0X65,0XF8,0X65,0XE8,0X44,0XD0,0X43,0XA8,0X01,0X88,0X82,0X90,0X3C,0XD7,
  400. 0XFF,0XEF,0X55,0X95,0X83,0X08,0X04,0X11,0X04,0X11,0X05,0X19,0X46,0X19,0XB3,0X94,
  401. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XB3,0X94,0X41,0X00,
  402. 0X86,0X21,0X5D,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XE7,0X7A,0XC6,0XD3,0XB4,
  403. 0X4E,0XB3,0X2A,0XC2,0X68,0XD1,0XE6,0XE0,0XA6,0XE8,0XA5,0XE8,0XA5,0XE8,0XE6,0XD8,
  404. 0X88,0XC9,0X06,0XA9,0X22,0XA8,0X02,0XA8,0X00,0XA0,0X00,0XC8,0X00,0XD8,0XF7,0XE5,
  405. 0XFF,0XE7,0XF8,0XAD,0XC4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X05,0X11,0X8B,0X4A,
  406. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X55,0XA5,0X41,0X00,
  407. 0XA7,0X29,0X5D,0XDF,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  408. 0XFF,0XEF,0X7D,0XDF,0XDB,0XCE,0X59,0XCE,0XF8,0XCD,0XD7,0XCD,0XF7,0XC5,0X79,0XCE,
  409. 0XFB,0XBE,0XAB,0XA2,0X03,0XF0,0X45,0XF8,0X42,0XD0,0X43,0XE8,0X00,0XF0,0X72,0XD4,
  410. 0XFF,0XDF,0X39,0XAE,0XE4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X05,0X11,0X87,0X29,
  411. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X59,0XCE,0X83,0X08,
  412. 0X46,0X21,0X1C,0XD7,0XFF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  413. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  414. 0XFF,0XEF,0X8B,0XBA,0X04,0XF8,0X45,0XF8,0X62,0XE0,0X44,0XF0,0X00,0XF8,0X8E,0XDB,
  415. 0XFF,0XDF,0XF8,0XA5,0XC4,0X10,0XE4,0X10,0XE4,0X10,0X04,0X11,0XE4,0X10,0X25,0X19,
  416. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0X87,0X29,
  417. 0X83,0X08,0X39,0XB6,0XFF,0XF7,0XDF,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  418. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  419. 0XBE,0XE7,0X4A,0XBA,0X03,0XF8,0X45,0XF8,0X64,0XF8,0X44,0XF8,0X00,0XF8,0X6E,0XE3,
  420. 0XFF,0XD7,0XF4,0X8C,0X83,0X08,0X04,0X11,0XE4,0X10,0XE4,0X10,0XE4,0X10,0X05,0X19,
  421. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XEF,0X73,
  422. 0X00,0X00,0X72,0X84,0XFF,0XEF,0XBE,0XEF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  423. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  424. 0XDF,0XE7,0X8B,0XBA,0X03,0XF8,0X45,0XF8,0X45,0XF8,0X23,0XF8,0X00,0XF8,0XD3,0XD4,
  425. 0XFF,0XD7,0X4E,0X5B,0X21,0X00,0X29,0X3A,0X55,0XA5,0X83,0X08,0XC4,0X10,0X25,0X19,
  426. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XDE,
  427. 0XA3,0X08,0XE8,0X31,0X9E,0XDF,0X9E,0XE7,0XBF,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  428. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  429. 0XFF,0XF7,0X51,0XBC,0X02,0XE0,0X03,0XF8,0X03,0XF0,0X43,0XE0,0XEC,0XC2,0X7E,0XCF,
  430. 0XFC,0XBE,0X46,0X21,0X21,0X00,0XD3,0X94,0XFF,0XFF,0X51,0X84,0X00,0X00,0X87,0X29,
  431. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  432. 0X51,0X84,0X00,0X00,0XF4,0X8C,0XFF,0XEF,0X9E,0XE7,0XBF,0XEF,0XDF,0XFF,0XFF,0XFF,
  433. 0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  434. 0XFF,0XFF,0X3D,0XDF,0X55,0XBD,0X52,0XBC,0X72,0XBC,0XB7,0XB5,0X5D,0XC7,0XFF,0XDF,
  435. 0XF0,0X6B,0X00,0X00,0X09,0X3A,0XBF,0XF7,0XFF,0XFF,0XFF,0XFF,0X14,0X9D,0X55,0XA5,
  436. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  437. 0XFF,0XFF,0XAC,0X4A,0XA4,0X08,0XBB,0XBE,0XDF,0XE7,0X7E,0XE7,0XBE,0XEF,0XDF,0XF7,
  438. 0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  439. 0XDF,0XFF,0XDF,0XF7,0XFF,0XEF,0XDF,0XDF,0XBF,0XD7,0X9E,0XD7,0XDF,0XDF,0XD8,0XA5,
  440. 0X83,0X08,0X26,0X11,0XDB,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  441. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  442. 0X79,0XEE,0X8B,0XDC,0X21,0X31,0XA9,0X21,0X3D,0XCF,0XBF,0XDF,0X7E,0XDF,0X9E,0XE7,
