#define ALLOCATE_EXTERN #include "HC89S105AC8.h" #define uint8_t unsigned char #define uint16_t unsigned int #define Hang_00_L P1_0=0 #define Hang_00_H P1_0=1 #define Hang_01_L P1_1=0 #define Hang_01_H P1_1=1 #define Hang_02_L P1_2=0 #define Hang_02_H P1_2=1 #define Hang_03_L P1_3=0 #define Hang_03_H P1_3=1 #define Lie_00_V P1_4 #define Lie_01_V P1_5 #define Lie_02_V P1_6 #define Lie_03_V P1_7 #define Lie_04_V ((P1&0xF0)>>4) #define Hang_10_L P1_4=0 #define Hang_10_H P1_4=1 #define Hang_11_L P1_5=0 #define Hang_11_H P1_5=1 #define Hang_12_L P1_6=0 #define Hang_12_H P1_6=1 #define Hang_13_L P1_7=0 #define Hang_13_H P1_7=1 #define Lie_10_V P1_0 #define Lie_11_V P1_1 #define Lie_12_V P1_2 #define Lie_13_V P1_3 #define Lie_14_V ((P1&0x0f)<<4) #define jpys 20 //??????jpys==20????????? uint8_t cord_h,cord_l;//??????? uint8_t temp; unsigned char guc_Uartflag = 0; //UART判断标志位 unsigned char guc_Uartcnt = 0; //UART计数使用 unsigned char guc_Uartbuf_a[5] = {0}; //用于存放接和收收据 unsigned char guc_i; uint8_t txBuf[] = "Key Value = : \r\n"; //发送数据计数 void DelayMs(uint16_t nms) { uint16_t i,j; for(i=0;i<nms;i++) for(j=0;j<200;j++); } void PORT_Initialize1(void) { P1M0=0xcc; P1M1=0xcc; P1M2=0x22; P1M3=0x22; } void PORT_Initialize2(void) { P1M0=0x22; P1M1=0x22; P1M2=0xcc; P1M3=0xcc; } unsigned char KeyScan(void) //???????????????? { uint16_t i,j; PORT_Initialize1(); for(i=0;i<1250;i++); Hang_00_L; Hang_01_L; Hang_02_L; Hang_03_L; for(i=0;i<1250;i++); //cord_h=(Lie_04_V&0x0f); cord_h=(uint8_t)(Lie_04_V); //cord_h=Lie_01_V|Lie_02_V|Lie_03_V|Lie_04_V; if(cord_h != 0xf0) //????????? { DelayMs(10); //?? cord_h=(uint8_t)(Lie_04_V); if(cord_h!=0xf0) { cord_h=(uint8_t)(Lie_04_V); //????? for(i=0;i<1250;i++); PORT_Initialize2(); for(i=0;i<1250;i++); if((cord_h&0x01)==0x01) Hang_10_H; else Hang_10_L; if((cord_h&0x02)==0x02) Hang_11_H; else Hang_11_L; if((cord_h&0x04)==0x04) Hang_12_H; else Hang_12_L; if((cord_h&0x08)==0x08) Hang_13_H; else Hang_13_L; for(i=0;i<1250;i++); cord_l=(uint8_t)(Lie_14_V); //????? while(1) //??????? { j=(uint8_t)(Lie_14_V); if(j==0xF0) break; for(i=0;i<1250;i++); } return(cord_h+cord_l);//???????? } } return(0xff); //????*/ } unsigned char KeyPro(void) { switch(KeyScan()) { case 0x7e:return 0;break;//0 ?????????????? case 0x7d:return 1;break;//1 case 0x7b:return 2;break;//2 case 0x77:return 3;break;//3 case 0xbe:return 4;break;//4 case 0xbd:return 5;break;//5 case 0xbb:return 6;break;//6 case 0xb7:return 7;break;//7 case 0xde:return 8;break;//8 case 0xdd:return 9;break;//9 case 0xdb:return 10;break;//a case 0xd7:return 11;break;//b case 0xee:return 12;break;//c case 0xed:return 13;break;//d case 0xeb:return 14;break;//e case 0xe7:return 15;break;//f default:return 0xff;break; } } /*************************************************************************************** * @实现效果 UART1接收到上位机发送的数据后,把接收的数据再次发送给上位机 * @注意 波特率1200,8位数据,无校验位 ***************************************************************************************/ void main(void) { uint8_t i; /********************************系统初始化*******************************************/ WDTCCR = 0x00; //关闭看门狗 //本例程为方便测试关闭看门狗,实际使用中,建议客户打开看门狗,详见WDT复位例程 CLKCON = 0x02; //选择内部高频RC为系统时钟,Fosc=32MHz CLKDIV = 0x02; //Fosc 2分频得到Fper,Fper=16MHz /**********************************IO配置初始化**************************************/ P0M0 = P0M0&0xF0|0x02; //P00设置为上拉输入 P0M0 = P0M0&0x0F|0x80; //P01设置为推挽输出 /**********************************UART配置初始化**************************************/ TXD_MAP = 0x01; //TXD映射P01 RXD_MAP = 0x00; //RXD映射P00 //8位数据发送,波特率1200 //波特率计算 //波特率 = 1/16 * 时钟源频率 / (65536 - 0xFCBE) // = 1/16 * 16000000 / 834) // = 1199.04(误差0.05%) //波特率1200 //反推初值 //初值 = (65536 - (Fper / 波特率) * (1 / 16)) // = (65536 - (16000000 / 1200) * (1 / 16)) // = (65536 - 833.33) // = FCBE SBRTH = 0xFCBE/256; SBRTL = 0xFCBE%256; SCON2 = 0x12; //8位UART 独立波特率,波特率可变 SCON = 0x10; //开串口接收 //IE = 0x10; //使能串口中断 //EA = 1; //使能总中断 while(1) { // if(guc_Uartflag) // { // IE &=~ 0x10; //失能UART1中断 // for(guc_i= 0;guc_i<guc_Uartcnt;guc_i++) // { // SBUF = guc_Uartbuf_a[guc_i]; //发送数据 // while(!(SCON&0x02)); // SCON &=~ 0x02; //发送中断请求中断标志位清0 // } // guc_Uartflag = 0; //标志位置0 // guc_Uartcnt = 0; // SCON |= 0x10; //使能串口中断 // IE |= 0x10; //UART1中断使能 // } temp=KeyPro(); if(temp!=0xff) { if((temp>=0)&&(temp<=9)) txBuf[14]=temp+0x30; else if((temp>=10)&&(temp<=15)) txBuf[14]=temp+55; for(i = 0; i < sizeof(txBuf); i++) { SBUF = txBuf[i]; //发送数据 while(!(SCON&0x02)); SCON &=~ 0x02; //发送中断请求中断标志位? } } } }效果图:
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
发帖类勋章
时间类勋章
人才类勋章
等级类勋章
470
3537
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
