[STM32F4] stm32F407 ADC
3497|40
 楼主| c17 发表于 2023-5-27 00:56 | 显示全部楼层
ADC—三重ADC-单通道-交替采集  只能每一个ADCX一个通道
  1. #include "stm32f4xx.h"
  2. #include "./usart/bsp_debug_usart.h"
  3. #include "./adc/bsp_adc.h"
  4. // ADC1转换的电压值通过MDA方式传到SRAM
  5. extern __IO uint32_t ADC_ConvertedValue[3];
  6. // 局部变量,用于保存转换计算后的电压值
  7. float ADC_ConvertedValueLocal[3];
  8. static void Delay(__IO uint32_t nCount)         //简单的延时函数
  9. {
  10.         for(; nCount != 0; nCount--);
  11. }
  12. /**
  13.   * @brief  主函数
  14.   * @param  无
  15.   * @retval 无
  16.   */
  17. int main(void)
  18. {
  19.   /*初始化USART 配置模式为 115200 8-N-1,中断接收*/
  20.   Debug_USART_Config();
  21.         Rheostat_Init();
  22.
  23.   while (1)
  24.   {
  25.     Delay(0xffffee);
  26.
  27.     ADC_ConvertedValueLocal[0] =(float)((uint16_t)ADC_ConvertedValue[0]*3.3/4096);
  28.     ADC_ConvertedValueLocal[1] =(float)((uint16_t)ADC_ConvertedValue[1]*3.3/4096);
  29.     ADC_ConvertedValueLocal[2] =(float)((uint16_t)ADC_ConvertedValue[2]*3.3/4096);
  30.
  31.     printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[0]);
  32.     printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[1]);
  33.     printf("\r\n The current AD value = 0x%08X \r\n", ADC_ConvertedValue[2]);
  34.
  35.     printf("\r\n The current ADC1 value = %f V \r\n",ADC_ConvertedValueLocal[0]);
  36.     printf("\r\n The current ADC2 value = %f V \r\n",ADC_ConvertedValueLocal[1]);
  37.     printf("\r\n The current ADC3 value = %f V \r\n",ADC_ConvertedValueLocal[2]);
  38.   }
  39. }
  40. /*********************************************END OF FILE**********************/
  41. #ifndef __BSP_ADC_H
  42. #define        __BSP_ADC_H
  43. #include "stm32f4xx.h"
  44. // ADC GPIO 宏定义
  45. #define RHEOSTAT_ADC_GPIO_PORT    GPIOC
  46. #define RHEOSTAT_ADC_GPIO_PIN     GPIO_Pin_2
  47. #define RHEOSTAT_ADC_GPIO_CLK     RCC_AHB1Periph_GPIOC
  48. // ADC 序号宏定义
  49. #define RHEOSTAT_ADC1             ADC1
  50. #define RHEOSTAT_ADC1_CLK         RCC_APB2Periph_ADC1
  51. #define RHEOSTAT_ADC2             ADC2
  52. #define RHEOSTAT_ADC2_CLK         RCC_APB2Periph_ADC2
  53. #define RHEOSTAT_ADC3             ADC3
  54. #define RHEOSTAT_ADC3_CLK         RCC_APB2Periph_ADC3
  55. #define RHEOSTAT_ADC_CHANNEL      ADC_Channel_12
  56. // ADC CDR寄存器宏定义,ADC转换后的数字值则存放在这里
  57. #define RHEOSTAT_ADC_CDR_ADDR    ((uint32_t)0x40012308)
  58. // ADC DMA 通道宏定义,这里我们使用DMA传输
  59. #define RHEOSTAT_ADC_DMA_CLK      RCC_AHB1Periph_DMA2
  60. #define RHEOSTAT_ADC_DMA_CHANNEL  DMA_Channel_0
  61. #define RHEOSTAT_ADC_DMA_STREAM   DMA2_Stream0
  62. void Rheostat_Init(void);
  63. #endif /* __BSP_ADC_H */
  64. /**
  65.   ******************************************************************************
  66.   * @file    bsp_bsp_adc.c
  67.   * @author  fire
  68.   * @version V1.0
  69.   * @date    2015-xx-xx
  70.   * @brief   adc驱动
  71.   ******************************************************************************
  72.   * @attention
  73.   *
  74.   * 实验平台:野火  STM32 F407 开发板
  75.   * 论坛    :http://www.firebbs.cn
  76.   * 淘宝    :https://fire-stm32.taobao.com
  77.   *
  78.   ******************************************************************************
  79.   */
  80. #include "./adc/bsp_adc.h"
  81. __IO uint32_t ADC_ConvertedValue[3];
  82. static void Rheostat_ADC_GPIO_Config(void)
  83. {
  84.                 GPIO_InitTypeDef GPIO_InitStructure;
  85.
  86.         // 使能 GPIO 时钟
  87.         RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_GPIO_CLK, ENABLE);
  88.
  89.         // 配置 IO
  90.         GPIO_InitStructure.GPIO_Pin = RHEOSTAT_ADC_GPIO_PIN;
  91.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  92.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ; //不上拉不下拉
  93.         GPIO_Init(RHEOSTAT_ADC_GPIO_PORT, &GPIO_InitStructure);
  94. }
  95. static void Rheostat_ADC_Mode_Config(void)
  96. {
  97.         DMA_InitTypeDef DMA_InitStructure;
  98.         ADC_InitTypeDef ADC_InitStructure;
  99.   ADC_CommonInitTypeDef ADC_CommonInitStructure;
  100.
