- import sensor, image, time, lcd, struct, ustruct, _thread
- from maix import KPU,GPIO, I2S, FFT
- import gc,os
- from machine import Timer,PWM,I2C
- from fpioa_manager import fm
- lcd.init() # Init lcd display
- lcd.clear(lcd.RED) # Clear lcd screen.
- sensor.reset() # Reset and initialize the sensor.
- sensor.reset(freq=24000000, dual_buff=1) # 设置摄像头频率 24M 开启双缓冲模式 会提高帧率 但内存占用增加
- sensor.set_auto_exposure(1) # 设置自动曝光
- sensor.set_auto_gain(False) # 颜色跟踪必须关闭自动增益
- sensor.set_auto_whitebal(False) # 颜色跟踪必须关闭白平衡
- sensor.set_pixformat(sensor.RGB565) # Set pixel format to RGB565 (or GRAYSCALE)
- sensor.set_framesize(sensor.QVGA) # Set frame size to QVGA (320x240)
- sensor.set_windowing((224,224)) # 分辨率为B224X224
- sensor.set_vflip(1)
- sensor.skip_frames(time = 2000) # Wait for settings take effect.
- clock = time.clock() # Create a clock object to track the FPS.
- #要拍摄不同的数字就切换这里的数字
- need_number_ficture= 1
- #保存文件名计数
- save_count =0
- #注册IO,注意高速GPIO口才有中断
- fm.register(35, fm.fpioa.GPIO0)
- fm.register(16, fm.fpioa.GPIOHS0)
- #构建案件对象
- KEY=GPIO(GPIO.GPIOHS0, GPIO.IN, GPIO.PULL_UP)
- #按键标志位
- key_node = 0
- key_press_long = 0
- #中断回调函数
- def fun(KEY):
- global state,key_node,need_number_ficture
- temp_count = 0
- time.sleep_ms(10) #消除抖动
- while KEY.value()== 0:
- key_node = 1
- time.sleep_ms(10) #长按延时
- #长按检测计数
- temp_count=temp_count+1
- if temp_count >= 50:
- key_node = 0
- beep.duty(50)
- time.sleep_ms(500)
- beep.duty(0)
- time.sleep_ms(100)
- need_number_ficture=need_number_ficture+1
- if(need_number_ficture == 9):
- need_number_ficture=0
- #开启中断,下降沿触发
- KEY.irq(fun, GPIO.IRQ_FALLING)
- #先把文件路径切换到文件卡里面
- os.chdir("/sd")
- #os.mkdir("img/0")
- #os.mkdir("img/1")
- #os.mkdir("img/2")
- #os.mkdir("img/3")
- #os.mkdir("img/4")
- #os.mkdir("img/5")
- #os.mkdir("img/6")
- #os.mkdir("img/7")
- #os.mkdir("img/8")
- #PWM通过定时器配置,接到IO15引脚
- tim = Timer(Timer.TIMER0, Timer.CHANNEL0, mode=Timer.MODE_PWM)
- beep = PWM(tim, freq=1000, duty=0, pin=9)
- clock = time.clock() # 创建一个clock对象,用来计算帧率
- while True:
- clock.tick() # 更新计算帧率的clock
- img=sensor.snapshot()
- #按键按下进入
- if key_node == 1:
- save_count=save_count+1
- img.save("img/"+str(need_number_ficture)+"/"+str(save_count)+".jpg")
- beep.duty(50)
- beep.duty(0)
- key_node = 0 #清除按键标志位
