[STM32G0] STM32G0 外部触发中断打开,TIM1 无法进入中断
1658|13
 楼主| jack.king 发表于 2023-8-8 10:40 | 显示全部楼层 |阅读模式
请问下:
但是屏蔽使能外部中断就可以正常进入。
  NVIC_SetPriority(EXTI0_1_IRQn, 0);
  NVIC_EnableIRQ(EXTI0_1_IRQn);
//屏蔽这个就可以。正常进入
什么其他的都不需要改
void MX_GPIO_Init(void)
  LL_EXTI_InitTypeDef EXTI_InitStruct = {0};
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOA);
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOB);
  LL_GPIO_SetOutputPin(GPIOA, LL_GPIO_PIN_4|LL_GPIO_PIN_5|LL_GPIO_PIN_6|LL_GPIO_PIN_7);
        //LL_GPIO_SetOutputPin(GPIOB, LL_GPIO_PIN_5|LL_GPIO_PIN_6|LL_GPIO_PIN_7);
  LL_EXTI_SetEXTISource(LL_EXTI_CONFIG_PORTA, LL_EXTI_CONFIG_LINE0|LL_EXTI_CONFIG_LINE1|LL_EXTI_CONFIG_LINE2|LL_EXTI_CONFIG_LINE3);
  //LL_EXTI_SetEXTISource(LL_EXTI_CONFIG_PORTA, LL_EXTI_CONFIG_LINE1);
  EXTI_InitStruct.Line_0_31 = LL_EXTI_LINE_0|LL_EXTI_LINE_1|LL_EXTI_LINE_2|LL_EXTI_LINE_3;
  EXTI_InitStruct.LineCommand = ENABLE;
  EXTI_InitStruct.Mode = LL_EXTI_MODE_IT;
//  EXTI_InitStruct.Trigger = LL_EXTI_TRIGGER_FALLING;
          EXTI_InitStruct.Trigger = LL_EXTI_TRIGGER_RISING_FALLING;
  LL_EXTI_Init(&EXTI_InitStruct);
  LL_GPIO_SetPinPull(GPIOA, LL_GPIO_PIN_0|LL_GPIO_PIN_1|LL_GPIO_PIN_2|LL_GPIO_PIN_3, LL_GPIO_PULL_UP);
  LL_GPIO_SetPinMode(GPIOA, LL_GPIO_PIN_0|LL_GPIO_PIN_1|LL_GPIO_PIN_2|LL_GPIO_PIN_3, LL_GPIO_MODE_INPUT);
  GPIO_InitStruct.Pin = LL_GPIO_PIN_0|LL_GPIO_PIN_1|LL_GPIO_PIN_2|LL_GPIO_PIN_3;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_UP;
  LL_GPIO_Init(GPIOA, &GPIO_InitStruct);//输入
  GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
  LL_GPIO_Init(GPIOB, &GPIO_InitStruct);//输入
//LED输出
  GPIO_InitStruct.Pin = LL_GPIO_PIN_4|LL_GPIO_PIN_5|LL_GPIO_PIN_6|LL_GPIO_PIN_7;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
  GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
  GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_OPENDRAIN;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  LL_GPIO_SetOutputPin(GPIOA,LL_GPIO_PIN_4|LL_GPIO_PIN_5|LL_GPIO_PIN_6|LL_GPIO_PIN_7);
  /* EXTI interrupt init*/
/* TIM1 init function */
void MX_TIM1_Init(void)
  /* USER CODE BEGIN TIM1_Init 0 */
  /* USER CODE END TIM1_Init 0 */
  LL_TIM_InitTypeDef TIM_InitStruct = {0};
  /* Peripheral clock enable */
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM1);
  /* TIM1 interrupt Init */
  NVIC_SetPriority(TIM1_BRK_UP_TRG_COM_IRQn, 0);
  NVIC_EnableIRQ(TIM1_BRK_UP_TRG_COM_IRQn);
  /* USER CODE BEGIN TIM1_Init 1 */
  /* USER CODE END TIM1_Init 1 */
  TIM_InitStruct.Prescaler = 64 - 1;
  TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;//32
  TIM_InitStruct.Autoreload = 100;//64*2 - 55;//64*2 - 55 大约2.1US
        //TIM_InitStruct.Autoreload = 1000;
  TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
  TIM_InitStruct.RepetitionCounter = 0;
  LL_TIM_Init(TIM1, &TIM_InitStruct);
  LL_TIM_DisableARRPreload(TIM1);
  LL_TIM_SetClockSource(TIM1, LL_TIM_CLOCKSOURCE_INTERNAL);
  LL_TIM_SetTriggerOutput(TIM1, LL_TIM_TRGO_RESET);
  LL_TIM_SetTriggerOutput2(TIM1, LL_TIM_TRGO2_RESET);
  LL_TIM_DisableMasterSlaveMode(TIM1);
  /* USER CODE BEGIN TIM1_Init 2 */
                TIM1->DIER |= 1 << 0;// 中断
        TIM1->CR1 |= 1 << 0;//启动
  /* USER CODE END TIM1_Init 2 */
香水城 发表于 2023-8-9 21:17 | 显示全部楼层
会不会是外部中断没处理好,频繁进入而抢占了TIM中断?
Stahan 发表于 2023-8-11 23:58 | 显示全部楼层
是不优先级的问题啊
呐咯密密 发表于 2023-12-26 10:27 | 显示全部楼层
应该是抢占了
童雨竹 发表于 2024-2-21 07:10 | 显示全部楼层
代码量小的时候用来做条件判断
Wordsworth 发表于 2024-2-21 08:13 | 显示全部楼层
在直流电流上叠加了一些小的交流电流分量
Clyde011 发表于 2024-2-21 09:16 | 显示全部楼层
连接点是产生控制IC所要检测的小电压的所有器件的公共连接点
公羊子丹 发表于 2024-2-21 10:09 | 显示全部楼层
这是个再正常不过的coding习惯
万图 发表于 2024-2-21 11:12 | 显示全部楼层
宽度则与电感量和电阻量成反比
Uriah 发表于 2024-2-21 12:15 | 显示全部楼层
电流要增大
帛灿灿 发表于 2024-2-21 14:11 | 显示全部楼层
有些信号包含丰富的高频分量
Bblythe 发表于 2024-2-21 15:14 | 显示全部楼层
交流电流环路的布线要在其他引线之前布好
周半梅 发表于 2024-2-21 17:10 | 显示全部楼层
对于优秀程序员来说,这不是好代码
Pulitzer 发表于 2024-2-21 18:13 | 显示全部楼层
功率开关或整流环的连接没有直接接到电容的两端