  101.   // ------------------DMA Init 结构体参数 初始化--------------------------
  102.   // ADC1使用DMA2,数据流0,通道0,这个是手册固定死的
  103.   // 开启DMA时钟
  104.   RCC_AHB1PeriphClockCmd(RHEOSTAT_ADC_DMA_CLK, ENABLE);
  105.         // 外设基址为:ADC 数据寄存器地址
  106.         DMA_InitStructure.DMA_PeripheralBaseAddr = RHEOSTAT_ADC_CDR_ADDR;
  107.   // 存储器地址,实际上就是一个内部SRAM的变量
  108.         DMA_InitStructure.DMA_Memory0BaseAddr = (u32)ADC_ConvertedValue;
  109.   // 数据传输方向为外设到存储器
  110.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  111.         // 缓冲区大小为,指一次传输的数据量
  112.         DMA_InitStructure.DMA_BufferSize = 3;
  113.         // 外设寄存器只有一个,地址不用递增
  114.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  115.   // 存储器地址固定
  116.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  117.   // // 外设数据大小为半字,即两个字节
  118.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
  119.   //        存储器数据大小也为半字,跟外设数据大小相同
  120.         DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Word;
  121.         // 循环传输模式
  122.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  123.   // DMA 传输通道优先级为高,当使用一个DMA通道时,优先级设置不影响
  124.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  125.   // 禁止DMA FIFO        ,使用直连模式
  126.   DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  127.   // FIFO 大小,FIFO模式禁止时,这个不用配置
  128.   DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
  129.   DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  130.   DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  131.         // 选择 DMA 通道,通道存在于流中
  132.   DMA_InitStructure.DMA_Channel = RHEOSTAT_ADC_DMA_CHANNEL;
  133.   //初始化DMA流,流相当于一个大的管道,管道里面有很多通道
  134.         DMA_Init(RHEOSTAT_ADC_DMA_STREAM, &DMA_InitStructure);
  135.         // 使能DMA流
  136.   DMA_Cmd(RHEOSTAT_ADC_DMA_STREAM, ENABLE);
  137.
  138.         // 开启ADC时钟
  139.         RCC_APB2PeriphClockCmd(RHEOSTAT_ADC1_CLK , ENABLE);
  140.   RCC_APB2PeriphClockCmd(RHEOSTAT_ADC2_CLK , ENABLE);
  141.         RCC_APB2PeriphClockCmd(RHEOSTAT_ADC3_CLK , ENABLE);
  142.
  143.   // -------------------ADC Init 结构体 参数 初始化--------------------------
  144.         ADC_StructInit(&ADC_InitStructure);
  145.         // 独立ADC模式
  146.   ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_Interl;
  147.   // 时钟为fpclk x分频
  148.   ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;
  149.   // 禁止DMA直接访问模式
  150.   ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_2;
  151.   // 采样时间间隔
  152.   ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles;
  153.   ADC_CommonInit(&ADC_CommonInitStructure);
  154.
  155.   // -------------------ADC Init 结构体 参数 初始化--------------------------
  156.   // ADC 分辨率
  157.   ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
  158.   // 禁止扫描模式,多通道采集才需要
  159.   ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  160.   // 连续转换
  161.   ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  162.   //禁止外部边沿触发
  163.   ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
  164.   //外部触发通道,本例子使用软件触发,此值随便赋值即可
  165.   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  166.   //数据右对齐
  167.   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  168.   //转换通道 1个
  169.   ADC_InitStructure.ADC_NbrOfConversion = 1;
  170.
  171.   ADC_Init(RHEOSTAT_ADC1, &ADC_InitStructure);
  172.   //---------------------------------------------------------------------------
  173.
  174.    // 配置 ADC 通道转换顺序为1,第一个转换,采样时间为3个时钟周期
  175.   ADC_RegularChannelConfig(RHEOSTAT_ADC1, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
  176.   //---------------------------------------------------------------------------
  177.
  178.         ADC_Init(RHEOSTAT_ADC2, &ADC_InitStructure);
  179.   // 配置 ADC 通道转换顺序为1,第一个转换,采样时间为3个时钟周期
  180.   ADC_RegularChannelConfig(RHEOSTAT_ADC2, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
  181.   //---------------------------------------------------------------------------
  182.
  183.         ADC_Init(RHEOSTAT_ADC3, &ADC_InitStructure);
  184.   // 配置 ADC 通道转换顺序为1,第一个转换,采样时间为3个时钟周期
  185.   ADC_RegularChannelConfig(RHEOSTAT_ADC3, RHEOSTAT_ADC_CHANNEL, 1, ADC_SampleTime_3Cycles);
  186.
  187.   // 使能DMA请求 after last transfer (multi-ADC mode)
  188.   ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
  189.   // 使能ADC DMA
  190.   ADC_DMACmd(RHEOSTAT_ADC1, ENABLE);
  191.
  192.   // 使能ADC
  193.   ADC_Cmd(RHEOSTAT_ADC1, ENABLE);
  194.   ADC_Cmd(RHEOSTAT_ADC2, ENABLE);
  195.   ADC_Cmd(RHEOSTAT_ADC3, ENABLE);
  196.
  197.   //开始adc转换,软件触发
  198.   ADC_SoftwareStartConv(RHEOSTAT_ADC1);
  199. //  ADC_SoftwareStartConv(RHEOSTAT_ADC2);
  200. //  ADC_SoftwareStartConv(RHEOSTAT_ADC3);
  201. }
  202. void Rheostat_Init(void)
  203. {
  204.         Rheostat_ADC_GPIO_Config();
  205.         Rheostat_ADC_Mode_Config();
  206. }