  443. 0XBE,0XEF,0XBF,0XEF,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XDF,0XF7,0XBF,0XEF,
  444. 0XBE,0XEF,0X9E,0XE7,0X7E,0XDF,0X5E,0XD7,0X5E,0XD7,0XDF,0XDF,0X9A,0XB6,0X26,0X19,
  445. 0X42,0X08,0XED,0XA3,0XBF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  446. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X74,0XDD,
  447. 0XC0,0XDB,0X00,0XFE,0X42,0XEE,0X02,0X42,0X89,0X21,0X7B,0XB6,0XDF,0XDF,0X7E,0XD7,
  448. 0X7E,0XDF,0X7E,0XDF,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X9E,0XE7,0X7E,0XDF,
  449. 0X7E,0XDF,0X5D,0XD7,0X5D,0XD7,0X9E,0XDF,0XFF,0XE7,0XF8,0XA5,0X07,0X11,0XE3,0X18,
  450. 0X02,0XC5,0X60,0XFD,0XE6,0XD3,0XDB,0XEE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  451. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9E,0XF7,0X84,0XBA,
  452. 0XC1,0XFC,0X42,0XFE,0X82,0XFE,0XA2,0XFE,0X81,0X83,0X45,0X21,0X74,0X74,0X5E,0XC7,
  453. 0XDF,0XDF,0X7E,0XD7,0X5E,0XD7,0X5D,0XD7,0X5E,0XD7,0X5E,0XD7,0X5D,0XD7,0X5D,0XD7,
  454. 0X5E,0XD7,0X9E,0XDF,0XFF,0XE7,0X3D,0XC7,0XF1,0X63,0X84,0X08,0X42,0X52,0X26,0XE6,
  455. 0X29,0XFF,0X86,0XFE,0XE0,0XF3,0X6A,0XC3,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  456. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X18,0XDE,0XC1,0XD2,
  457. 0XA2,0XFD,0X22,0XFE,0X42,0XFE,0X42,0XFE,0X62,0XFE,0XE2,0XD4,0X41,0X6A,0X49,0X42,
  458. 0X53,0X74,0X3B,0XA6,0X3E,0XC7,0XBF,0XD7,0XBF,0XD7,0XBF,0XD7,0XBF,0XDF,0XBF,0XD7,
  459. 0X3E,0XC7,0X1A,0XA6,0XF2,0X63,0XA7,0X29,0X82,0X41,0X22,0XB4,0X62,0XFE,0X83,0XFE,
  460. 0XAA,0XFE,0X0F,0XFF,0X67,0XFD,0X63,0XBA,0X3C,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  461. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X9A,0XE6,0X80,0XD2,
  462. 0X21,0XFD,0XC2,0XFD,0XE2,0XF5,0XC2,0XF5,0X82,0XF5,0X82,0XFD,0X62,0XFD,0X61,0XDC,
  463. 0X21,0X9B,0X84,0X6A,0XE9,0X6A,0X2C,0X63,0XAF,0X63,0X11,0X74,0X6E,0X63,0X2C,0X63,
  464. 0X89,0X5A,0X04,0X52,0X81,0X7A,0XC2,0XCB,0XE2,0XFC,0X62,0XFD,0X82,0XFD,0XC2,0XFD,
  465. 0XC2,0XFD,0XE4,0XFD,0X24,0XFD,0X62,0XCA,0X1C,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  466. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XB1,0XCC,
  467. 0X81,0XD2,0XC0,0XF3,0XC1,0XFC,0X02,0XFD,0X02,0XFD,0XE2,0XFC,0XC2,0XFC,0XC2,0XFC,
  468. 0X81,0XFC,0X80,0XFB,0XC0,0XC9,0XA4,0X81,0X35,0XAD,0X59,0XCE,0X71,0X9C,0X21,0X81,
  469. 0X00,0XDA,0XA1,0XFB,0X82,0XFC,0XA2,0XFC,0X82,0XFC,0XA2,0XFC,0X02,0XFD,0X22,0XFD,
  470. 0XE2,0XFC,0X00,0XFC,0X60,0XDA,0X90,0XCC,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  471. 0X5D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  472. 0X59,0XDE,0X0D,0XC4,0X06,0XCB,0XE4,0XD2,0X03,0XDB,0X03,0XDB,0XE3,0XDA,0XC3,0XD2,
  473. 0XA4,0XC2,0X09,0XB3,0XD2,0XBC,0X9E,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XE6,
  474. 0X0E,0XB4,0XA6,0XBA,0X83,0XD2,0XE3,0XE2,0X02,0XEB,0X22,0XEB,0X22,0XE3,0X03,0XDB,
  475. 0XE4,0XD2,0X6A,0XC3,0XB6,0XD5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
  476. };
效果图:
拍的效果不太好。
chenqianqian 发表于 2023-6-11 19:43 来自手机 | 显示全部楼层
IIC控制LCD屏幕,速率有点慢啊。
guijial511 发表于 2023-6-13 23:10 来自手机 | 显示全部楼层
图画看不清,另外IIC刷这个屏太慢了吧
 楼主| 比神乐 发表于 2023-6-14 10:28 | 显示全部楼层
图画看不清,另外IIC刷这个屏太慢了吧
不是I2C,是SPI,你没仔细看程序吧
lajdfla001 发表于 2023-6-19 18:01 | 显示全部楼层
这个速度太慢吧
kjkujkj22 发表于 2023-6-19 18:56 | 显示全部楼层
这个速度很好的。很棒的。
hjl714016 发表于 2023-11-2 17:30 | 显示全部楼层
用8080快一点
 楼主| 比神乐 发表于 2023-11-3 08:51 | 显示全部楼层
8080什么意思?请指教
 楼主| 比神乐 发表于 2023-11-3 08:52 | 显示全部楼层
找到了,是个显示屏
