[通信技术资料] DR6018 Routerboard: Unleashing Long-Distance Transfer Capabilities up 23Km!
1471|0
 楼主| Cindy@wallys 发表于 2023-6-12 14:29 | 显示全部楼层 |阅读模式
Introduction:
In today's interconnected world, seamless and reliable data transfer is crucial for businesses, organizations, and individuals alike. The DR6018 Series Routerboard has emerged as a game-changing solution, revolutionizing long-distance data transfer. With its recent upgrade, the DR6018 Series Routerboard now supports long-distance transfers of up to an impressive 23km. This remarkable achievement opens up new possibilities for networking and communication, empowering users with enhanced connectivity and efficiency. Let's delve deeper into the features and benefits of the DR6018 Series Routerboard and explore how it enables long-distance transfer like never before.
Enhanced Connectivity:
The DR6018 Series Routerboard is designed to provide robust connectivity over extended distances, catering to a wide range of applications. Whether it's setting up networks in remote areas, connecting multiple offices across vast distances, or facilitating data transfer between critical infrastructure, this routerboard excels at overcoming the limitations of traditional networking solutions.
The Qualcomm-Atheros IPQ6010 is a system-on-a-chip (SoC) designed for networking applications. Here are the specifications and features of the IPQ6010:
Processor: It features a quad-core ARM Cortex-A53 processor, operating at a clock speed of 1.8GHz. The Cortex-A53 is a 64-bit architecture commonly used in low-power devices.
System Memory: The IPQ6010/ipq6018 has 1GB of DDR3L system memory. DDR3L is a low-voltage variant of DDR3 memory, commonly used in power-efficient devices.
Flash Memory: It is equipped with 32MB of NOR Flash and 256MB of NAND Flash. NOR Flash is used for storing the firmware, while NAND Flash is used for data storage.
Dynamic Frequency Selection (DFS): The IPQ6010 supports DFS, which is a regulatory requirement for certain wireless communication channels. DFS enables the device to detect and avoid interference from radar systems.
On-board Radios: It includes two on-board radios, one for 2.4GHz and another for 5GHz frequency bands. The 2.4GHz radio supports a physical data rate of up to 573Mbps, while the 5GHz radio supports a physical data rate of up to 1201Mbps. These radios are used for wireless communication and networking.
Support for QUECTEL RM500Q-GL: The IPQ6010/ipq6018 supports the QUECTEL RM500Q-GL module. The RM500Q-GL is a 5G modem module that provides cellular connectivity.
Support for QCN9074 WiFi 6E Card: The IPQ6010 is compatible with the QCN9074 WiFi 6E card. The QCN9074 is a wireless network card that supports the WiFi 6E standard, offering faster speeds and lower latency compared to previous WiFi generations.
Support for Openwifi: Openwifi is an open-source project that provides a full-stack implementation of IEEE 802.11 WiFi baseband and MAC layers. The IPQ6010 supports Openwifi, allowing for flexibility and customization in the WiFi implementation.
Support for QSDK: QSDK (Qualcomm Software Development Kit) is a software framework provided by Qualcomm for developing applications and firmware for Qualcomm-based platforms. The IPQ6010 supports QSDK, enabling developers to build and customize software for the device.
Extended Range Capabilities:
By leveraging advanced technology and innovative design, the DR6018 Series Routerboard now boasts an extended range capability of up to 23km. This breakthrough achievement has been made possible through a combination of hardware enhancements and software optimizations. The routerboard's high-gain antennas and improved signal processing algorithms ensure reliable and efficient data transmission over long distances, eliminating the need for costly infrastructure investments or complex setups.
Seamless Performance:
With the DR6018 Series Routerboard, long-distance transfer no longer means compromising on performance. The routerboard is built to deliver exceptional throughput and low latency, ensuring swift and uninterrupted data flow even across vast distances. Whether it's transferring large files, streaming high-definition media, or hosting real-time applications, users can rely on the routerboard to handle the demands of data-intensive tasks with ease.
Security and Reliability:
In addition to its impressive long-distance capabilities, the DR6018 Series Routerboard prioritizes security and reliability. Robust encryption protocols and advanced firewall features safeguard data during transmission, protecting it from unauthorized access and potential threats. The routerboard also incorporates intelligent redundancy mechanisms, ensuring uninterrupted connectivity even in the event of network disruptions or hardware failures.
Versatility and Scalability:
The DR6018 Series Routerboard is a versatile networking solution suitable for various scenarios. Its scalability allows users to expand their networks as needed, accommodating growing demands and evolving business requirements. Whether you need to connect multiple sites, establish a point-to-point link, or create a wireless backbone, the routerboard's flexibility and adaptability make it an ideal choice.
Conclusion:
The DR6018 Series Routerboard's newfound support for long-distance transfers up to 23km signifies a significant leap forward in networking capabilities. By combining enhanced connectivity, extended range, seamless performance, and robust security features, this routerboard empowers businesses and individuals to overcome the challenges of long-distance data transfer. With the DR6018 Series Routerboard, users can now achieve reliable, high-speed connectivity even across vast distances, unlocking a world of opportunities for networking and communication. Whether it's connecting remote locations, expanding existing networks, or facilitating data transfer in critical environments, the DR6018 Series Routerboard is poised to redefine the way we think about long-distance networking.