- # 在图像上画字符串
- img.draw_string(0, 10,str(need_number_ficture)+"/"+str(save_count)+".jpg", color = (200, 0, 0), scale = 2, mono_space = False,
- char_rotation = 0, char_hmirror = False, char_vflip = False,
- string_rotation = 0, string_hmirror = False, string_vflip = False)
- lcd.display(img)
下面来解释一下上面这段代码做了什么:
- 导入必要的库:导入需要的库和模块(就像C语言的.h头文件一样),如sensor, image, time, lcd, GPIO, Timer, PWM, I2C等。
- 初始化LCD屏幕:使用lcd.init()初始化LCD屏幕,并使用lcd.clear(lcd.RED)清空屏幕,防止出现误显示问题。
- 设置摄像头:使用sensor.reset()重置摄像头并进行初始化。然后,设置摄像头的相关参数,比如时钟频率、设置双缓冲来增加帧率,关闭自动曝光、关闭自动增益、关闭自动白平衡、设置像素格式、帧大小、窗口大小、垂直翻转(这个和用的摄像头有关)等。
- 初始化变量:初始化必要的变量,如当前拍摄的数字(need_number_ficture)、保存计数(save_count)、按键标志位(key_node)等。
- 设置GPIO和按键中断:注册GPIO,并创建一个按键对象KEY。定义一个中断回调函数fun(KEY),用于在按键按下时改变当前拍摄的数字。最后,配置按键中断,使其在下降沿触发。
- 设置蜂鸣器:使用Timer和PWM初始化蜂鸣器,并连接到指定的引脚。
- 主循环:在主循环中,首先更新帧率计算的clock。然后,从摄像头捕获一帧图像。如果按键被按下(key_node为1),则将当前帧图像保存到SD卡的相应目录(对应于当前拍摄的数字)。同时,蜂鸣器发出提示音(提示我们拍照OK了)。最后,在图像上绘制当前拍摄数字和已保存的图片计数,并将图像显示在LCD屏幕上,方便提示我们拍摄下一张照片。
对数据集进行标注
这个就需要用到一个大神开发的软件了(现在最新版自带Python环境,无需麻烦的环境配置了),下载地址,找下面的百度网盘下载链接,找到里面的V4.0.0下载下来安装后就可以使用了。用读卡器把 K210的TF 卡里面采集到的训练集保存到电脑上。
打开Mx-yolo里面工具集中的图片标注助手,打开保存采集数据的文件夹。详细教程请查看这个链接。
开始训练
训练可以选在线的也可以用本地的,但是如果像是电赛这种时间很紧张的比赛,为了防止到时候千军万马过独木桥,导致你的训练任务一直在排队,最好先设置好自己的本地环境。按照上面的介绍安装mx-yolo。
- 模型训练的次数需要在保证模型收敛的前提下进行合理的选择。如果训练次数过少,可能会导致模型欠拟合,无法很好地拟合训练数据。如果训练次数过多,可能会导致模型过拟合,无法很好地泛化到新的数据。因此,需要根据具体的问题和数据集进行调整。一般来说,可以通过观察模型在训练集和验证集上的表现来确定合适的训练次数。当模型在验证集上的表现不再提升时,可以停止训练,以避免过拟合。
- Alpha 主要影响所生成模型的大小,选 0.25 模型大小约 219k,选 0.5 模型大小约 831k,选 0.75 模型大小约 1.85M,选 1.0 模型大小约 3.24M。当运行 maixpy 的最大固件时,k210 最大只能加载约 2MB 左右的模型,所以选 0.75 就行了。
- Batch Size 一般选 8 就行了。这个参数是指每次迭代训练时,所选取的样本数。Batch Size 的大小会影响模型训练的速度和稳定性。较大的 Batch Size 可以加快模型训练的速度,因为每次迭代处理的样本数量更多。但是,如果 Batch Size 过大,可能会导致内存不足或显存不足的问题。此外,较大的 Batch Size 还可能导致模型过度拟合训练数据。较小的 Batch Size 可以提高模型训练的稳定性,因为每次迭代处理的样本数量较少,可以更好地避免过拟合。但是,较小的 Batch Size 也会导致训练时间变长,因为需要更多次迭代才能处理完所有样本。
- 数据增强建议开启,他主要是做了一些随机裁剪,随机旋转,缩放,翻转等。
训练结束后他会自动把模型转换为K210能使用的模型,主要文件都在\result_root_dir\detector_result目录下面,它还会给一张测试报告,确保模型损失已经到了0.1以下。在测试报告中,epoch代表训练次数,model loss是模型损失,train代表训练集,是用来训练模型的数据集。valid代表验证集,是用来评估模型性能和调整超参数的数据集。这两条线越来越往下就是越来越好了。
文件下的boot.py是他给的测试程序,labels.txt是标签顺序,mx.kmodel是K210实际要用的模型文件(这个文件在使用的时候需要保存到K210要使用的TF卡里面)。简单来说,把boot.py,lables.txt,mx.kmodel一起放到K210的sd卡里,重新上电就可以运行了。
